When trying to execute a print job the printer keeps insisting that there is a paper jam. I have done my best to insure the printer is cleared of any obstructions short of trying to pull it apart. Is it possible the printer is being tricked into thinking it has a paper jam? Is there some other way to correct this at the user level? The unit is a MP160.
  • 1,218 Answers
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Posted on Nov 08, 2010
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
When turned on keeps wanting to feed paper then early paper jam apperrs. how do i fix this
Might have a print job it is trying to print. Clear the print queue and or cancel the print job at the printer. where is jamming could it be the fuser the hot part? if so might have to have it replaced.
Nov 16, 2015 | Xante ScreenWriter (Refurbished) Laser...
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Cant send nor receive faxes
dear sir,kindly follow the below instructions
Instructions
  1. Ensure that all cables are securely connected. First, make sure that the printer cable connecting your computer to your printer is connected securely. Then, make sure that the power cord is inserted into a wall outlet. Try your print job again after you have ensured that all cables are properly connected.
  2. Clear a paper jam if your printer is not responding or you are receiving a "Paper Jam" error message on your printer. To clear a jam, first open the rear output door by pushing down on the two levers on each side of the door. Opening the rear door simply makes it easier to clear a jam. Open the top cover on the front of the printer by pressing the release button on the right side of the printer. Locate the paper jam and use two hands to gently remove the paper jam. Try your print, scan, fax or copy job again.
  3. Clear stored or saved faxes if you are having trouble sending or receiving faxes. Old faxes may be stuck in the fax queue, which may be causing the printer to not respond. To remove stored faxes, press the "Menu" button on the printer and select "Fax Functions." Then select "Clear Saved Faxes." Wait for the queue to clear and try your fax job again.
  4. Remove paper from the automatic document feeder (ADF) input tray if your scan job is coming out crooked. The ADF input tray can only hold up to 50 sheets at a time. If there are more than 50 sheets in the input tray, the output may appear skewed. Try your scan job again after removing the paper.
  5. Adjust your computer monitor's display settings if your scanned image is not an accurate representation of the original image. This can be done in the "Control Panel" in Windows. Set the settings to the highest possible resolution and try your scan job again.
  6. Perform a power cycle on your printer if the previous steps were unsuccessful. To do this, turn off your printer, then unplug it from the wall. Wait a few minutes and plug the printer back in. Try your print, scan, fax or copy job again.
take care..thank you
Oct 04, 2010 | HP LaserJet 2840 Printer
Printer will not print and insists that there is a paper jam but there is no paper jam...there was but I cleared it ..how can I fix this?
You did not _completely_ clear it -- the sensors that detect a jam are still detecting a jam.
Turn the printer off.
Turn the printer on, and see if it still reports the problem.
Otherwise, take the printer to a qualified technician.
Nov 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
How do i clear a paper jam
The Lexmark Printer you are having a very sensitive printer.
Normally this tyoe of Printers are very very slow in Printing job.
Comparing with other laserjet used.
If the Laptop / Printer are under warranrty, the Service engineer
can rectifity the printer jamming.
Solutins :
Make the Printer - Monthly service compulsory.
Use only good quality paper in the Lexmark Printer.
Do not pull the paper through hand, when the print out is coming.
Regards
Jul 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
First print job, first page jams on output area
Please note that paper absorve humidity, try to keep you equipment in a dry place.
When the paper is that condition, and while passing thru the hot image drum, the sheet hedges sometimes curves and jams...
Sorry for my bad english !
Jun 23, 2009 | Xerox 4150V_P Printer
Paper jam
try to check it again maybe there is a small piece left inside the printer or you can try to restart your computer and turn off your printer then during the restart process practically the BIOS booting start your printer.
Jun 19, 2009 | Canon PIXMA MP470 All-in-One Printer
Printer keeps saying paper jam even after all doors are cleared of paper jam. Reset didn't work.
Dear, there is very minor mechanical fault but it is better to visit the repair shop to fix it.
Best regards
May 25, 2009 | HP Photosmart C6100 All-In-One Printer
87 people viewed this question
jasbo
jasbo
