Question about Bassett Cottage 3-in-1 Crib
I have a chatham convertible crib. Is there a way to convert not using the footboard. I only want it to have a headboard.
SOURCE: HOW DO I ACTUALLY CONVERT A 3 in 1 CRIB TO A BED?
I emailed them for a copy of the assembly instructions. I'm sure they'll be able to help you with the conversion.
www.bassettbaby.com
You may contact your Consumer Affairs Representative at the following: juvenile@bassettfurniture.com
Bassett Furniture Industries, Inc.
P.O. Box 626
Bassett, VA 24055
(276) 629-6000
1-800-308-7485
Posted on Jan 31, 2008
SOURCE: Bassett Convert instructions
The instructions to convert this be can be found on the bottom where the stick is with the manufacturers info and warning, but be careful i have the same one and the screws ripped through the wood causing it to colapse.
Posted on Oct 11, 2008
  • 8 Answers
SOURCE: Need instructions ofr converting crib to a toddler bed.
This site has instructions for the cribs listed below. The 1st two listed seem to be generic cribs with a metal mattress support. It worked for my used crib.
www.milliondollarbaby.com/help.milliondollarbaby.com/
*For cribs with snap-in spring hangers hooks & metal mattress support.w/ spring hanger hdware.
*For cribs w/ bolt-in metal hdware for metal mattress support w/ metal hdware.
For cribs with Safety Glide nylon(rodless) hardware
Sleigh Convertible 3001 Crib
Sleigh Convertible 3091 Crib - Safety Glide
Jenny Lind Crib
Ashley/Alexandria Crib (1 piece headboard) +Day bed info.
Ashley/Alexandria Crib (3-piece headboard) +Day bed info
Lauren Crib ) +Day bed info
Emily Crib (One piece headboard) ) +Day bed info
Emily Crib (Four-piece headboard) ) +Day bed info
Mini Emily Crib
Anastasia Crib
Bridget Crib
Valerie Crib ) +Day bed info
Bailey Crib ) +Day bed info
Ellie Crib Day bed and full bed info
Kalani Crib Day bed and full bed info
Bordeaux Crib Day bed and full bed info
Annabelle Mini Crib
Italian Cribs-Metal Barrel Nut
Italian Cribs-Nylon Nut
Canopy cribs with snap-in spring hanger hardware
Canopy cribs with metal bolt-in hardware
Posted on May 17, 2009
SOURCE: Bassett Southampton Crib Directions
THE DIRECTIONS FOR BASSETT SOUTHHAMPTON CONVERTIBLE CRIB (model 5925-0521) ARE LOCATED *INSIDE* THE WARNING LABEL ON THE WIRE CRIB BASE. The warning label is an envelope that holds the direction packet. I was confused, too--I thought they hadn't included them with my crib! Hope that helps!
Posted on Jul 06, 2009
SOURCE: Unique Oak Treasures Crib - Full Bed Bassett Model 5542-0521
We have this crib as well. We bought it from Babys R' Us in 2005.
We also purchased the rails to convert it to a full sized bed. It did not come with instructions but I can explain to you how to put it together.
The rail conversion set should come with 2 pieces of wood that act as the bed frame. You do not need to purchase the extended frame. The set should also come with 4 long screws, the hex tool to tighten it and 4 metal pieces. You might also have some wood nail cover plugs.
Once you've taken apart your crib, the only pieces that you will need are the 2 longer pieces of the crib...the headboard and the footboard. The 2 shorter side pieces which served as a headboard and footboard as a crib and the metal grate to hold up the mattress can be put into storage.
On the sides of each of the new wood rails, you will see a circle indent on each end with a hole. You will insert one of the long screws into each and then insert it into the head board. You must use the special tool to screw/ tighten it in. The metal flat pieces can be inserted into it the circle befor eyou are done tightning so that it does not strip or damage the end of the circle. You do this with the other rail on the other end and then add the footboard using the same process. If you would like, I can send you a copy of what this looks like close up. ( the cricle indent with screws. The bed is extremely strong. We've all napt in it as a family along with our 2 large dogs. I highly recommend ordering the extra long/ tall bed rails from OneStepAhead for security because my son has rolled out of the bed and it is super tall!
http://www.onestepahead.com/catalog/product.jsp?productId=534602&parentCategoryId=85183&categoryId=85216&subCategoryId=86203
Posted on Jul 18, 2009
Need brackets for a crib to twin bed conversion
call the number listed in the instruction sheet . they and only they have the parts
Sep 19, 2015 | Baby Gear
BedrAILS FOR CHATHAM CONVERTIBLE CRIB
If you are looking to buy bedrails for your Chatham crib, you can try Amazon
http://www.amazon.com/Bassettbaby-Premier-Chatham-Wooden-Bedrails/dp/B004NRP8EE
Jun 12, 2012 | Baby Gear
Simplicity Ellis Crib Combo to Fullsize Bed
Is it the full size bed frame that goes to that bed because if it is not it will not attach. It will only attach to the special boards you had to order from them. You can try this email I have for them, but I am unsure if they are in business anymore. I know they were connected with Graco so if the email does not work you can try Graco for a manual. The email I have is customerservice@simplicityforchildren.com
Sep 02, 2009 | Simplicity for Children Ellis Crib 'N...
Jul 12, 2009 | Bassett Cottage 3-in-1 Crib
Converting Delta Martinique 5-in1 Crib to single bed
I have the same crib and it can be transformed into a toddler bed by removing the front rail and it can be transformed into a full size bed using a full size bed frame and the front and back rails of the crib.
May 30, 2009 | Delta Martinique 5-in-1 Crib
Jardine Black Olympia lifetime convertible crib
I called Jardine Enterprises and they said they would email me a manual . Call them at 1-800-295-1980 and provide them with the model number and mfg date of your crib and they will send you a manual via email.
Apr 03, 2009 | Baby Gear
Need Help converting the Storkcraft Ariel Crib into a full size
Beats me. All the frames I am familiar with have brackets at the headboard end and open channels at the foot. Maybe Storkcraft can explain.....
Dec 24, 2017 | Storkcraft Baby Ariel Stages (3-in-1 Crib)
Instructions To Convert Jardine Madison Life Time Crib
To convert your crib to a Full Size bed you will need to purchase a set of full size bed rails (hook style for headboard and foot board). You can find this at any discount mattress store, or furniture outlet, it can range in price from $39.99 - $99.99. To install the rails you will see slots with bars on the headboard/footboard, this is where the hooks on the rails slide into. There are no bolts used to secure the rails to the headboard/footboard.
Jardine enterprises does not make a wood rail kit as was shown in some of the earlier ads for the Madison line of convertible cribs, and do not waste your time ordering the rail kit from Babies-R-Us as it is simply a metal rail kit (which you may be able to get cheaper at a local furniture/mattress store).
Use the lower daybed rail between the two front posts for the foot board. Another option for the full-size conversion is to purchase the metal rails (hook style) for a headboard only and not even bother with a foot board.
If you are still unsure of what you need to do for the full-size conversion please feel free to email me at gistecknician@aol.com.
Feb 21, 2009 | Baby Gear
How to convert crib to youth bed..
contact me and i can walk you thru it if it is a white metal one, since that is the one i own and know how to do it
Jun 29, 2008 | Simplicity for Children 4-in-1 Convertible...
I have two children and I changed their beds from the cribs to the day beds by taking the front or footboard part off.  You have to save this part because in order to change it from the day bed to a full bed, you have to buy a siderail kit, take the sides off, and attach the siderails to the headboard and footboard.  Hope this helps!
Oct 11, 2007 | Bassett Cottage 3-in-1 Crib
Bassett Cottage 3-in-1 Crib Logo
Top Bassett Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Tom Chichester
Are you a Bassett Baby Gear Expert? Answer questions, earn points and help others
