Question about Sony Handycam DCR-HC20 Mini DV Digital Camcorder
I get the message that i have dirty heads...it wont record, wont playback. i cannot find a head cleaner. can i manually clean the heads? and where are they? sony dcr hc20.. can you send a picture by chance....pls advise
  • 10,594 Answers
No, you should not clean video head manually, it will be damage/ broken easily.
MiniDV Video Head Cleaning Tape is available in amazon.com, click that link to view tape image and price info.
Thanks.
Posted on Nov 08, 2010
Camcorder won't record or playback,has distortion and low volume.Is it just real dirty?
Try to find a video cam ,,head cleaner,,at elonric s store ,,find online,,,try cleaning the heads down in there with alcohol and a q tip,,,also,,good luck,,but thats what it is just dirty,,
Dec 23, 2011 | Quasar VM-L152 Camcorder
Lines across tape while playing
It sounds like either the recording head of your camcorder was dirty when you made the recording, in which case you will need to clean the record head and re-record, or the playback head is dirty.
Either way, you should be able to solve the problem by using an 8mm head cleaner tape which you can buy from the same place you get your camcorder tapes.
Hope this helps,
Chris
Mar 05, 2011 | Sony (41989) Hi-8 Tape
Sony DCR- HC18E Camcorder
Hello there, you are not alone in this problem, I get 100's of other people write on this matter, the tape head cleaners sold are mostly a bit of non abrasive tape type stuff that would not clean a bit of dust off a shiny table, let alone a dirty camera head.
You need to get a proper head cleaning kit with the tape that looks like a white flat shoe lace, run that for 30 sec in camera in seconds your heads will be like new.
from
David
Jun 19, 2010 | Sony DCR-HC18E Mini DV Digital Camcorder
Camera gl1 is recording glitches on the playback
go at the electronic store, buy head cleaner and vcr head cleaning tip cleaner, then clean the head with this stuff manually... Head are fragile, so you might make it clean at your local vcr repair place...
Aug 07, 2009 | Sakar (CNGL2CHLENS) for Canon GL1, GL2,...
Sony vx2100...blue playback screen
in either case the head condition is bad.. pls inspect the tips on the head whether it is not damaged in the cleaning.inspect the drum hours also..
Nov 08, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Choppy recording and playback
If the heads become dirty, “NEED HEAD
CLEANING” appears during recording. During
playback, moreover, the following symptoms
appear.
≥Mosaic-like noise appears partially or the
sound is interrupted.
≥Black or blue mosaic-like horizontal stripes
appear.
When normal playback cannot be performed
even after the head cleaning
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Mar 27, 2008 | Panasonic PV-GS150 Mini DV Digital...
VCR Play Back is OK, but Recording produces Blue Screen on playback
If the heads are TOO dirty, a head cleaner will not help. If you are cinfident enough to open up the recorder, then they can be cleaned manually.
Disconnect the VCR from the mains.
Remove the screews from the side and back (if applicable) of the lid.
Remove the lid.
Look at the large drum (set at a slight angle) If you gently rotate the drum you will see 2 or 4 small sensors set into the drum.
Tear of a clean piece of A4 paper about 1inch square.
Hold between thumb and first finger and rub the centre of the paper against each sensor in turn. Make sure the edge of the paper does not catch the sensor.
After each sensor check the paper for dirt (black marks) and change paper if need be.
Try a recording / playback.
Repeat if necessary.
Nov 08, 2007 | Philips VR330 VHS VCR
JVC-GR-D371U
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 25, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Canon Gl2
Sep 18, 2007 | Canon GL2 Mini DV Digital Camcorder
Bad playback quality
Some possible cause of lines, noise or pixelation during playback are: 1. Dirty heads on the recording machine. If the heads were dirty at the time of recording, the dirty heads didn't record a strong enough signal on the tape. The damage is done for this tape and recovery is unlikely. Best advice here is to use only premium grade new tapes and keep your camcorder clean by occasionally running a cleaning tape. 2. Physical tape damage. Any distortion of the tape will result in mistracking and subsequent loss of data. 3. Built up oxide deposits or other debris in the guidepost corners can also result in tape edge damage. Keep your machine clean! 4. Improper tape storage - Even short term exposure to high temperatures over 130 deg f. can permanently damage the tape. The black cassette housing readily absorbs the sun's infrared rays and internal cassette temperatures can soar even if left in direct sunlight on just a warm day. It doesn't take much heat to slightly distort the plastic shell or ruin the tape contained within. * Try other tapes to ensure the problem lies within the tape and not the camcorder. * If the problem becomes apparent on all tapes, try a head cleaner. After cleaning the heads, the tapes may not play cleaner if the recording was done while the heads were dirty.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony Handycam  DCR-HC20 Mini DV Digital Camcorder Logo
155 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
