Question about Gateway GT5220 PC Desktop
When I turn My Computer on all that happens is I hear the fans on the back running really loud and a light on the back flashes green. The light on the on button on front doesn't even come on, but I know that the computer is on because of the loud fan sound and the light on the back. Anybody know what is wrong?
  • Gateway Master
  • 27,725 Answers
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Nov 08, 2010
  • 21 Answers
Just go inside your tower after you unplug the main power cord from the back of your tower first then unplug the big main connector from *********** board very carefully there a clip in the center of it that you have to squeeze in order to get the plug to pull out of the main mother board ok then leave it unplug from the board go and plug the main power plug cord back into your power supply at the back of the tower now carefully go inside your computer without touching anything else and plug the big wide connector plug back the main mother board now press the Power button on in the front of your tower and it should boot if not play around with unplugin and plug it back in on the main mother board if still no bootup screen then you either have and onboard video problem or your bios chip is fries or it could be one of your memories sticks in the mother board not functioning properly but first try the plug deal first ok then your memory if still nothing then try a different video card and if that does not do it try unplugging your hard drive and see if that is whats cousing it if so then you need a hard drive bud and if thats not the problem then your bios chip or processor known as the CPU would be fried then ok but im giving you guides to walk through the Simplest things first the step by step way bud so thats it then you can figure it out couse it will light up again or perhaps sorry your kid was vacuuming and so on you can also try to take the power supply out the the power cord plugs into take that out and take the little screws out of it and then look inside of towards the back of the circuit panel where the power cord goes and you should see a fuse link inside now some can be removed and replaced with another 5amp fuse and some are soidered in place the ones that are able to pop out you can get a replacement at raidio shack or some electronic place ok bu the ones that don't come out well just do like this take a piece of chicken wire and twirl it around the fuse making sure both ends of the fuse is making contact then secure it and put the power supply back together again putting all the little screws back in place again put it back in place in to your tower and then plug the power cord back in to it and see if that lights you up in the front of the tower and see if that boots it up if so it great to go now this will last you a long time with out any problems but just make sure you have apower surge protector plugged into it as well and you wont need to worry about the power supply in your system or if you still worry them use 2 power surge protectors and that will do the trick have fun and enjoy and i hope that all my info to you has been helpful and great of helping you out bud well ps don't forget to say thanks
Posted on Feb 17, 2012
Won't start up little green light flashing on back
the green light flashing on the backside is your internetconnection.
about the computer wan't start i should check the PSU do the fan movs any light on the motherboard.if not is the electric cord firmly and tight in place.if the fans runs and lights on the got no picture proberly brooken videocard.
Apr 11, 2013 | Computers & Internet
Flashing green lightbulb
Do you hear the fans running? Do you hear the hard drive spinning? Did anything ever appear on the monitor?
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 09, 2012 | Acer Veriton Computers & Internet
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
Compaq Presario SR2150NX doesn't turn on. Front panel green light turns on but nothing else happens (no fans, no boot, no noise, nothing) Please advice
On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
Apr 14, 2010 | HP Compaq Presario SR2150NX PC Desktop
please remove and replug your system RAM. its happened due to some fault in system RAM. after remove and replug the RAM it will be sure working fine.
thansk & regards
Feb 08, 2010 | HP dc7800 Business Desktop USDT Alternate...
My infocus PL70+ powers up but there's no picture. after I plug in, the amber light come on so I hit the power button, green LED light flashes, fan kicks in, green LED remains steady after flashing for a...
if you hear chirping or a loud buzzing, you have a bad colorwheel. the lamp won't turn on if the colorwheel doesn't spin as fast as it needs to. if you don't hear anything like that, you need a new power supply. the lamp striking takes a lot of power, and if the power supply can't handle it, it shuts off. you can get the part from an infocus service center and replace it yourself, or send it to them for repair. either way, try av solutions in ny. they're really good.
Jan 12, 2010 | InFocus LP70+ Multimedia Projector
KDF60XBR950 doesnt turn is on just flashes green
There is no less than two Cooling Fans on the right side. Either one of them could cause the problem. The one that turns slow or stops turning quickly is the one that is probably causing the problem.
I hope this helps,
Sky Assoc
Sep 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
No pic...humming noice on 62'' toshiba dlp
was the lamp blown if it was blown you could be hearing the ballast
if the lamp was not blown and the new one did not fix it the red light indicates the door there is a little switch when you put the door back on if you look at it it may need to be adjusted so it will connect with the door if that is not it you could have a fan that is not turn if it is making a real loud constant humming noise while it trying to fire the lamp you probably have a bad color wheel
Nov 19, 2008 | Toshiba 62HM95 62" HDTV
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Gateway GT5220 PC Desktop Logo
290 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
