Question about Toshiba Regza 52XV645U LCD TV
I have the Toshiba 52xv65u LCD TV. I have n DVI -> HDMI cable. As the manual says I used HDMI port 1 and tried both taking the audio cables and put them in the component 1 audio jacks and lso tried the Y RCA cable and put them in the HDM1 input audio jack and still no sound. If switch my input to component 1, then I have audio, but if I switch to HDMI 1 then I have picture but no audio.
3dmaster
  • 183 Answers
SOURCE: No picture when on TV/Sat mode on receiver
Dear Customer,
Try another tv to this bales,
than try another cables with this your tv ,this way you got problem & find out solution on which you can spend time for ,
than try some channels to sets up your tv configuration,
or must not be imported from another country cause its not similar to your country's signal identification,
THNX
Posted on May 18, 2008
IFIXALL
  • 868 Answers
SOURCE: no audio brand new toshiba 42xv540u
speakers are muted.
Posted on Jun 10, 2008
SOURCE: No sound with HDMI cable and Xbox 360
FROM THE TOSHIBA MENU, (FIRST MAKE SURE YOU ARE SET TO
THE HDMI PORT THAT THE XBOX IS PLUGGED INTO) THEN SELECT
HDMI SETTINGS, UNPLUG HDMI CABLE FROM THE TOSHIBA TV (LCD
FLAT, MINE IS A 42") WAIT FOR THE SETTINGS TO HIGHLIGHT OR NOT
BE GRAYED OUT, THEN TURN OFF THE THREE SETTINGS, FOR COLOR
AND LIP-SYNC., SCROLL DOWN AND PRESS THE RESET BUTTON,
WAIT FOR MESSAGE TO APPEAR. TURN OFF THE TV AND PLUG IN THE XBOX.
TURN EVERY THING BACK ON. SEE IF IT WORKS.
NOT ALL CABLES ARE THE SAME AND NOT ALL TVS ARE THE SAME.
READ THE TV OWNERS MANUAL CAREFULLY, (RTFM), I FOUND A NOTE ABOUT
THESE SETTING ON THE SPECIFICATIONS PAGE.
Posted on Jul 13, 2009
SOURCE: the left 25% to 33% of my screen is blurry when it
My Toshibla is a 52LX177 LCD and it's doing the same thing on the right side. This TV is only 2 yrs old. Anyone have a solution?
Posted on May 30, 2010
SOURCE: Tv with out coax inputs.
you can run it through a cable box or vcr that has a coax input and rca output.
Posted on Dec 17, 2010
How can i connect my hp pavillion s5610y to my bravia tv
This is a bit complicated since there is no HDMI output capability to the PC, only VGA and DVI. First, check to see if the Bravia has one of its HDMI ports listed as DVI capable. If it does, it should have accompanying audio jacks (red/white) for it. What you would need to get is two different cables for interface. The first is a DVI-to HDMI cable to run from the PC DVI port to the Bravia DVI-compatible HDMI port. You cannot run the DVI to a regular HDMI port because if you do you will get only picture and no sound. DVI outputs, unlike HDMI outputs, do not carry the audio signal. A DVI-compatible HDMI port on a TV set will connect the video from the HDMI port and the audio from the reserved audio port accompanying it. The second cable you need will be a mini stereo audio plug to RCA jacks. This will connect between the PC audio out (green), and the DVI audio plugs on the set. See pictures for cables below
Once you have this done, selecting the appropriate HDMI port on the set should result in audio and video getting to the unit. If you only need the video (you are going to use the PC speakers), then you don't need the audio cable and you can use any HDMI port, but you cannot control the volume using the TV set remote. You would need to use the PC volume settings. (Just as an afterthought if the set has no DVI-compatible HDMI port).
Jan 26, 2016 | HP Computers & Internet
Where is my cable output on my Philips TV 32PF7321D/37. How do I get cable on my TV I cannot find a cable output! please help
your output cable is in the back of your t.v. there is a color designated on its hole then you have to buy a a cable in any electronic shop like components cable or hdmi cable try to read the back panel of your tv
Mar 10, 2011 | Philips 32PF7421D 32 in. LCD HDTV
Cant connect laptop to tv
Hey
If you're using a newer laptop look for either a HDMI (looks like elongated USB port) port or a DVI (a female port similar to a serial port but wider. Usually a white) port on the back/sides of your laptop.
If it's an older one, Look for an SD port (Resembles a PS/2 port which you plug the mouse in).
That being said, your TV must be able to pair with one of the above ports.
HDMI -> HDMI (using a HDMI cable)
DVI -> DVI
SD cable usually splits into three, Red, Yellow and White pins. Two for the LEFT and RIGHT audio channel and the other is for the video.
You might also be able to find converters from one format to another.
Hope this helps.
Cheers!
Dec 19, 2010 | Computers & Internet
How do I connect my Toshiba LCD television to my computer using hdmi
HDMI carries both "audio" and "video" signals, while DVI carries only "video" signals.
Does your computer have a HDMI-output port, or separate DVI-video and stereo-audio ports?
If the former, then one HMDI-to-HDMI cable will make all the necessary conections.
If the latter, you'll need a cable to connect "line-out" from your computer's sound-card to the left/right RCA-jacks stereo-inputs, and you'll need a DVI-to-DVI cable to transmit the "video" signals.
Oct 22, 2010 | Toshiba Computers & Internet
Just trying to connect the HDMI using a cox cable box. Cannot find the connection on the tv.... help
This TV doesn't have an HDMI port. You can use a DVI to HDMI adapter or the component video. (I assume the Cox cable has component video out.) You will need to connect an audio cable as well. There are 2 DVI-HDCP ports.
I wish that I could be of more help.
Oct 01, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Hp plasma ID5226N can get external audio input when in HDMI 2. I have a DVI to HDMI cable from my computer to TV, & manual says to hook the audio to the input jacks, but no sound comes out. I can use...
DVI cables are usually HDMI compatible. The downside is that DVI usually doesn't carry any audio. Your computer may need a specific audio card to transmit audio/video data from your DVI output to the HDMI input on the TV. You can find one at your local computer store and ask if it is compatible with your computer
I hope this helps...good luck
Jun 23, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
This unit does not have a HDMI cable in put . Is there a cable adapter to accomplish this?
You do have a DVI input for this Dell W3000 so to connect to a box that has HDMI you will need a HDMI to DVI cable. When you connect to a cable/DVD or satellite box via HDMI/DVI you will have to run separate connectors for audio as this setup wont pass sound to the TV. Please take a moment to rate my answer. Thanks...
Here is a link to look at the cable type you will need.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10231&cs_id=1023104&p_id=2661&seq=1&format=2
Nov 24, 2009 | Dell W3000 30 in. HD-Ready LCD Television
Sharp Aquos LC-32GH5 and MacBook problem, HELP! I've recently bought a 32" Aquos and want to use it with my MacBook as a secondary monitor and screen for movies, etc... I bought all...
it sound like you did the right thing . The problem is the mac output for sound is bad or the TV input sound is bad.
try input a mp3 radio to the TV verify TV is working.
put an earphone to the mac to verify the mac out sound is working .
if both are working just tool around a little and you will get it. good luck
Aug 18, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
HELP WITH CNECTION
Only if you've got an HDMI output on your computer. Some computers with higher quality video cards, or just newer ones will have a DVI output for a monitor. You can get a DVI to HDMI cable that will then be able to connect the two.
As others have said, if you have a video card with DVI output, you can get the video to the TV using a DVI to HDMI cable.
But no one mentioned anything about audio. DVI can not carry audio, so you'll need to send audio from the computer to the TV (or receiver). Some TVs have audio inputs associated to one (or more) HDMI ports for use with devices that have DVI, but not HDMI. My Sharp LCD has two HDMI ports, one with separate audio inputs, one without.
Sep 27, 2008 | Computers & Internet
Toshiba Regza 52XV645U LCD TV Logo
51 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
