Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Sound isn't working on tv but works from dvd - Sony BRAVIA KDL-40S2010 40 in. LCD Television
  • 95 Answers
Press the menu button on remote control then Audio Video set up then select Audio then TV Speaker.
Posted on Nov 10, 2010
Sound is working on the tv but the picture isn't
Is there a dvd or cd that came with it. I think you need to install the driver of the TV to your computer for them to work well.
David
Jul 26, 2013 | Televison & Video
Why isn't my dvd working
Check the input selection at the tV. Set it to DVD. Power ON the DVD player too, while selecting the inputs to TV.
May 11, 2012 | NEC 46" 1366x768 LCD wtuner Black 46 in....
Sound isn't working on my pioneer 5071 pdp
Does the set have sound with a DVD etc. directly connected to one of the audio/video inputs this set has?
Apr 30, 2012 | Pioneer PDP-5071HD 50 in. Plasma HDTV
I have 2 good qaulity heybrook speakers and have tried everything to connect them properly such that both play sound when the tv / dvd is on. Both speakers work perfectly one at a time and both work...
You're guessing. That is exactly the wrong thing to do. Get the manual.
http://www.retrevo.com/support/Kenwood-VR-205-Receivers-manual/id/480ci174/t/2/
"[D]vd 6 channel input" is for a 6-channel analog input as the name implies. I doubt you even have a source that HAS 6 analog channel outputs.
Speakers are OUTPUTS of the amplifers' speaker posts. Any one can work ANYwhere.
And that bi-wire capability, IF the speakers have it - pretend it isn't there.
Jul 31, 2011 | Kenwood VR-205 Receiver
I have a JVC HD 52g787, the sound works but no picture, The tv comes on, but the blue light just blinks, then cuts off, I have sound no picture
The problem is usually from the power or the Y sustain at the left or right side of the display when one of the large capacitor or heat sync on the capacitor even the flat power cable connection it to a main power board needs to be checked too, if the fuses on the board are blown it will need to be replaced
But after replacingthe fuses and the capacitors and still no solution,youwill need to replace the all board ..
You can also trouble shoot first before going to the board of the TV..
How to Troubleshoot an LCD With Sound But No Picture
It can be overwhelmingly frustrating when an electronic device as expensive as an LCD television set starts having problems. Luckily many of these problems are easily troubleshot. While being able to hear sound coming from your LCD television but seeing no picture may seem serious on the surface, fixing the problem involves checking a few different settings to make sure everything is set properly
Instructions
Check the video connection of any devices plugged into the LCD television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
Hope it helped ..
Jul 17, 2011 | JVC HD-52G886 52" Rear Projection HDTV
My dvd player and tv blink on and off . When the dvd is unplugged the tv is ok? Whats the problem?
It sounds like your DVD player is the problem, not the TV. Check all the connections from the DVD to the TV and the power cord to the DVD and make sure they are all connected correctly and tightly. If that doesn't help try replacing the cables connecting the DVD to the TV. After that try using a different kind of connection (switch from S-Video to composite or component, or vice versa). If none of that works, the DVD player may be bad. Most of the time it isn't worth having it looked at for repair.
May 22, 2011 | Televison & Video
I have a a LG model 42LG30 UD. My issue is the IF doesn't appear to be working. I've 3 different remotes. the one the came with the tv. a remote from a LG dvd player and a comcast remote. the remotes work...
If your TV is still under warranty I would recommend sending it in. It sounds like the receiver on the TV is malfunctioning which isn't something that can generally be fixed or replaced by your local electronics store. Your best course of action would be to send the TV back to the manufacturer with a detailed list of what is happening. Most major retail outlets can assist you in getting your TV fixed or replaced through the manufacturer if you purchased the TV through them.
May 04, 2011 | LG 42LG30 42 in. LCD HDTV
Cannot connect my PS3 to Panasonic TV via HDMI, my PS3 will connect to other HD TVs using HDMI but not Panasonic
Does your TV work on VGA, it maybe worthwhile getting a HDMI---VGA lead and try that as it sounds like your TV isn't working, and you've tried the obvious. Do any other HDMI devices work on your TV, like DVD HD/SAT?
Apr 22, 2011 | Televison & Video
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
37 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
