Cannot recognize my flash drive - Computers & Internet
  • 27,725 Answers
Control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you could see a yellow question mark? right click to reinstall drivers or right click select properties general troubleshoot or driver to uninstall,disable,roll back driver
hope this helps
Posted on Nov 08, 2010
My Kingston flash drive 8gb doesnt get recognized by windows 7
Sometimes it comes with a software, you must have erased it.
Mar 12, 2014 | Kingston DataTraveler 101 G2
How to fix not recognized USB device?
USB device not recognize it means there is damage to hardware.
Possibilities and solutions
1. Cracked solder.
Solution: Open flash drive casings, heat the tin solder.
2. Resistor (R) broken
Solution: Open flash drive casings, replace the resistor.
Hopefully this information helps
Sep 23, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to fix usb flash drive not recognize
1. usually a flash drive that is not recognized is due to the electronics in the flash drive have failed.
A new drive is needed.
Jul 14, 2011 | Computers & Internet
VAIO desktop does not recognize Sandisk flash drive
Most probably you have a drive letter conflict? If so, right click "My computer" choose "Manage" and locate "Disk management" - here, in the middle lower panel, you should be able to find your usb-memory stick, right click it and assign it a drive letter that you're sure is not in use.
Jun 01, 2010 | Sony VAIO PCV-RS720G (027242658103) PC...
Usb flash memory not recognize and become hot temperature malfunctioned
At first attempt in plug in your usb flash memory didn't recognized you may plug out. And plug in again until it recognized you may see that theres an icon in the task bar at right below. Thanx
May 09, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Will not recognize the flash drive /unable to access Word files.
Try to connect the flash drive on the USB port located at the back of the tower. See if it works.
Jun 15, 2009 | SanDisk Memory Media
Flash Drive not recognized
hi, this may help a little. it sounds a bit like the drivers are not installed correctly.
i would go into computer management and c if you can remove it.
then reboot the machine
insurt the flash and it may then install the drivers again
but it does have to be removed in managment first.
if it was a rights issue it would also not allow you to install the drivers correctly but assuming the pc is yours then its not likely
sory if this doesnt help
May 07, 2009 | Electronics - Others
Unrecognized Flash Drive
Check out if the USB ports are 1.1 or 2.0
Your computer may use 1.1 and not see the newer 2.0
May 07, 2009 | Dell Dimension 8300 PC Desktop
Laptop does not recognize the flash-drive after it's pluged in.
there are some reasons why it does not work.
1- You do not have correct drivers for the flash drive, and the computer will not recognize the product. simply update the driver for the flash drive and it will work. To do this go to the flash drive companies site and search for product driver updates
2- You have damaged your flash drive to the point where windows will not even recognize it. To prove this, plug multiple usb devices into the port and test if they work, and test the flash drive in different ports in your laptop and other PCs. If it is still not working, then it is faulty and will not work. Purchase a new one if this is the case
Hope This Helps
Nov 18, 2008 | Computers & Internet
Unit does not recognize usb flash drive.
Use a 2GB or less compatible memory card - Sandisk is the best bet.
Feb 19, 2008 | Philips DVDR3575H/37
Computers & Internet Logo
David Payne
David Payne
