Question about Mitel 5220 IP Phone
Mitel IP5207 Hi there, We have given a client a number for which his clients call through to. When the call is picked up then a recording comes up saying press 1 for sales, press 2 for tech support etc. We have in the past programmed the numbers into the system and the numbers have now changed and we are unsure of how to change the settings. Can you help with steps of how to change this?? Thanks
You will need access via the web browser to the 3300 esm (database). Assuming you have a user log on ... select all forms alphabetical and select multi-level auto attendant. This will list all auto attendant boxes. High light the required one and click change. You can now change the option 1,2.. dialables
Posted on Jun 17, 2008
Code for the radio
Here you go - hope this helps -
- Turn your radio off.
- Turn key to the ON position. Do not start, just leave ignition in ON position.
- Press and hold the numbers 1 and 6 on your radio with one hand.
- Using your other hand, turn the radio on while keeping 1 and 6 pressed.
- Ten characters will appear on the screen, usually alphanumeric. Write down all the numbers you see.
- Email contact@torontohondaparts.com with Proof of ownership and the radio serial numbers.
or
- Drive to your nearest Honda or Acura dealer, provide proof of ownership, give them the numbers, and get your code.
or
You can call Client Services, but you will be required to provide your VIN number, radio serial number, as well as proof of ownership.
Acura Client Services: 1-800-328-2238
Honda America Client Services: 1-800-999-1009
Acura Canada Client Services: (888) 922-8729
Honda Canada Client Services: (888) 946-6329
May 05, 2016 | 2010 Honda Civic DX
When i try to open my mail box it shows application not found
Do you have an e-mail client installed? If it was, then something told the operating system to disassociate e-mails from that application. If you don't have an e-mail client installed, then pick one (Outlook, Thunderbird, old Navigator, and many others) and install it. But make sure the operating system associates your e-mail files with your new client. In Windows, the icon should change to something like an envelope. MacOS has something similar.
In Windows, you have two options to reestablish the link between e-mail files and the client.
#1. place your mouse over the e-mail file, then press the right mouse button (or which ever is NOT the normal selection button). Look for a drop down menu option that says "Open with ..." which should show you a list of installed applications. Your e-mail client should be in that list. If not, then click the "Browse" button (lower left section), and find your original e-mail client program.
#2. Start your e-mail client (should still be in the START-->All menu (or sub) somewhere). It will probably ask if you want it to become the default for all e-mails. If not, go to Preferences (usually under Tools, but might be under Edit), and (usually) Advanced tab/listing, and find something that says "make XXX (program name) the default...", and then save the new setting.
Good luck. (Since you didn't provide the operating system name or possible installed e-mail client)
Feb 19, 2011 | Computers & Internet
We have given our clients the DS-40 recorders. One of the clients is having a problem with the computer automatically detecting the voice files. It worked for two days, then stopped. We went to the client,...
When the recorder is connected to the computer,it should be recognized as a device.Have your client go to my computer and click on the drive that represents the recorder and open the files from there.Once the drivers are in place,nothing should change.
Sep 24, 2009 | Olympus DS-40 Digital Voice Recorder
Panda wont let me activate
http://www.pandasecurity.com/homeusers/support/troubleshooter/
Sep 18, 2009 | Panda Internet Security 2009 - 3 User for...
Client no.?
client no nothing but a no which is given to u while downloading the software along with that u will get other wise type some num and start using it
Feb 26, 2009 | Panda ClientShield for PC
Networking problem
From client pc
1.) click start
2.)click run
3.)in the box that opens, type cmd
4.)click ok button
A black box will appear
5.) type ipconfig
6.)press the enter key
Some lines of text will appear. One of these lines says IP Address please take note of the numbers to left of this. This is your Clients IP address
Now, you said your server IP address is 192.168.1.2 and lets say from the instructions I just gave you that you find your client IP address is 192.168.2.5. If your client pc does not have an IP address that begins with 192.168.1 it will not see your server. Also, If your client pc in question has an IP address the same as another one of your client pc's it will not see a server.
I suggest the following.
Change the IP address on your client pc following these steps
From the desktop of the client pc
1.)click start
2.)open control panel
3.)double click Network Connections
4.)right click Local Area Connection (it is possible to have more than one)
5.)left click properties
6.)a window will open, in the middle of this window is box you can scroll down in, scroll down and find TCP/IP
7.) left click on TCP/IP to highlight it
8.)once highlighted click the properties buttton just below the scroll box.
9.)another window will open
10.)click the dot next to Use the following IP Address
11.) enter the following
IP Address = 192.168.1.??? (replace question marks with a number of your choosing. Just dont go above 254 and don't use a number that you are using on your other pc's)
Subnet Mask = 255.255.255.0
Gateway = 192.168.1.2
12.) click ok
13.) click ok on any other open windows and reboot PC. then test connectivity.
PLEASE NOTE: There are alot of things that can change what you need to enter for the Gateway, Subnet Mask and IP address. Generally with simple networking it is what i have described above but if you have a Cable/DSL router for internet or wireless router then the numbers you must put in these fields changes. The directions I gave you above is assuming that you just want to get your pc talking to your server. It does not take into account any routers or advanced networking equipment. If you do have a router I will need more info and a somewhat different set of directions will apply.
Feb 19, 2009 | Microsoft Windows XP Professional
1. A software company has the following information about its cl
Shouldn't you be doing your own school homework?
Nov 18, 2008 | Computers & Internet
Mitel 5220 IP Phone Logo
93 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
