Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My Cabrio won't stop attempting to drain even when the power is turned off. The only thing that stops it, is unplugging the unit. I have had it unplugged for a couple of hours and when I plugged it back in, it immediately started again. I tried running it through a cycle, but that didn't help either. I just had the unit serviced for another problem that cost me over $300 and would like to be able to at least try to remedy this problem myself. Any help would be much appreciated! Thank you :)
  • marisanicole Nov 08, 2010
    Thank You!! Much appreciated!
  • marisanicole Nov 09, 2010
    Thanks for the help! I ended up calling Whirlpool after reading about some serious defects in this particular washer. They are actually sending someone out to fix it free of charge! Woo Hoo! Thanks again though...much appreciated :)
  • Whirlpool Master
  • 43,501 Answers
The relay that runs the draining is stuck... this relay will be in the main circuit board... so replacing the main circuit board is the way to fix this problem...
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Nov 08, 2010
Carrier 58STA/STX furnace false starts even when off or temperature set lower than current.
Is it possible the drain is plugged? The newer furnaces have a moisture drain and will shut down if they are blocked., shutting them down and restarting will reset fault, but will come right back if not fixed.
Dec 24, 2014 | Carrier Heating & Cooling
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
My Haier Commercial Cool A/C says "STOP" as an error message and won't turn on.
Bring it outside or to your tub and tip it on a 45 degree angle some water will drip out...once a puddle has come out of this thing it will work again but u will need to properly drain it eventually unless u wanna tip it and drain it every few days. But thats what ive been doing with mine...
Jun 11, 2012 | Heating & Cooling
Hi, I just purchased this used. It was working fine for one day, but now it won't turn on. Can u help? Haier CPN12XH9 12000 BTU Portable Air
If the water collection tank is full, it will not turn ON. Since you said the unit worked fine for one day and now it won't turn ON, more than likely, that's the problem. After draining the tank, the unit should reset itself and turn ON like it should.
The drain plug is on the rear of the unit, just above floor level. You can either drain it into a low sided pan or bowl that's capable of holding up yo a quart of water. O r roll the unit to a floor drain or outside to drain it. If you choose to drain it into a pan, turn the unit OFF & unplug it, before draining it.
I hope this helped you and thanks for choosing FixYa
Jul 25, 2011 | Haier CPN12XH9 Portable Air Conditioner
I was washing sheets and "sd" appeared. Now I had to unplug it to get it to stop running.
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Oct 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the "OL" mean on the cabrio washer? it doesn't seem to be spinning out the water either
my cabrio is having problems too it won't go through a full wash cycle ,when it's time to drain it stop.I cleared the drains and even took the drum out and found some socks,then I started it today and it worked till the drain cycle .I also had it run a diagnostic and stopped on C8. I hate laundermatts
Aug 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Jensen VM9410 - Stopped Operating All Of A Sudden
Sound like to me you got a problem with the capcitor inside the unit, if its under warrenty it will need to be serviced. If its not I ould be checking capcitors inside to make sure there not bulging leaking or otherwisen ot wroking correctly.
Jun 24, 2009 | Jensen VM9410 Car DVD Player
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
271 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
