MY COMPUTER WONT CONNECT TO WIRELESS BELIKN ROUTER AFTER IT BEING RE INSTALLLED OTHER PEOPLES LAPTOPS WILL CONNECT BUT MINE WONT
    Problem Solver:
  • 6 Answers
If you are fimilar with your operation system go into your device manager. and pull up the properties for you WIFI card. Make sure your card is not set to only pick up B or G. Make sure the Signals such as B/G/N match up on your wifi card and router
Troy Box
troy@lcss.us
Computer Tech
Posted on Nov 08, 2010
My lap top isnt set up for wireless connection to internet
Connecting laptop/computer to wireless router
If you have a wireless router and it is connected to the DSLor cable modem and Internet then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Jun 16, 2012 | Samsung Computers & Internet
I can't tell which router is mine
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Apr 26, 2012 | Linksys Wireless-G WRT54G Router
I can get internet on my house computer that its connected to via ethernet cord, however, i can't connect wirelessly using my laptop. My laptop has no problem connected to other peoples wireless...
When u try to connect wirelessly with your laptop does it find your home network when you scan for available networks...If so you need to input the SSID and passsword which is on the bottom of your wireless router usually or you should have received a card with these details on from your Internet provider....Hope this helps xx
Jun 21, 2011 | Computers & Internet
How do i secure my belikn from outsiders using it
Enable wireless security on your router, so that other people will not be able to connect to your network.
To enable wireless security, access the setup page of the router through a web browser. Type 192.168.2.1 in the address bar.
By default, leave the password blank.
Once in the setup page, go to Wireless. Take note of your SSID. Then go to Security.
Select WEP or WPA, depending on the operating system and capabilities of your wireless computer. If in doubt, you may use WEP since it is the legacy wireless standard.
You can enter your WEP key manually by typing in the hex WEP key manually, or you can type a passphrase in the “PassPhrase” field and click “Generate” to create a WEP key from the passphrase.
Make sure to take note of the WEP key because you will be needing this for your wireless computer.
Click Apply Changes.
On your wireless computer, view the available wireless networks, select your SSID, then type the WEP key.
I hope this helps!
May 11, 2010 | Belkin (F5D9230-4) Wireless Router...
How do i put a password on my Belikn G Plus router.
To secure your wireless router you should specify a WPA or WPA2 key (depending what your router supports).
To set it up follow the steps below:
Open an internet explorer and type 192.168.0.1 on the address bar above and press enter.
The router will probably ask for a username and password which if you haven't set it will probably be "admin" for the username and "admin" or a blank password.
Then go to wireless settings and choose wireless security. Choose WPA2 if it is available (avoid WEP as it not very secure). Then enter a passphrase that you will remember and save your settings.
When you try to connect from your laptop or other wireless device it will ask for the type (WEP,WPA, WPA2) and the passphrase that you entered. That's it!
Feb 03, 2010 | Belkin (F5D7231-4) Wireless Router
How do I change the channel on my Belikn N router?
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 26, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Windows xp wont connect to internet
Please check you LAN settings on your router (DNS) - usually it is 0.0.0.0 (assigned by provider)
Make sure your PC is using DHCP (TCP/IP properties -> Obtain IP Address Automatically & Obtain DNS server address automatically). Try "ipconfig /all" at others computers and compare with your PC (look at gateway & DNS). See if you can ping gateway and then outside address.
p.s. To access your router open Internet Explorer and enter http://192.168.0.1/
If it is not working, check the default gateway address on working computer and use it instead.
Feb 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Acer Aspire wont connect to internet wirelessly.
try to change position of your wireless router it will work.
Mar 17, 2008 | Acer Aspire 3000 Notebook
Port forwarding
go to http://www.portforward.com/ and follow instructions on how to port forward, select your router model first.
Nov 19, 2007 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
David Payne
David Payne
