Question about Sony KV-36FS100 36" TV
KV 36FS10 Yes, I re-set but still no sound or picture, just Stend By light (red) 5 blinks, pause, 5 blinks. How much does it usually cost to replace that board you mentioned? TV is not too new, but real good picture, so I hope I don't need to buy a new TV! Thank you!
  • 84 Answers
To have someone come to the house to repair you are looking at usually $75 service call plus $100 labor plus parts. If the circuit board needs to replaced it could be up to $200 to $300 for the board if it is still available, sony is going flat panel these days and parts for your set are fazing out. If you take it to a shop you will save money on pickup and delivery and make it easier for the tech to diagnose which should save you money.
Posted on Jun 22, 2008
Turn on tv no picture no sound standby light starts green changes to flashing red
the number of red light flashes indicate where the fault lies...sony error codes are easy enough to find if you google the model with the number of flashes.hope this helps somewhat as you dont say how many blinks!!
regards,steve.
ps.line output transformer failure rates are quite high on these sets,usually resulting in two red blinks-pause-two red blinks-pause etc...
Sep 28, 2010 | Sony FD Trinitron WEGA KV-28CS70 28" TV
Sony KV-34xbr800 standby light flahes all the
Flashing standby light is an error code that is specific, there would be pause of 3 seconds in flashing, so count pause to pause and let me know that how many times red standby light is blinking to diagnose problem.
Thanks.
Jan 11, 2010 | Sony Televison & Video
Sony KV 36FS10 led light flases, no picture, sound is ok.
unplugg from wall and surge leave for 2 hours. if problems still there. your power supply is probably done. repair is usually pretty reasonable.
Jun 04, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Intermittent picture on Sony KV-36FS10 TV
This is possibly an indication that the picrute tube is starting to fail. To confirm this, open up the back and carefully turn up the screen control just a bit. This is the upper control on the flyback transformer (part with large red wire coming out the top). Turn it only slightly clockwise. If the picture remains on, this suggests that the tuvbe is starting to fail and you will have given yourself enough time to find a replacement. Please note that this is not a permanent fix.
Keep us posted.
Dan
Jul 12, 2008 | Sony KV-36FS100 36" TV
KV-36FS10 - No picture or sound Stand By Light blinks
5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
Jun 15, 2008 | Sony KV-36FS100 36" TV
SONY KV-27FS20 TV does not start
Only 3 things bad Flyback transfomer,bad picture tube ,shorted hori output transistor. more then likely you have a bad picture tube,ive already throwed over 20 sets out due to bad tubes.
May 04, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv won't turn on-red blinking light
This is the most common death mode for TV's. The high voltage is acting up. You set is not quite 10 years old right? Can be fixed, but involves replacing the Flyback transformer which is not cheap. It is a toss-up as to whether it is worth putting the $200 or so it will cost to fix into a set that has limited expected lifetime.
Dec 31, 2007 | Sony KV-27FV16 TV
Sony KV-32FS120 No picture, No sounds, 5 red blinks after turned on
your problem is in power supply section in your tv. if it is ok check for h/output section. call skilled tech to fix it it is not a major problem.
Sep 28, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
Video blinking - sound works fine (KV-36FS10)
Sounds like you have 1999/2000 model Sony with a CRT that is showing its age. This would be a tech fix but, most likely not worth the repair cost. It probably flashes slower when the set is cold and gets more rapid when it warms up.
Feb 20, 2007 | Sony KV-36FS100 36" TV
Sony KV-36FS100 36" TV Logo
106 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
