Question about Dryers
I have Model # LGR8648LW0, the belt broke on the idler pulley and I need to know if the new belt goes through the idler pulley or on top of the idler pulley? Thank you
    President:
  • 1,554 Answers
The belt goes through the pulley like this:
Posted on Nov 08, 2010
What is the belt diagram from the deck to the motor for a mower?
1st, Unplug the Dryer from the Power Supply.
You will need the Exact recommended Replacement "Idler Pulley".
With the Belt Ribs Facing Toward the Dryer Drum, position the belt on the tell tale Ring Mark on the Drum letting the Belt Hang Down below the Drum.
Place The New Idler Pulley into the Slots on the Inside Dryer Bottom located near the Motor Mounted Pulley.
(Face The Idler Pulley Toward The Motor Mounted Pulley)
(Hold the Idler Pulley in place in the slots)
Take the "Hanging Belt" & run the Whole Loop "UNDER" the Idler Pulley & then
Attach the "Belt Loop" "AROUND" The Motor Mounted Pulley.
That should do it.
Put the rest of the Dryer Back Together...Done!
Good Luck,
Vinnie
Sep 20, 2014 | Dryers
I have a Kenmore 70 Series Dryer and the belt broke. I ahve since ordered the replacement belt, but am uncertain how to replace it. Is there somewhere I can view a diagram of my dryer so I know where the...
pulley fits into slots in bottom of dryer near motor pulley. idler pulley will be to the left of motor pulley looking at it from the front. loop belt thru idler and place around motor pulley.
Jun 26, 2010 | Dryers
I don't know how to get the belt on the small pulley
If the design of this unit is the water pump is in the front directly below the motor, you have to install one of the pump plastic legs between the belt. when installing new belt. There are torex screws holding the pump onto the motor. This is assuming your belt burnt off or broke and you are replacing the belt. The small idler pulley can be worked on by running the belt on the big pulley when reinstalling the motor Try not to stretch the spring for the idler pulley,
hope this helps
May 27, 2010 | Amana DLW330RA Top Load Washer
My Kenmore 80 series gas dryer will turn on but won't spin
Hi, Sounds like the belt broke.
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
There should be instructions that came with the belt. I will try and explain how this goes on. The idler pulley fits in a slot right in front of the motor. Put the belt over the drum with ribs touching drum. Now, thread the belt through the idler pulley wheel and bracket and set the belt on the motor pulley. The ribs should rest in the grooves on the motor pulley.
I hope this helps you. If I can assist you further, please let me know. Please rate me performance so that others as well as myself will know how I am doing.
Thanks
Vic
Feb 10, 2010 | Kenmore Dryers
Just need to now how the drive belt goes. My belt
I don't have a diagram but it shouldn't be to hard. You will have to drop the deck. Then when installing the new belt remember to always place the inside of the belt (V) into the pulleys and the outside of the belt (flat side) up against the larger idler pulley. When you have the belt on properly it should be snug. If you have excessive play you need to try a different routing2.gif around the idler.
Good luck and let me know if this helps.
Thanks
roundo4
Sep 07, 2009 | Cub Cadet Street Sign- tractor lawn riding...
I have a 1995 murray lawntractor model#42816B.The deck belt broke and need a routing diagram on which the way the belt goes on.Bought new idler and belt.The belt length is 35x75a.Is this the correct size?
Have you tried going to www.murray.com and then find a dealer. Call them and ask if it is right belt. If you have the old belt there should be number stamped on it. If you have the number and you can't find a belt try a mower repair shop and they can cross ref it and get new number if it has been changed.
Then when you put the new belt on make sure you have the right belt and then it should be fairly easy to route the belt if you put the back of the belt (flat side) up against the larger in height idler pulleys and the smaller (v) in the smaller pulleys. The belt should be snug when on properly.
Thanks
roundo4
Jul 31, 2009 | Garden
The belt is broken. How do I install a new belt.
Hi, UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
Thanks
Vic
May 23, 2009 | Dryers
My Whirlpool dryer belt broke.
You should be able to reuse the idler pulley unless it is physically broken.
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side and loop it around the motor pulley.
Let me know if you need more assistance.
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
Replacing main belt on chevy truck 4.8 engine
remove the belt to ac compressor.take your serpentine belt go around crank pulley goes around power steering pump goes around alternator and the tensioner on the far left. the water pump on the out side and the top idler pulley out side. the belt drives them from the out side. then you put your ac compressor belt back on.
Mar 17, 2009 | 2001 Chevrolet Silverado 1500
Changing the belt on Frigidaire GLER642
ok here we go facing the drier take a putty knife come about 1-2 inches from the edge and push in should feel a spring clip depress in lift one side then the other look inside on the front panel and remove the two 5/16 inch screws grasp the front and snap it off give it a good tug then your ready to go be sure to un plug the drier and slide it out from the wall so you can tilt the top back before removing the front don't forget my 4 boxes and make sure the idler pulley is on the belt the the belt goes around the drum around the motor pulley then you pull the idler pulley back and put the belt on top of the idler pulley let it back against the belt to keep the belt tight you do not have to remove the drum for this can all be done from the front
Jan 10, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
83 people viewed this question
Top Dryers Experts
