Question about Dell Inspiron 531 Athlon 64 X2 4400+ 2.3GHz 1GB 500GB DVD RW Vista Home Premium PC Desktop
My dell inspiron 531 just has beeping noise and a black screen unable to boot up any idea?
  • joecoolvette
    joecoolvette Nov 08, 2010
    The beeping noise is a BIOS Beep Code. The computers way of telling you something is wrong, and an area to look into for it. It is a Code. The code may consist of Short beeps, or Long beeps, or a combination of the two. Then a period of silence, (Pause), then the code starts over again. What do you hear? [ A lot of times the Ram Memory modules {'Sticks'} are the problem. Computer unplugged from power, Anti-Static Precautions observed, open the computer case, remove all Ram Memory modules. Clean the gold plated contact pins on the bottom with a pencil eraser. Use air to remove the eraser dust. {Air from one's mouth is sufficient} Reinstall the Ram Memory module/s, close the computer case, plug the computer into power. WAIT 1 minute, turn the computer on ]
    Problem Solver:
  • 6 Answers
Here is a link to a list of beeping codes from dell. Also there is a list for the lights on the back of the system.
http://support.dell.com/support/edocs/systems/dsleest/codemess.htm
Posted on Nov 08, 2010
My dell inspiron 531 PC just keeps beeping and will not boot up!
The beeping is called a beep code, you may be able to check the connections on the inside but only if you know what you're doing. You will most likely have to take it in the be serviced.
Jul 28, 2011 | Dell Inspiron 531 Athlon 64 X2 4400+...
Got an interesting issue. I've got a dell inspiron 531 with a dell ry206 motherboard. Bad news is, when I boot up the pc, the power turns on, the fans turn on, but that's it!, only CD ROM and cpu fans...
Hello
Open up the case,after unpluging pc.
Remove memory sticks one at a time.After you removed one try pc again.
If it boots up normally then you know that memory stick is bad.Also check your keyboard by unpluging and pluging back in while booting up.
More then likley this is bad memory.
Mar 24, 2011 | Dell Computers & Internet
Dell 531 insp. will not boot up and has 3 beeps along with an orange light??? can you help tell me what it may be??
3 beeps signal a problem with the memory. take out the memory sticks, put another one in and try to start it - if the pc boots then your sticks are defective, if it doesn't then the motherboard is defective. Replace the failed part.
Dec 01, 2010 | Dell Inspiron 531 Athlon 64 X2 4400+...
When I turned on my dell inspiron 531 all I get is the Dell splash screen, it won't let me press F2 or F12, or go into diagnostics. it just freezes on the splash screen everytime. I have over 200GB of free...
With the Power Off, and Plug Removed, try removing your memory modules, and then plug in and power up. If you here a series of beeps, it means your motherboard could be working fine. If you do not hear any beeps, but the Power Supply and CPU Fans spin, then it could indicate that your Integrated Video Card has been damaged. Usually happens due to excessive heat if system is left on for days, and Games are played using High Graphic Resources. Prior to this happening, did your system shut down on its own, reboot without warning, or show any weird colours or characters on the screen? Try adding an external Video Card in one of the available slots and see if you can boot the system.
Jan 10, 2010 | Dell Inspiron 531 Athlon 64 X2 4400+...
Show a blue screen
You need to go into the Setup Utility or BIOS when the computer boots. You need to enable the computer to boot from the CD drive, and set up boot priority with CD Drive first, then Hard Drive HDD.
Then it will boot the disc.
Dec 17, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Dell Inspiron 531 gets me crazy..
hello, sounds like memory issue, I would say if you have more than one stick of memory in it remove one at a time and try it again.
also while you are at it reset BIOS by remove battery from motherboard and/or switching jumper setting.
hope it helps.
regards
Amar Sondhi
Dec 05, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
No boot device available
If the other computer would not properly access the HD as a slave, I would definitely concur that it is a hard drive failure.
Apr 09, 2009 | Dell Latitude C640 Notebook
My dell inspiron 531 is beeping when i try to boot it. it beeps twice thne pauses and then repeats. last night is froze
Ok with that issue your hard drive is either not connected correctly or your hard drive has gone bad.
Apr 08, 2009 | Dell Inspiron 531s Desktop Computer
Open Questions:
Dell Inspiron 531 Athlon 64 X2 4400+ 2.3GHz 1GB 500GB DVD RW Vista Home Premium PC Desktop Logo
1,477 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
