Bosch maxx 900 rinse light is blinking and won't restart. what to do?
  • 139 Answers
SOURCE: Bosch Maxx WFL 2260
Hey check to see if you can move the drum by hand,, if you cant the the bearings on the drum have gone and it is seized ..
If you can turn it by hand then most likely it is the carbon brushes on the motor..
hope this helps
any questions dont hesitate to contact me im here to help....
Posted on Jan 17, 2008
beltronic205
  • 1474 Answers
SOURCE: Bosch Maxx - softener not dispensing into machine
It blocks very often , give it a good clean..remove soap dispenser to do so
Posted on Sep 28, 2009
tony2155
  • 64 Answers
SOURCE: washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
Posted on Mar 28, 2010
Macmarkus
  • 2605 Answers
SOURCE: My Bosch maxx 900 front loader won't drain water
Hello David,
Welcome to FixYa.
Based on your description you likely have a clogged drain pump/filter.
Here`s how to check since that would be the first logical place to start.
1) **Turn off the power or unplug the cord from the dryer or wall...ehichever applies to your set-up...safety first**
2) Water removal...remove toe panel. There you will find a small hose with a plug in the end for draining the pump.
3) Now bleed pump drain...A shallow pan is handy for this step.
3) remove pump filter, but be careful if you don't have a shop-vac or a shallow pan and towels you may get wet...
*Once you`ve reached this point you may have trouble removing the filter if it is really plugged up with debris. You might have to wiggle it back and forth as you twist and pull.
4) When you get the filter out, visually inspect inside the pump thoroughly with a flashlight and clean it out really well. It won`t take much to prevent these from draining. i.e. a penny, hair pin, buttons etc.
Let me know if you found anything in the pump and how you make out after that.
If you removed any obstruction, simply reassemble the unit making sure the filter is screwed in tight, run a quick rinse cycle to test for leaks before putting the toe panel back on and you should be good to go...save for any leaks.
There are other possible factors that can prevent the unit from draining or spinning out items properly, but we`ll cross that bridge when and if we get there.
Thank you for choosing FixYa, keep me posted on your situation.
macmarkus :)
Posted on Sep 02, 2010
ginko
  • 19396 Answers
SOURCE: The door won't open on
Hi.
You need to drain water out of the machine.
Disconnect power and first work on the drain hose at the back of the appliance, use a bucket to empty water placing the hose at the floor level.
Second part of drain job is done accessing the filter. the filter is connected to the drain pump. This is accessed through the service access located in front of the machine, on the lower side.
Remove the trim at the base of the machine using a lever, then unscrew the filter cap located at the left hand side, ensure that you have a container ready to collect the water.
At that point, try connecting back power and unlock door. Door should open.
If door still does not unlock, then the door interlock, the pressure switch or door lock may be responsible. In that case most Bosch have an emergency lock located near to the pump:
Posted on Sep 30, 2010
How to open bosch maxx 1200 once it has started cycle
you cannot you can try manually turning switch so it does its last rinse and spin and weight untill light goes off there is a switch inside the m/c when the water gets to a sertain level the door will not open for obvious reasons hope this helps ivan uk
Aug 25, 2012 | Bosch Washing Machines
Does anyone know how to check a fuse in my Bosch Maxx 1000 washing machine??
Try it in a different socket as it may not be the machine. The machine would have been factory fitted with a moulded plug, lift out the middle section and try a new fuse. If the unit failed after filling then possibly you have a short on the wash heater..you could verify this if you get power by setting a cold cycle or rinse and see if if completes it. Please also check that the consumer unit (main fuse box) has not been triggered.
Nov 26, 2011 | Bosch Washing Machines
The water does not cutoff during rinse cycles on the rinse plus and normal wash programmes on my Bosch Maxx WFL 2060 but works fine on quick wash programme
pressure chamber blocked with soap depists scale etc will need removing for service and cleaning partial strip down required.
Feb 14, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Washes until before rinsing and stops.
I think the problem was a bad waterfill value. removethe water from the base
RINSE/DRY = Water filling fault (over or under filling)
regards
balisonu79
Jan 04, 2010 | Bosch Washing Machines
Bosch Maxx WFL 2060
connect at random. put on a rinse cycle. if cold water comes in then pipes are correct. if hot water comes in then pipes are wrong way round and just swap them
Sep 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
