Question about Microsoft Windows 98 for PC
How to install windows 98se os at sata hdd - Microsoft Windows 98 for PC
  • 449 Answers
Windows 98 does not support SATA.
It may be possible to use an IDE to SATA converter to make the SATA drive look like an IDE drive.
Something like this:
http://www.satacables.com/html/sata_to_ide_adapter.html
Then the SATA drive will look like an ordinary IDE drive to the hardware.
Posted on Apr 12, 2011
After installing another HDD from another Packard Bell computer, the computer would not boot. This computer I recieved from a mate and I dont believe windows was removed, as I have tryed and failed...
if it is a sata Hdd you have to reinstall it ..cause the sata driver on the os ..is from the other computer ..or go to bios ..and in the drives feature..look for a function called AHCI and disable it ...
after that will boot with the windows installed..but you will have to reinstall the windows anyway ..and if it is a raid sata you need to insert a diskette with the sata driver during ..or disable the ahci function ..for to let it see the HDD ..if not all it will say is that the hdd was not found..or if you try to boot with this windows on it .will say that the media is missing ..
beter to set the defaults in the bios ..and after that look for that funstion to be disabled..or disable the raid sata ..and enable teh sata Ide..instead..it is the same thing ..and will pick up the sata hdd with no sweat ..
Aug 30, 2010 | Packard Bell iMedia SL 9553 (P660401806)...
Vista Crashed does not recover (Can't install XP or 98SE either)
if you want to recover vista then download vista recovery disk here is the link
http://rapidshare.com/files/145731926/WVRD_www.warezspark.com.part1.rar
http://rapidshare.com/files/145698726/WVRD_www.warezspark.com.part2.rar
password : www.warezspark.com
burn the ISO disc and boot from cd rom and get it repair it automatically.
if you want to installed windows XP or 98;the reason why your hard disk could not be detected is your hard drive is SATA. disable any sata setting in your BIOS IDE configuration( if setting is not available then download SATA driver and Nlite ;make a bootable windows xp disc  with SATA driver pre installed .
this is solve your problem
here is the link for lastet SATA driver
http://download.cnet.com/SATA-Driver-Intel-Ver-7-0-0-1020-zip/3000-2122_4-162224.html
here si the link for lastest nlite software
http://home.midmaine.com/~nlite/nlite/nLite-1.4.9.1.installer.exe
regarding how to make a bootable cd with nlite with sata driver check out this link
http://www.windowsreference.com/free-utilities/nlite-slipstream-servicepackshotfixespatches-create-bootable-windows-cd/
let me know if it's helpful to you
Dec 09, 2009 | HP Pavilion dv6000z Notebook
Sata hdd windows dell recovery cd will partition install windows
The system is originally designed to use IDE HDD, make sure the necessary chages for Sata HDD are made in the BIOS, next make sure the Recovery disc is fine without any scratches. You can order a new Windows OEM recovery disc by calling Dell tech support (1-800-624-9896-US) and try installing the OS. The disc will cost you not more than $12.
Nov 15, 2009 | Dell Dimension 4700 PC Desktop
Unable to run and install Windows on my computer
try to format your hard disk first.. if you required any drivers.. try below link..
http://etech.maiila.com
May 20, 2009 | Microsoft Windows XP Professional SP2
Problem with sata HDD probably?
check the bios settings first. if you can see your sata hdd and dvd rom drive then you can install it with no problem. or else try to replace the cables of the hdd if the hdd is not showing up in the bios.
also check that the hdd is set to master drive and dvd also set to master as they are on different connections.
Apr 21, 2009 | EliteGroup ECS 915-A Intel 915GV Chipset...
Winxp instalation
hi,
There is not way to install a windows xp os without SATA drivers. If you don't want to use the floppy disk to make the os recognize the HDD, you can integrate the drivers in the Windows Xp installation Cd, using software like Nlite.
Another solution is to use a IDE HDD, the old kind with the 80 wire ribbon cable.
Mar 31, 2009 | VIA ASUS A7V600X MB AMD KT600/ 400FSB/...
I have a asus K8S-MX i want to connect SATA HDD
To enable sata port press Delete Key when computer Starts. U will get BIOS menu. On there the Main settings window the second last option is to enable sata option. If u want to install widows OS (XP,2000, Server edition) **** Driver CD and go to RAID folder there u get a driver ( shown as Floppy drive Image). Incerte Floppy in drive and click that icon. And click Extract. Then incert the OS CD. On starting of instalition u will get a option press F6 to install Raid Disk. Press F6. On Bitween instalition u will get a option to install this Raid. ( With out this RAID u cant install XP or Other vartions of windows in ur sata hard drive)
Mar 31, 2009 | ASUS K8S-MX Motherboard
I cant install vista OS on this MBD , by sata HDD
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
I m not able to install win xp sp2 on my compaq notebook
windows xp cant detect ur hdd bcoz its SATA hdd.
Solutions:
1. Install vista instead of XP
2. You need to disable this SATA feature in BIOS to install OS.
SATA disable steps.
1. Restart the computer and start tapping F10 key.
2. Choose System Configuration tab.
3. Disable SATA native support.
4. Save and Exit the BIOS by pressing F10 key
Aug 21, 2008 | HP Compaq Presario V5000Z Notebook
Microsoft Windows 98 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
