Question about Sony KP-51HW40 51" Rear Projection Television
No sound only get sound when dvd or vhs - Sony KP-51HW40 51" Rear Projection Television
  • tsnell1 Jan 30, 2009
    I have a 1998, 53 inch Sony, rear projection. model number kp53V.
    There is no sound. A great picture. It is connected to cable.
  • 927 Answers
Good Day;
No sound on what? DVD & VHS, okay?
Need more information:
1. Where don't you get any sound from?
2. Are you using cable box, sat.,or.....? What?
3. If box what type?
4. ANT, VIDEO, COMP, HDMI or ECT. inputs.
If you are using a cable box there are some boxes that have volume controls on them, please check volume level.
Please clarify what source you are using & check all 'other' cables.
Good Luck, Day, Big Irish.
Posted on Jun 18, 2008
No sound when playing dvd, connection to vhs player
tried to record coming from other tape and replace the audio cord.
Sep 15, 2012 | Televison & Video
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
My py90vg dvd vhs player does not play vhs. The sound is on but there is no picture
If you have the DVD/VCR connected using the component outputs, then you'll need to also connect a composite video wire to your TV from the DVD/VCR. VHS will not play through the component outputs, only the DVD will and they probably both share the same audio output connection so this would explain the DVD being seen and heard while only hearing the VHS.
Feb 01, 2010 | Funai PY90VG DVD Player/VCR
My dvd/vhs combo has sound but no picture on the vhs side?
Check ur RCA cable setting might have a short in the cables.
Dec 12, 2009 | Televison & Video
Have a samsumg 4600 combo dvd/vhs plays vhs with good sound and picture, dvd only has sound and no picture
need to check the video audio output connectors sounds like it hooked to and output that is only for the vhs
Jul 07, 2009 | Samsung DVD-V4600 DVD Player/VCR
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
Vhs tapes recorded to DVD+R's
try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
May 12, 2017 | Televison & Video
VHS side doesn't have pictures
the connection from your player to TV is only single output not separated DVD and VHS. If there is picture when used on DVD then you should be having problem with your VHS player. Question.... is your unit new? Is this the first time you encounter this problem? what is the brand of your player?
Jun 28, 2008 | Televison & Video
Sony KP-51HW40 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
