Question about SDI iHome iH5 Docking Station, FM Transmitter for Apple iPod (047532889017)
My ihome is not keeping time. It is losing about three hours over a weekend
Will my ihome Bluetooth speaker work after being wet I have no sound
yes but you need to dry it for 12 hours or it looks dry
and then charge.If its not working charge the one damaged and turn on
Oct 20, 2015 | iHome Audio Players & Recorders
How do i set the alarm on my ihome alarm dock?
Once the time is correct, users can move on to setting the alarm itself. Many iHome systems come with dual alarms allowing couples to set different times for each person or individuals to designate a weekday and weekend alarm. Each alarm has its own time, wake-to source, and frequency. The process of setting the alarm is the same for both options, the only difference is what button, either 1 or 2, users depress when setting it.
Once ready to set an alarm, users need to push and hold the button down, waiting for the alarm time to appear on the clock's display. From there, the up and down arrows or plus and minus buttons adjust the time backwards or forwards accordingly. Once that is complete, users select the frequency of the alarm by pressing the alarm button again and then opting for 7, 5, or 2, which correlates with all week, weekdays, and weekends respectively.
The final part to set is the wake source of the alarm. Users press alarm buttons one more time, and then use the same directional buttons to choose from iPhone and iPad on some models, radio, buzzer, or playlist. If users choose playlist, they must also setup a playlist within their Apple device titled iHome.
Because frequency is part of the alarm setting process, there is no need to turn on the iHome alarm manually as one would do with a normal alarm clock. However, users can check to see if the alarm is active by looking at the screen of the clock for the earliest alarm time, displayed on its lower part.
In the mornings, when the alarm sounds, users have two options: Snooze and disarm. The disarm process turns off the alarm until the next day in its frequency chain. Users disarm the alarm by pressing the power button. On the other hand, users must manually program the snooze button. Users do this by pressing and holding the snooze button and then toggling to the desired snooze time, generally between one and 29 minutes. Once this is set, users simply press the snooze button in the mornings to delay the replay of the alarm for that amount of time.
Jul 18, 2014 | iHome Audio Players & Recorders
How do I Set time on ihome HPL10
This is a hotel version of the iHome iPL10 which has the Set Clock button on top. Instead, the set/sync button is on the back of the unit. This is typically covered by a plastic cover to keep guests from messing with the time settings on the clock. The covered buttons allow you to set Volume Limit: high or low, Time: set/sync, and Day Light Savings Time (dst) +1 -1 or Auto.
Since this is the hotel version, there is no User Manual on iHome's web site.
Jun 13, 2014 | Pioneer DXT-2266UB Car Audio System
I cannot get my ihome ip11 model out of military time. Help. Thanks for any help you can give
Hello pac31:
For 12 hour time format setting: Press the Alarm Ser Button durin time setting to set 12-hour 24-hour display format. Remember to set the correct AM or PM time (an icon to the right of the time display is the PM indicator ther is no AM indicator).
Remember to click the thumbs up if this helps.
Sincerely, Peter
Mar 02, 2011 | Audio Players & Recorders
My brand new ihome ip87 just stopped working. It will charge my ipod but it shows no clock and it won't turn on.
Mine is doing the same thing. So I looked it up. And it said to take out your iPod and unplug the ihome then take out the batteries from the ihome and leave it for an hour.. Then it will reset itself.. I just did it and it worked.. I also had to put in new batteries in the ihome
Jan 02, 2011 | Audio Players & Recorders
My iTouch is fully charged but wont turn on
hold don the top and bottom button and the sam time and keep it held down till the apple logo shows
Oct 15, 2009 | Apple iPod touch
Ihome won't play ipod, even after resetting ipod I have de same problem. I got an itouch 2nd generation and docked it on a speaker that supports it. It worked fine for two or three hours, but suddenly it...
Welcome to the wonderful world of the iHome frying the Ipod.
Your iHome, has most likely fried the mainboard on your ipod.
to check plug a usb into the ipod and connect to the computer.
if it comes up disconnect the usb and try a headphones in the jack.
if it doesn;t play sound its fried and you will need a new mainboard.
if it does play through the headphone jack, your lucky and keep it off the dock.
I have fixed at least 30 ipods taken out by ihome docks and other docks.
they are terrible for the ipod. Even Apple sells the docks on their website
that shows how much they care about the product.
If this helps leave a vote on fixya
May 11, 2009 | Apple iPod touch
IH36 iHome degrading
The problem is that the flat flexible cable which connects the dock to the main unit is breaking. After taking mine apart(!), I found that the point at which the cable connects to the main unit is flexed very strongly each time the dock is opened. Each time the dock opens & closes, it gets worse.
Replacement is a 260mm, 12 pin, 1mm pitch, flat flexible cable, AWM 20624 80c VW-1. I have yet to locate a supplier of this cable.
Jan 04, 2009 | Audio Players & Recorders
Changing displayed time
Go to Preferences, select Restart GPS. Then Enter Coordinates. Keep hitting the enter key until you get to the time field, now set your local time. And no, you will not lose your POI.
Mar 18, 2008 | Magellan eXplorist 100 GPS Receiver
SDI iHome iH5 Docking Station, FM Transmitter for Apple iPod (047532889017) Logo
162 people viewed this question
Top SDI Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a SDI Audio Player and Recorder Expert? Answer questions, earn points and help others
