Question about Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z error code
Hello, I am hoping the someone can provide some guidance about how to resolve the following error message / code.
  • budredfan Sep 13, 2008
    I have the same code F 01 coming up. My manual says there is excess water in the machine but there isn't. I've tried to fix it per my manual but it doesn't work. I've put a call into the repair man.
    Did you ever get yours fixed?
    Problem Solver:
I need a clear code for maytag epic z front load washer
code f-o1 is coming up
says intall new ccu, I did but still the same
do I need to clear the code if so how.
please tell me.
Posted on Jun 19, 2008
Maytag dryer epic z flashes error F1
bad thermister part number 8577274 and it's around 30 dollars.go here and see the part
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MED9700SQ0/3048/0151200/W0802068/00003?blt=06&prst=&shdMod= number 42 on the diagram.hope this helps.also there should be a tech sheet with info and error codes on it.don't loose this paper in case you ever have to call someone in to service it
Jan 06, 2013 | Maytag MED9700S Electric Dryer
My Maytag Epic Z front load washer stops working and flashes F-21 Error code. When I press "cancel" it then continues but doesn't go through the rinse cycle nor the spin cycle. When it's...
Hello, welcome to FixYa.
Based on your information posted I understand you have the Maytag Epic washer, correct ? The F21 error on these built by Whirlpool means an excessive drain time or excessive suds was detected as you may or may not already know.
If you follow the link to my solution to this error designed specifically for "do-it-yourselfers" you should be fixed up in no time. (It's much quicker for me than pasting or retyping the complete solution several hundred times, that's how common this is).
This will also instruct how to unlock the unit...though once the water is gone it likely will unlock without issue, if it is at all an issue. Many times it is, but it's just a by-product of not draining correctly.
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for choosing FixYa. Please take a moment to rate the info provided here and a testimony on your experience here at FixYa today is appreciated.
Let me know if anything isn't clear or you need further assistance, Good luck.
Regards,
Macmarkus :)
Sep 26, 2011 | Maytag EPICz 3.7 Cu. Ft.
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * EpicĀ® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
Mani have an error coming on my epic maytag washer it flashes the letter F and then the letters DL please help
Hello the error code F with a DL is usually a clogged or kink in the drain line.
Unplug washer and remove drain hose and clean it out.
Check area where Line connects to washer closley for any debris and remove it.
May 08, 2011 | Maytag EPIC MFW9700S Front Load Washer
Hello, I'm getting and Error Code F24, does anyone
The "F24" error code is a heat sensor error code. The following link explains the error code in detail and the steps to correct it:
http://www.fixya.com/support/r1976126-f24_error_code_whirlpool_duet_kenmore
In many cases, the connector plug on the NTC sensor wiggles loose and causes the error code. Check the NTC connection first to make sure it is tight and making good contact. This may save you a service call and/or replacement parts. Make sure you UNPLUG the washer before servicing anything inside the unit.
A replacement NTC module (if required) can be purchased at searspartsdirect.com for about $10. The part number is 8181705. Refer to the parts illustrations under the "Tub and Basket Parts" heading for item 26 as a pictoral reference to assist you in locating the sensor on your washer.
If you have any questions, please let me know. I hope this helps you.
Dec 08, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Oct 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Torn Bellow on Maytag Epic Z
The following link explains step-by-step how to replace the door bellow:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I know the link I provided is for a Whirpool Duet. The newer model Maytags (such as yours) are manufactured by Whirlpool now and have Whirpool parts. These instructions should work for you.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Aug 13, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic giving F11 error code!
ths.gardenweb.com/forums/load/.../msg1012004912002.html
Jun 22, 2009 | Maytag EPIC MFW9700S Front Load Washer
Error code "F".
The "F" code indicates an electrical problem, possibly a faulting part. Maytag does not offer any guidance on this. FYI - Could be a bad control board
Apr 18, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z frontloader Error Code F20 Help Please!!!
i also have a magtag epic z &f 24 error code is on my washer. i don't know what to do.
Jul 01, 2008 | Maytag Washing Machines
Maytag EPIC MFW9700S Front Load Washer Logo
1,297 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
