Question about Craftsman Hydro Ground Drive Belt
I have a model #917.28870 lawn tractor. I recently changed the ground drive belt due to slippage. It worked fine for the first 8 hours or so and is now slipping as before. The belt was replaced exactly as it came out. with a craftsman belt, are there any adjustments? if so where?
  • 49 Answers
SOURCE: mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Posted on Feb 05, 2009
  • 246 Answers
SOURCE: owners manual for a craftsman model 917255812 lawn tractor
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Respectfully
John
Posted on Apr 21, 2009
SOURCE: 20 Year Old Craftsman Lawn Tractor Steering Gear Slips
check top of sector gear mounting plate for waer this is the gear that hooks to you steering gear . the plate that it mounts to will ware down causing it to be loos and slip . the only way i know to fix it is to pull the cross member out and take it to a welding shop and have it built back up.if the bolt is as tight as itcan go .
Posted on May 06, 2009
wadembly
  • 448 Answers
SOURCE: How do you change Craftsman Lawn tractor model
it simple 1st lower mower deck 2nd take belt off of engine pulley then out behind the idler pulleys then the blade pulleys slide out & reinstall if i can further help you e-mail me wade at wadembly@aol.com
Posted on Jun 28, 2009
  • 376 Answers
SOURCE: large belt routing for crafstman lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number that is under the seat. If it's a lawn tractor, it will start with 917. That will get you to all the diagrams of the mower.
Posted on Jul 02, 2009
What size belt does my lawnmower take its a Craftsman lt2000 model# 917.275762
How would someone know that,
unless they had the same product ?
You have no owners manual or service
manual?
All you have to do, is remove the old belt,
& read the numbers on it
You can stop by any small equipment shop & give
them the old belt or the make & model numbers & they
will look up the new belt
Oct 03, 2014 | Garden
Clutch pulley slippage
you are out of Alignment and need to check the Bearings on your Pulley. They go bad due to Water coming down on it through your deck
Oct 02, 2014 | Craftsman Garden
Craftsman mod # 944.609800..20.5hp/42...how can i get a diagram of how to change a ground drive belt?
You need to contact Searspartsdirect get a copy of the owner manual. Use their Email Us on below linked page. They should be able to give a link to the manual.
If you just wish to look at the parts diagrams here is link for that.
CRAFTSMAN Lawn Tractor Parts Model 944609810
Aug 14, 2014 | Craftsman Garden
Fix a motion drive belt squeals on a Craftsman 24 hp 42 in. Deck Lawn Tractor - CA Model
If I understand the issue correctly, the belt that drives the machine's transmission squeals. When does it squeal? When engaging the clutch? When in motion?
Typically it's the condition of the belt. It's likely slipping due to stretch, wear or from an oil leak causing it to slip, or simply due to a loose idler pulley, worn idler pulley bearing, broken spring. Look for all that stuff. Look at the drive belt and inspect for wear, cracks, fraying, missing rubber, etc. Replace it if any of those conditions are found.
Jul 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Toro manuals
If the belt has quite a few hours it may have stretched enough to cause it to slip. May have to replace it. I replaced mine and works fine now. As a short fix you can spray with a belt dressing and will work for a while if the slippage is not too bad. The can will specify for slipping belts.
Feb 24, 2014 | Toro Titan ZX4800 23HP Zero Turning Radius...
Craftsman lawn tractor model 917.270821 ( Auto trans)
Check the fluid level in the transmission. If the fluid level is low, the trans will act as if it's slipping.
Nov 25, 2009 | Vacuums
Cratsman lt2000 lawn tractor will start but will not move forward or backward. I tried changing the drive belt, but that didn't work.
Is the transaxle pulley turning? If so have you removed the rear wheel recently and possibly lost the square key that fits on the axle?check those two items first.If ok it probably has a broken gear or shift key in transaxle.
Jul 14, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
LTX 1000 CRAFTSMAN /42 IN. DECK BELT LODGED ABOVE PULLEY AND STOPPED MOWER AND BROKE BELT. IS THE BELT SIZE 96 OR 97 INCH? THE BELT HAS DONE IT TWICE/STCK BETWEEN THE PULLEY AND THE THING ABOVE IT.
Without the model number, I couldn't tell you what belt goes on the ground drive. That 174883 is a 5/8 x 97" and is your deck drive belt. Your ground drive belt may just need replacing. They will wear thin and loosen up between the pulleys and cause the problems you're having. The old belt may still have the numbers on it.
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Hydro Ground Drive Belt Logo
146 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
