Question about Samsung HP-T5064 50 in. Plasma HDTV
Our samsung hp-T5064 lost power and now will not turn on at all. The day before it lost power and turned back on 3 times. The next day after a lound pop on lower right side it shut off for good. No power at all to front blue light.
  •  Brian
    Brian Mar 27, 2016
    It is possible it was the Fuse on the Panel its easy fix too
  • Samsung Master
  • 8,457 Answers
The tv power supply board is dead.That the board,where the power a/c plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Nov 08, 2010
I have a samsung hp-t5064 that show grainy picture with scanning horizontal lines. TV repairman came and looked around the back. Opened it up, replaced some boards, don't know which, I was not
You can also check for poor connections on ribbon cables etc.
Socketed Chips etc.
Modern TV's are more "Computer" than old fashioned TV. You could have memory problems, CPU or timing problems. Power supply problems.
Did the problem occur overnight. Like On/Off... or has it gradually gotten worse. All of these things can be clues. Does a slap on the back cause any glitches or changes to picture. If so then it could be an indicator of a physical problem like a poor connection.
Suggest getting a second tech's opinion before any replacement
Good Luck
Nov 27, 2014 | Samsung HP-T5064 50 in. Plasma HDTV
Hello. My sumsung HP-T5064 ( bought Jan, 2008 ) after working for few minutes starts clinking and turns off and on by itself. I started doing it few days after cable box has been installed ( wich...
The capacitor is bulging or puffing up more than the other capacitors beside it?Yes,replace it with a new capacitor with the same micro ferit and 5 to 10 higher voltages for a better heat resistance later.This suspicious capacitor is on the power supply board.That the board,where the power a/c cord plug into it.Yes,90-95% that ur tv problems.
Mar 28, 2011 | Samsung HP-T5064 50 in. Plasma HDTV
No picture have sound hp t5064
I have a samsung hp-t5064 with sound and no picture. I purchased a service manual and went through the check list of solving the problem. It tells you to remove 4 plugs from the SMPS board (cn810, cn809, cn808, cn807) and you should get dc voltages at test pin (Vs 207VDC) and test pin (Va 63VDC). If you do not get these voltages at these two pins you should replace the SMPS borad. My question is when all plugs are unpluged I get Vs 0VDC and Va 63VDC but when I start plugging in the plugs one by one nothing changes as far as voltages until I plug in the CN807 Main board and the voltages are at normal Vs207VDC and Va 63VDC. I am asuming the SMPS board is bad. Would I be correct?
Oct 23, 2010 | Samsung HP-T5064 50 in. Plasma HDTV
My samsung plasma 50" model HP-T5064 cant turn on. what could be the problem?
Make sure all of the cables are very tight on it. The button may actually be faulty, believe it or not. This is common on the model you are speaking of. If the remote won't work either, it is most likely a short.
Oct 06, 2010 | Samsung HP-T5064 50 in. Plasma HDTV
Clicks wont come on like circuit breaker going on
Ur power board is dead,know how to solders?Check the power board for Capacitors puff up or burst open replaced these capacitors.Or buy refurbish power board on Shopjimmy.com,Ebay.com.
Jan 16, 2010 | Samsung HP-T5064 50 in. Plasma HDTV
Tengo un tv samsung hp-t5064 , no quiere encender solo hace el intento , suenan los rileys del power suply, pls necesito ayuda mi mails es este,, Johel_vincent@hotmail.com byee
hola, chequeate los capacitores de la fuente de alimentacion es muy posible que esten reventados, solo destapas el televisor  con mucho cuidado, mira la fuente y veras de lo que te estoy hablando. si no tienes experiencia tecnica llama al tecnico.
buena suerte. caypianan@yahoo.com
May 19, 2009 | Samsung HP-T5064 50 in. Plasma HDTV
My samsung hp-t5064 keeps beeping with the light flashing and the screen won't turn on.
How long have you had it? Perhaps the bulb is burnt out. The average life of one is 3-4 years. These are easily replaced by a repair person, and the price will vary.
Apr 09, 2008 | Televison & Video
Samsung HP-T5064 50 in. Plasma HDTV Logo
280 people viewed this question
Jerry Greenberg
Jerry Greenberg
