Question about Kenmore 64602 Electric Dryer
Condensation inside empty clothes dryer
The room my dryer is in is pretty cold in the summer, with the a/c coming in on the floor just a few feet from the dryer. The dryer works fine, but when it is empty for a few hours, the inside becomes wet from condensation. The dryer vents directly out through the brick exterior wall into the open carport. Do I have to leave the dryer open when it is not being used to prevent this problem?
  • pccgroup Aug 30, 2008
    Codensation and sitting water inside empty clothes dryer. Dryer upstair vent lead to roof ease. Its been a very rainy Florida summer. This problem is new after 5 years of use. Could rain be entering in?
    Genius:
  • 1,122 Answers
Yes,also if you have a front load washer you do the same thing,hope this helps-mike
Posted on Jun 16, 2008
Why is it out of balance?
One of the feet is not in proper contact with the floor. All the feet are adjustable in height. The washing machine must be checked level, front to back and side to side using a long spirit level. All feet must be in equal loading contact with floor.
Regarding loading, a small load can often be worse as all the clothes end up on one side. Run a cycle empty and see what happens? Run a cycle full of towels, 3/4 fill the drum and see hat happens?
Finally, is the machine new? Did you remove the locking bar inside. If this is fixed in place there is no dampening from the floating springs and shock absorbers. I did that once after a move!
Jun 30, 2015 | Admiral Washing Machines
I have just lit a coal fire for the first time in the living room, all is OK ecept when I went into the bedroom (2 floors above) I could smell smoke quite badly Any advice?
The chimney needs to be 3 feet taller than the highest point of the house . If you are running the clothes dryer, bathroom vent fan, or exaust hood in kitchen it makes a vacum in the house that can draw smoke into the house down the chimmney . I think when you burn wood or coal in a house it is pretty hard not to be able to smell it. Our house and clothes do not smell like smoke any more since we stopped burning wood.
Feb 02, 2011 | Heating & Cooling
Zanussi tc7103w condenser dryer-water tank light keeps coming on when tank is empty or nearly empty-have found small plastic float and spring on floor behind dryer-where do they fit?
I had this problem. If you look at the valve on the plastic water tank, you will see that those parts are the same. They fit inside the tumble dryer to shut off the water from flowing onto the floor when the water tank is removed. The white hollow cylinders in the tumble dryer and the water tank push each other open. If you study the water valve on the tank you will see how it is put together. It is all held in place by a little 9mm O ring at the back of the valve. The ring gets tired after a while and pops off. The valve then falls apart and you find the cylinder and spring on the floor and the O ring still inside the dryer. I bought an O ring kit and reassembled the valve inside the dryer using a new ring. You will have to pull the dryer out, turn it upside down and remove the floor to do this
Sep 23, 2010 | Dryers
Why would a dryer be leaking water at the bottom?
look for a restricted vent . and a cold floor or room . this would cause condensation and would leak from inside / causing leakage on floor in or around the dryer .. hope this helps . pls leave feed back .. mm
Dec 12, 2009 | LG DLE3777 Electric Dryer
LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
Did you repair this problem? If yes, how?
Thank you.
Dec 11, 2009 | LG Dryers
Condensation is forming on the walls when I use my clothes dryer
Simpson may have a kit available for accomplishing this. Also, your dryer may have several optional ways of venting.
Mar 27, 2017 | Dryers
Burning smell coming from the dryer!
You have a serious clog somewhere in your dryer exhaust ventilation. I would recommend you STOP using the dryer immediately and clean both the interior and all the vent ducting from where it exits the dryer to where it exits the home. the burning is coming from lint build up in and around the heating element and its beginning to smolder. This is a potential fire hazard and may end up causing the heating circuits to fail. The condensation comes from the the inability of the hot air (which is mixed with humidity from your clothing) condensating inside the vent duct. The lint starts to collect and get wet to the point of saturation. Then it begins to cause water to form and leak out of the ducting and on to your floor. You do not want this condensation inside the dryer where the heating circuits are. The following link will provide with some guidance for future reference:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Pay particular attention the paragraph where it discusses proper dryer ventilation. I hope this helps you. Let me know if I can be of further assistance.
Sep 28, 2008 | GE DBSR453EBWW Electric Dryer
Our washer dryer is leaking water after the drying cycle. Everything seems to be fine just after the cycle has finished but in the morning the floor is covered in water. It seems to be coming from the...
Hi. I take it that the machine is of the condenser - dryer type?
In these machines, during the drying cycle, warm air is circulated inside the drum and a cold plate is either splashed with cold water or has cold water running through it, causing moisture from the clothes to condense on the cold plate - just like moisture in a room condenses on a cold window pane on cold days.
If your machine is continuing to fill up slowly with water after it has been switched off, then I would suspect the cold water inlet valve isn't closing properly. This is likely due to a build up of grit inside the valve.
If you turn off the cold water supply you will be able to remove the cold supply pipe from the machine and - hopefully - see some of the grit on the filter gauze. The grit possibly causing your problem is already inside the elcetically controlled inlet valve, so it may need to be removed and cleaned or replaced.
You should be able to check if this is the problem by just turning off the cold water supply to the machine. No supply means no water can get into the machine, so it shouldn't fill up overnight.
Before removing the filter down at the bottom of the machine you could turn the machine on to a spin or pump out cycle - that way you shouldn't need wellington boots when you removed the filter :-)
Hope this helps a bit. If not, add a comment and I will try to help you further. D.
Jul 09, 2008 | Hoover Washing Machines
Condenser Dryer Still Filling Room With Moisture
all dryers produce moisture. thats what hapens when you heat wet cloths up. the dryers job is to remove the moisture to dry. thats how the automai]tic cycles work by deteting the moisture in the exhaust. i will say there is nothing wrong with your dryer. only thing i dont understand is the containers of water?
May 13, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Kenmore 64602 Electric Dryer Logo
1,391 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
