Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Mower tripped outlet breaker - wiring schematic available?
It appears that the mower shorted either in the winding or the solid state switch loacted on top of the motor. Is there an electrical wiring diagram available for the Black & Decker Lawn Hog 19"? Thanks, David
  • Tequila Dave Jun 16, 2008
    If you can't offer a solution without a paid assistance plan, just say so!
  • jenncatron Jul 14, 2008
    I've already replaced the switch once but list the part #. Need the diagram for the MM895 model with the parts #. Please send via email to Jenncatron@charter.net
I had a MM875 go out after some months' service -- it actually went out with a bit of a bang. The problem was a shorted circuit; the weather was hot and the "solid state switch" on top of the motor shorted out. This part wasn't a switch but a bridge rectifier. The original part was specified a bit close to its actual working limits so I bought another (from Radio Shack, no less) that was higher rating -- something like 30 amps at 200 or 400 volts. ITs worked for years.
If it is a bridge then it will have two terminals labelled '~' and one each with the '+' and '-'. The plus and minus go to the motor (keep those connections the same as the original) and the others go to the supply wires.
Posted on Jul 15, 2008
    Champion:
  • 313 Answers
Electrical diagram available i send it to your email just give your email add.
Posted on Jun 16, 2008
  • mr aicnelav Jun 16, 2008
    can i send to by fax. just give to me the fax #
  • mr aicnelav Jun 19, 2008
    i am not asking for your paid assistance. thats all
Why does the breaker keep tripping on this 2.0hp exhaust fan motor
Christopher, motors starter/capacitor could be faulty, wire circuit/breaker could be insufficient. motor could be faulty or wired incorrectly. Have motor checked out and ensure you are wiring correctly.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LEESON Electric Motor Trouble Shooting Chart
Motor trips breaker Why
http://www.garagejournal.com/forum/showthread.php?t=256105
Jun 03, 2016 | Heating & Cooling
Lawn mower batter charger blows circuit breaker
I'd try plugging it into another outlet first, then try turning off any other appliances that might be on that same circuit. If it continues to trip the breaker, I'd take it to the small engine shop.
hope this helps
Apr 19, 2014 | Toro Garden
My lawn mower just stopped working. I was mowing along and it just stopped. It is an electric Black and decker. I was mowing regular grass, nothing complex. It was working fine before that. It is very new...
Open your circuit breaker box. Locate the breaker that has tripped. Turn the breaker OFF (it is in a mid position). Then turn it back ON. Before you do that you need to ask yourself, why did the circuit breaker trip? They trip because of an overload of current. Is something else running on that same circuit, say for example an electric heater or something similar? Depending on the rating of that circuit breaker (15 or 20 amps) you may be drawing too much current. Look for anything else that could be running on the same circuit (only so many outlets can be put on the same circuit). Disconnect or turn off all other devices. Attempt to operate your mower again. If the breaker trips again, then there is something wrong with your mower (electrical short?).
Nov 29, 2017 | Electric Lawn Mower
When I pull the red lever on the electic mower, the lawnmower will not start and the GFI to my house is being popped?
just for a quick test -- run power to the mower using a different outlet,,, GFI outlets are well known for having a bad trip circuit in them,, they go bad all the time. so if your mower does in fact work on a different outlet with no problems then the issue is your GFI outlet and you will need to replace it.
if the mower is infact tripping the next circuit then the problem is with the mower motor windings or a short at the switch or two wires shorting out. check all wires and make sure connections are good.
c...
Jan 30, 2011 | Black & Decker Black Decker 18" Lawnhog...
Replaced switch but circuit breaker trips on start up ! Mowermm600
Your circuit breaker will trip because of two main reasons:
  • Electrical power point circuit is overloaded (too many appliances active on the same power point circuit)
  • Power Lawn mower has become unsafe as your active live is able to reach your earth connection (e.g. short-circuit). Make sure that you have correctly reconnect ALL your power leads wires (check that the Active and Neutral wires have not been transpose). With power off/device unplug, use a multimeter on resistance range and verify that your active lead pin is not showing a reading against the Earth (middle) pin when the mower switch is turn on or off! There should not be any resistance reading between the Earth and Neutral (opposite pin to Active) pins either!
Hope it helps.
Aug 01, 2010 | Black & Decker Garden
Switch stuck in trip mode
The reason why the breaker stays tripped is a result of a direct short. Unplug every electrical device plugged into an outlet in both rooms and try the breaker. If it stays on, individually start plugging in each device until the breaker trips, that is the defective device. If the breaker stays tripped, start checking wall outlets for short circuits with an ohm meter. If you did not find a short, check your hard wired lamps and appliances for shorts. If you did not find any shorts the only other problem is a shorted pair of wires in the wall or ceiling. You will need to disconnect any hard wired lamps and appliances and check for shorts between individual pairs of hot (black) and neutral (white) then hot and ground. I have a short circuit finder, but you do not need one because the technology is not perfect and you may have to manually check for shorts with a meter anyway which never lies.
Jun 25, 2010 | Square D Co. HOM130 Circuit Breaker
My story is the same. I have an MM600, replaced switch, and still trips breaker in variety of configurations. I have tried both of the relevant configs recommended on this site, and no luck. Is there...
As you know a breaker tripping is a result of a direct short inside the electrical circuity of your mower.
That short can be anywhere from just beyond the switch all the was down to the winding in the motor.
There are 2 switches Item 3 and Item 7 of this link:
http://www.toolpartsdirect.com/cgi-bin/noframes.cgi/blackdecker/MM600_TYPE_1
Places for a short are the power wire from the switch to the motor connection. (Item 28 of link)
A broken motor brush where the carbon brush has broken off and the metal from the spring is now touching wither the motor chassis or across multiple segments of the armature.
Check items 46, 47, 48, 48 this link for damage:
Also check Item 80 Brush of the above link (picture below link
http://www.toolpartsdirect.com/cgi-bin/parttools.cgi/242273-00
A bearing in the motor can have failed allowing the armature Item 65 of link to drag on the stator item 70 of link and cause a stator short where the armature damaged the stator winding.
The above items are all things that can cause your problem. It will take a multi-meter and some resistance checks of the circuit to isolate exactly where the short is.
I would connect the meter across the 2 power cord terminals i.e unplugged and simulate mower use then start disconnecting wires one at a time working my way backward from the motor to see when the short disappeared. If the short is in the motor... then we are back to all of the times above except the cord and switches. The all have to be isolated and checked out.
Kelly
May 02, 2010 | Black & Decker 19" Electric Lawnhog...
Cut cord with mower by accident. connected new cord but no dice. is there a reset button?
Did you check the outlet, you might have tripped the breaker,
or you fried the outlet.
Plug the mower into a outlet that you tested with a lamp or something
so your sure there is power at the outlet, and at the end of the extension cord, if there is power to both but not the mower, contact the company because there is no reset button.
What ever outlet you use to plug this thing into, you should have a ground fault outlet installed, for two reasons, safety for you, and protect the mower.
Feb 05, 2010 | Black & Decker 19" Electric Lawnhog...
Electric lawn mower repeatedly trips house circuit breaker
The breaker is tripping because there is a short in the mower electrical circuit -- most likely in the motor winding -- it overheated.
If you have a multimeter measure the resistance (ohms) of the motor winding by putting the meter probes on the two flat prongs of the power cord with the mower switch on. If you get near zero ohms, the winding is shorted -- motor "burned up".
Using the multimeter again, check for continuity between the round ground pin on the power cord and each of the two flat prongs. If you get continuity on either of these, there is a short to the mower chassis. This can probably be corrected without much expense.
My bet is on the motor winding being shorted.
Charlie
Aug 20, 2009 | Craftsman Garden
Why does electric mower shut off my breaker when switch is turned on?
you are probably overloading a busy circuit and the mower is pulling enough to trip breaker....try another source that is hopefully more than 15 amp rated and not running the rest of the house. otherwise mower motor could be failing and shorting or drawing too much amps(electrical current) overloading and tripping breakers
Jun 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
648 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
