I just turned my computer back on and it says disk boot error and wont get past that. Ant help would be great!
  • 1,179 Answers
Your Windows installation on your computer has become corrupted, you may want to try to recover your personal information, a technician will be able to do this. It might be possible to repair windows by way of the windows disk. However it mostly comes down to formatting the hard drive using file system NTFS and reinstalling your Windows operating system.
All the best, thumbs up!
damnor01
Posted on Nov 08, 2010
I have Acer 1200 Aspire. When I turn it on, it won't proceed past the initial window. It says boot failure.
It almost sounds like your primary boot disk is incorrectly selected in the BIOS. On older machines, the primary disk on the primary cable had to be the boot disk, but nowadays almost any device can be selected as boot disk. Check your BIOS setting and ensure that the hard disk partition that you have Windows installed on is selected as the first boot device. Otherwise, the system may be looking in the wrong place for the OS and giving the boot error.
Jan 07, 2012 | Acer Aspire X1200-B1601A PC Desktop
I have an ACER laptop. It has crashed several times recently and now when I power it on the message BOOTMGR is missing appears on the screen. I am instructed to press Ctrl.Alt.Delete and when I do the same...
I am glad to HELP YOU!
This is one of the worst errors that can appear for a Windows operating system I've experienced myself few times in the past...
It means your computer doesn't know which way to boot, what to load and where from because a tiny file - called BOOT.INI - was altered.
Happily there is a solution for that: reinstalling the hole operating system.
If you have a RESCUE PARTITION you are saved; if you have the INSTALLATION DISK(S) you are also saved...
Or - if you have a usual operating system installed - just insert the installation disk and boot from it.
But if you have data that you want to be saved from your faulted computer there's one way to do it prior re-installing the system: take out the hard drive, connect it to another computer and save what you ant to save.
Then attach it back and start the re-installation procedure.
GOOD LUCK!
______________
Windows Tips
Apr 24, 2011 | Acer Computers & Internet
My evo610c would not start and failed the HDD self test. I installed a new hard drive. It now passes the HDD self test, but will not go past the screen that says "not-system disk, replace and try again"....
Put the Windows CD disk into the CD-drive.
Turn the computer off.
Turn the computer on, and immediately look for a message like "press F12 to change boot order", or something like that. Tell the computer to first try to boot from the CD-drive. When it boots, the installation process will start.
Jun 23, 2010 | Compaq Evo N610C Notebook
Did I fry my ASUS A7V8X-MX motherboard? I bought an old computer(with this moboard) that was working. I opened it and put in my old HD to slave it. Rebooted to get into the BIOS (just to check things...
I do not think that this problem is to do with your Motherboard. If you had fried your Motherboard, you would not see anything when you started the computer, you especially wouldn't be able to get in to the BIOS if your Motherboard was damaged because the BIOS is accessed straight off the Motherboard itself. You will notice that if you take out all the Hard Disks in your computer, you will still be able to access the BIOS.
This problem is probably due to a corrupt Hard Disk. Maybe you set the old Hard Disk to the Master or whilst moving your computer you damaged the other Hard Disk. This problem is known as the Windows Reset Loop, your computer will not get past a certain point in the start-up process and will then restart itself and do the same thing over and over again.
This could also be caused by a problem in your BIOS, when you did the CMOS reset, it would have probably knocked out all of the stored data. When your computer is starting up, you must go in to the BIOS and check which drive the bios is set to boot off. Even though your Slave Hard Disk is set as a Slave, you can still set the computer to boot off this drive, and if this drive is corrupted it will not boot, it will go in to the Windows Reset Loop.
If the problem still persists, i recommend that you remove the old Hard Disk which you have put in and try and boot off the Master as a single drive. If this still doesn't work, set your other Hard Disk as the Master and remove the other drive and try boot off that one.
If you would like further assistance with this problem, pleas do not hesitate to contact me on Skype (Skype Username: fixya-support)
Thank you for using FixYa! Have a great New Year and please remember to rate this solution.
Warm regards,
BearWeb
Jan 01, 2010 | ASUS A7V8X-MX (90-M7A780-G0EAY)...
Blue screen when trying to boot windows
you have the "blue screen of death" i had this same problem and the easiest way to fix it is to take the hard drive out and put it into another computer back up all files you want to keep on it have a boot disk for the right windows operating system on it use the boot disk with it once it is back in the right computer and then put all the files you saved back on it. the blue screen of death occurs when there is a registry error on your computer. if the blue screen of death appears again then you need a new computer.
Jun 30, 2009 | EliteGroup nForce3-A Motherboard
Thinkpad t20 dvd error
Unfortunately only few people know your problems solution but I'm happy that i can help you.
Its simply a problem of setting HDD ( Hard Disk Drive ) type which can be changed using BIOS setup. I hope your laptop must have SATA but if its not working on current settings then please change it to another options available.
Surely, your system will get booted after that and furthermore you can re-install your windows again...
Rate this solution if it was helpful to you.
With Regards,
Shyny
May 29, 2009 | IBM ThinkPad T20 2647 Notebook
Toshiba Satellite 1800 Disk Drive Problem
There's an issue with the way yout laptop is booting, either its set to the incorrect boot device or windows cant properly access the hard disk. Take it into a PC repair centre.
May 17, 2009 | Toshiba Satellite 1800-S253 Notebook
Hi all was ok in till i removed my hard drie affter i shut down the system and turn it off i removedthe hard drive now system will not boot back up it will power on but wont boot up ive unpluged everything...
hi im josh in cebu phils.may i help you? friend try to do this things. first i suggest to change new ide or sata cable.if still persist.try the following:
Boot order: Traditionally, a computer is set to boot first from the floppy drive, and then from the main hard drive (Drive C). This means that the computer will check the floppy drive first for boot files. If there is no disk in the floppy drive, the computer will then go to the hard drive to look for boot files. That is why if you leave a non-bootable floppy disk in the drive and try to boot up, you'll get an error message such as "NTLDR is missing. Press any key to restart." or "Non-system disk or disk error." This can be changed to pretty much any order, including CD and DVD drives. It is useful when installing Windows on a new or just-formatted computer to set the computer to boot first from a CD-ROM drive, and then insert the Windows installation CD-ROM into that drive. This saves you from having to use boot floppies that might or might not come with the Windows CD-ROM. Good luck.
Mar 05, 2009 | EliteGroup MB ECS A770M-A 770 SB600 AM2+...
Boot pc problem
You can solve this by going into the bios setup & changing the boot order. Make the dvd/cd drive 1st in boot line then hdd. This should allow you to boot up from the windows xp disc. Hope this helps & please rate this solution fixya. Thanks.
Feb 04, 2009 | HP Compaq EVO D510 Intel Desktop PC -...
Computers & Internet Logo
18 people viewed this question
Alun Cox
David Payne
David Payne
