Question about OKI C5400 Laser Printer
Fatal error 428056ec + 4280999c - OKI C5400 Laser Printer
I had this error on our OKI C5400. Turned out to be a rogue print job that was sending data directly to the printer, bypassing the print server. When network cable was disconnected and the printer reset, all was fine till cable reconnected. So I changed the printer's IP address and this solved the problem. The sender of the rogue job was identified when they later asked why they could no longer connect.
Posted on Feb 13, 2012
    President:
  • 3,278 Answers
Hello.
Try resetting the printer:
  1. Power on printer while holding both the "+" & "-" buttons simultaneously; release when "OKIUSER" is displayed.
  2. Press either the "+" or "-" button until "ENGINE DIAG MODE" is displayed; press "Enter" and "DIAGNOSTIC MODE xx.xx.xx" will be displayed.
  3. Press and hold both the "-" & "On-line" buttons simultaneously until "ENG DIAG LEVEL2" is displayed.
  4. Press either the "+" or "-" button until "CONSUMABLE COUNTER SET" is displayed, press "Enter" to go in the menu to set various consumables.
  5. Press either the "+" or "-" buttons to go to the desired consumable and press "Enter": the last digit of the count will start flashing.
  6. Press "Cancel" to decrease the digit amount or press the "On-line" button to increase the digit amount; press the "+" or "-" buttons to move along individual digits in the count.
  7. Once the count is at the level you desire, press and hold the "On-line", "Cancel", and "Back" buttons simultaneously until the "*" reappears next to the count; consumable's count has been reseted to the number specified.
  8. Press the "+" or "-" buttons to move to the next consumable and repeat at step 5.
  9. Once all consumable counts have been set to desired amounts that are below their end-of-life thresholds, use the "Back", "+", and "-" buttons to exit through the menus (reverse of steps 2 through 4) until "INITIALIZING" is displayed.
  10. Turn off the printer and turn on.
Hope this helps.
Posted on Nov 08, 2010
2 Suggested Answers
jay767
  • 386 Answers
SOURCE: Fatal Error message 428056ec + 4280999c tried the
Hi Good day!! Try to reset the factory setting
Follow this
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Thank you for using FixYa
Please accept if my solution helps you thank you
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
My pc`s screen is blue and it sais stop:c000021a ,is there? anything I can do to fix it
hello there
here is some information that should be able to explain this error and how to fix it ok?
best regards michael
  1. How to troubleshoot a "STOP 0xC000021A" error ... presents advanced troubleshooting steps for the STOP 0xC000021A error. ... STOP: c000021a {Fatal ... Note Most STOP 0xC000021A errors occur because Winlogon. ...support.microsoft.com/kb/156669
  2. "STOP: c000021a (Fatal System Error)" Error! RE: "STOP: c000021a (Fatal System Error)" Error! Ya, thats what I thought I might have to do ... RE: "STOP: c000021a (Fatal System Error)" Error! just input the ...www.msghelp.net/showthread.php?tid=66202 - 52k - Cached
  3. How I fixed my Windows XP Stop c000021a {Fatal System Error} with ... How I fixed my Windows XP Stop c000021a {Fatal System Error} with Knoppix Linux. 2008 March 14 ... Message: Stop c000021a {Fatal System Error} The Session ...healyourchurchwebsite.com/2008/03/14/how-i-fixed-my-stop-c000021a-f... - 53k - Cached
Sep 16, 2009 | Microsoft Windows XP Professional With...
Iomega HDD Fatal Error 05
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Jul 05, 2009 | Iomega ScreenPlay
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Navigation fatal error Error 1706
yes..I saw that..need teh model number of the actual gps you are using, please..
Mar 09, 2008 | GPS
Fatal error oo4
fatal system error
service required/004
Feb 16, 2008 | Olympus m:robe MR-100 Digital Media Player
Emachine will not start up it says fatal error regeristery not updated, then turns off
Linux and UNIX ld command help -z defs, Force a fatal error if any undefined symbols remain at the end of the ... which are marked lazyload will not be loaded at initial process startup
E-mail CHID: 5369 Unfortunately we were unable to find anything about the Fatal Exception error message you are encountering we suggest you go through the basic fatal.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | E-Machines eMachines Desktop PC
OKI C5400 Laser Printer Logo
270 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
