Question about Samsung HT-Q100 System
The unit does not tur on it has a circle with a line....
The unit does not turn on.  You press de power button an a circle with a line appears in de screen and the unit turns off again,,,
  • x-emma_x Jan 12, 2009
    We have the same problem, we try to turn it on, but the same symbol appears across the screen. Can anyone help us with this problem?
  • x-emma_x Jan 17, 2009
    We have the same problem and its very annoying as the equipment seems to be useless. Does anyone know how to resolve this?
    cheers
    Wouild be great to have it working again
This symbol means,that main supply doesn't work.In my HT-Q100 there was no +31,5Volts for the
audio amplifier.Dual diode SF3006PT(super fast,400V,30A) failed.It seemed to be O.K. by meter,but
make breakdown,when voltage appears.Greetings,Wlodek.
Posted on Oct 02, 2008
Dont have a solution, but the same problem, if u turn it on a couple times with remote or the power switch, it will turn on...
Posted on Aug 24, 2008
I have the same problem! what does this mean?
Posted on Jun 24, 2008
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
Sylvania LC 155sl8p Will not turn on
its a problem with ignition panel try to change ut its not an easy task though.
Aug 23, 2008 | Televison & Video
I start the machine and after 5 seconds give me the 116-324 error code
Thats called an exception error. One of 2 things. Either it needs a complete software upload, or the network control board, called the ESS board has failed.
You can try these steps
This step will delete any print or copy job that is in process, and then perform a reboot.
To execute: simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This step will delete all pending print or copy jobs in the job queue, and then perform a reboot.
To execute: simultaneously press and hold the 6, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This step will delete all pending print or copy jobs in the IOT job queue (DC 3535: does not delete any job data stored in the Network Controller), initializes the IOT HDD (refer to ADJ 9.8 for details), and will and then perform a reboot. All customer data on the HDD will be deleted.
To execute: simultaneously press and hold the 4, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This routine will set all IOT ESS NVM values to default. Do not attempt this procedure unless there is a known-good Machine Settings floppy, an accurate Configuration Report and/or other data that will enable you to reload the correct NVM values for this machine.
This step will initialize the IOT ESS NVM (SYS-System and SYS-User) and then perform a reboot.
To execute: simultaneously press and hold the 3, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
The last one IOT ESS NVM will clear all your netrowk settings.
May 07, 2011 | Xerox WorkCentre M-24 Color Copier
Pls help me: xerox workcentre 24 code: 116-372
Ugh.. That is a formatter software issue. Try these resets
arrwup.gif Log Initialization
arrwup.gif Spool Initialization
arrwup.gif HDD Initialization
arrwup.gif ESS NVM Initialization caution.gif CAUTION
If these do not work the system software needs reloaded or the ESS network board needs to be replaced.
Mar 12, 2011 | Xerox WorkCentre M-24 Color Copier
I have canon mp145 printer when power on the error e5 display what is the problem, how to solve.
Hi.. E5 means the cartridge is not installed or the cartridge is not recognized. Here are some possible solutions that will work on your printer.
First step
1. Remove the cartridge and clean the copper surface contact by a moistened cloth. Then return back the cartridge properly, you will hear a snapping sound to tell you its properly seated.
Reset the Printer to clear the error. This is done after refilling the cartridge with ink.
1. Disconnect the printer's power outlet.
2. Press and Hold Power button while connecting the power outlet back.
3. While holding the Power button, Press the Reset button twice (red circle with inverted triangle)
4. Release the power button.. wait until the printer shown number 0
5. Press + to change the value from 0 to 1.
6. when this value is 1, press the color button; this will light up two leds, one is for plain paper and the another for photo paper . at this point is feed the printer with paper.
7. Press the Power button
8. Press the Color button
9. Press the Reset button. The canon will print some stripped lines and some numbers and letters (all black if colored ink is empty). When you print this sheet the value in the display returns to zero.
10. Open the printer cover (not the scanner cover) and remove the cartridges.
11. With the printer stll open, disconnect the power outlet.
12. Close the lid
13. Re-connect the printer to the power outlet and turn on the printer.
14. Open the lid, return the cartridge and wait for the printer until it fully initialize.
Try printing again.
IF another error appears, do this reset.
1. While the errors appear in your printer...Press and Hold the Reset button (red circle with inverted triangle) and wait until it self restart.
2. Release the Reset button when the printer restart.
Take note of this as you will use this everytime you refill the canon cartridge.
Please comeback and rate this answer.
Thank you for using Fixya.
Aug 18, 2010 | Office Equipment & Supplies
There are buttons on the front of the monitor. Why
The first button is the E-power button for the Auto preset function.With it you can select presets like text, standard, graphics etc. depending on your use.
When you select any button the options are displayed at the bottom of the window. These tell you what button to press to select the next option.
For example press --menu-- > -- > -- menu , to adjust the horizontal and vertical position.
To turn off the monitor you must press and hold the --circle with the line -- button for a couple of seconds.
Jan 27, 2009 | Acer X193W LCD Monitor
Forgot how to use my Insignia MP3 player.
Power up:
If the player is laying flat with the screen facing left, you will see a large circle button and two buttons above the circle. The button on left above the circle is the power button.
To start playing music:
Press the button in the middle of the large circle with a small triangle facing the right (the play button)
To stop music:
Pressing the same button mentioned above will pause the music while pressing the power button I first mentioned will turn off the unit completely and stop the music as well.
Nov 30, 2008 | Insignia NS-DV2G MP3 Player
Curtis region error
This region code solution as per
http://www.dvdcodes.net/newCodesAZ/codesD/DigixMedia/DigixMediaHT-1056A.php
Power up the player and open the tray. With the tray open, hit the setup button and then 0000 and then the "Up" button.
On the Setup menu, go to Version and hit enter. Go to region code and change the number to 0 for region free and hit setup again to save.
Or
Press the SETUP button. The setup menu appears.
Press ZERO on the remote control four times - 0000
Press the CHAPTER FORWARD button - the one on the bottom right of the remote control unit that looks like a double arrow with a bar.
A new menu item appears, "Version". There is a REGION option you can select, and this can be set to zero "0" for all regions. Once you see its set to region 0, press SETUP to exit, close the tray and power off. When you power up again, its region free. RCE disks work fine in this unit.
To recap - open the tray, press setup, press 0-0-0-0, press Chapter Forward, select Version, choose 0 for region free, press setup again.
Or
1) Turn on the System
2) Open the tray
3) Press "setup" button
4) Press four times the number "8": 8888
5) Press the "Next Chapter" button (>>|)
6) Appear a menu called "Setup Factory"
7) Select with the cursor movement key "Region All"
8) Press "setup" button to save de changes.
Aug 17, 2008 | Digix HT1056A DVD
DVD8723UK
this region code solution as per
Or
Or
2) Open the tray
Jul 11, 2008 | Digix HT1056A DVD
Samsung HT-Q100 System Logo
592 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
