Question about RCA HD52W58 52" TV
My RCA Model number HD52W59 has color distortion and double image and sunk picture in the middle. Is there any way of fixing this problem. This tv is a projection TV
  • RCA Master
  • 8,457 Answers
Yes.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be change to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Posted on Nov 08, 2010
Rca hd52w59 tv has red, blue and green lines at the top and the images are doubled. What is wrong?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 18, 2011 | RCA HD52W59 HDTV Projection Television
Hi I have a rca hd52w59. the top half of the
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 24, 2010 | RCA HD52W59 HDTV Projection Television
I have a 52inch rca projectin tv model hd52w59 i
Ur convergence it dead,U know how to solder?Buy a covergence kit,replace what in that kit.Tries these Websites,Tv Repair World.com,Ebay.com.
Sep 30, 2009 | RCA Televison & Video
Images doubled and red blue green colors all seperate
Look in menu go to setup see if you have convergence listed on menu if not you have open fuse FL231, located next to flyback on right side there is 3 in aroll small brown looking caps middle one is it FL231.
Dec 16, 2008 | RCA HD52W59 HDTV Projection Television
Rca 52inch hdtv
Please replace STK392-110 quantity 02 in your tv to fix convergence problem.
Above said part is available here.
Regards,
Sep 27, 2008 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 convergence?
Before you go and buy parts it might be worth your time to check the convergence power supply fuse. It's located in the back of the TV just to the right of a large black component with 2 red wires coming off of the top. This is the flyback transformer. Just to the right of the flyback you should see three fuseable links that look like chicklet's gum. The one that may have fried is the one in the middle, it's a 400mA 125V fuseable link. Hopefully thats all your problem is.
Apr 28, 2008 | RCA HD52W59 HDTV Projection Television
Convergence??
e-mail me at networks@q.com and get me the chassis number see in the back of your tv under model number maybe chassis number
Apr 17, 2008 | RCA HD52W59 HDTV Projection Television
Distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W58 52" TV Logo
319 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
