Question about Black & Decker AS100 Iron
Iron black & decker cat no. as185-2 type 1 is not working - no heat, water is leaking through the holes for steeming. where can i exchange it?
SOURCE: iron D2000C type 1 black decker
the folowing reason for not working 1. the connection may be lose 2. the heating coil is gone 3. inside connection may be lose.
Posted on Sep 30, 2007
geokohler
  • 304 Answers
SOURCE: We have a fairly new
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it
good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up
the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
clyde2j2
  • 137 Answers
SOURCE: I have a Black and Decker First Impressions
It's a possibility that you iron steam making elements are caked with lime and possibly the steam holes as well.
Purchase some "Lime Away" and dilute it 50/50 and pour it into your steam iron (drain all the old water out first and leave the iron unpluged) let sit for an hour or so and drain out, fill it again with clear water shake and drain out do this a couple of time then turn on the steam and see if it works properly, use the first time on an old towel to be sure all the chemical has been rinced out. Good Luck.
Posted on Feb 28, 2009
electrodynam
  • 35 Answers
SOURCE: the black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Posted on Mar 16, 2009
  • 43 Answers
SOURCE: the cord gets hot
You have a short somewhere in the cord. As this is a risk for fire, the Iron should either be taken for repair or replaced.
Posted on Aug 03, 2009
My Black & Decker D2030 Iron fell on the floor and it is leaking water from the tank - can it be repaired?
if the crack is visible and isn't on a part that gets heated then super glue will work 4 you , plus if you cant access the crack a separate 99 cent squirt bottle kept handy will still allow you to use the iron ,just squirt and swipe the iron across the surface ,steam will be made if irons hot enough
Jun 03, 2016 | Irons
I require a manual for an iron I just purchased yesterday. Cat. No.AS210 Tyype1 Black @ Decker. I am 76 years old and over the years used many of your products. I just want to be sure, and a manual
http://www.managemylife.com/mmh/owner_manuals/70113/Black-Decker-Iron-AS200-AS210-AS225-AS250798
Copy and paste the above info. and wait a few seconds for the web page to fully load. The manual will be ready to download once the page is fully loaded.
Jan 31, 2012 | Irons
Stopped heating
I work for Black & Decker. Any part that someone is telling you to purchase for that iron isn't from Black & Decker. Their irons are no designed to be repaired. If the iron is no longer heating, it needs to be replaced. Please call our customer service department at 800-231-9786 so that we may determine your warranty status.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 20, 2009 | Black & Decker D2030 Iron
Describe your Black & Decker
Please call Black & Decker customer service at 800-231-9786 so that we may determine your warranty status. Mon - Fri. 8:30 to 6:00 EST.
Jul 07, 2009 | Black & Decker AS150 Iron
I have a Black and Decker First Impressions (about 2 yrs old). When on steam it always spits out large puddles of water on the clothes as I'm ironing. It seems to come from the top or bottom part of the...
Feb 28, 2009 | Black & Decker D2030 Iron
Water leaks out of iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Nov 23, 2008 | Black & Decker Steam Xpress AS250 Iron...
New iron, stopped heating and leaked water
heatman101
May 22, 2008 | Black & Decker D2030 Iron
Iron D2000C type 1 black decker
Sep 17, 2007 | Black & Decker D2030 Iron
Black & Decker AS100 Iron Logo
188 people viewed this question
Top Black & Decker Irons Experts
tfelton3
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
