Question about RCA F32444 32" TV
No picture but sound
We have an F32444 rca television in our mororhome and while watching a program, the screen shrunk to a center pin-point and the screen went blank but the sound was fine. An hour or so later we turned on the tv and the picture was fine for approximately 10 minutes and again the pin-point and a blank screen. This tv is in a custom designed cabinet to hold the tv in place while the motorhome is in motion so we would like to get it repaired since we probably can't find another tv of this size and shape.
Any suggestions?
    Brigadier General:
  • 6,966 Answers
Initially, what could be surmised is that the TV could either have a loose connection/cold solder or a component heat related problem. Loose connectors would be any of the major connector carrying the major B+ supply, cold solder on the other hand could be on any of the major power components. Heat related would be often on capacitors, generally on the power supply or filters on the load side.
Since this would involve opening the unit, familiarity with electronic components and circuitry, use of a DVM and a soldering iron, perhaps your best/quickest bet would be to seek the services of a qualified professional. Should you venture a DIY, it might be to your advantage to have access to a service manual or at the very least a schematic diagram with voltage readings.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 16, 2008
  • 62 Answers
Yes tv need to see a mechanic cause the loading resistor was done his job for now.
You can't fix that only mechanic.
They should give you second tv until they repair him.
    Sergeant:
  • 243 Answers
It sounds to me that your tv has a bad vertical deflection system or it has just worn out. you can take it to a place to be serviced cause Any set is repairable. The question is at what cost.
As a general rule, most experts agree that a set over 4 years of age is better replaced than repaired (unless it is a trivial problem). Consumer Reports stated in October 2001 issue The reason is simple: Cost of repairs is getting more all the time. Prices of new sets is going down dramatically. The features and performance have improved dramatically the last few years. The chances of something going bad, again, after a repair is very high; which means you may be pouring good money after bad.
The problem with your set could be a bad vertical deflection system, blown ic or pcb board to deflection system.
My recommendation is this: Before doing anything, just bang on the set a few times with your hand to see if there is something loose inside that will, with some agitation, bring back the picture. YOu never know, it may come back to life. If nothing simple seems to improve it, then i would disposed of it and replace. As i have had this happen before and it costs more money to hear that its broke then its worth.
thank you,
Nathan
  • 1 more comment
  • Nathan Ayers
    Nathan Ayers Jun 16, 2008
    specially on a tube type tv. if you bought the extended service plan nows the time to use depending on when you got it. but since i see it only has a 1 year tube warranty. Its probably just shot. as you had a special deflection system for this tv for a sharper picture. It wouldnt be uncommon that it no longer works in one of a dozen ways. Which most likely would result in a tube replacement.
  • Nathan Ayers
    actually the dimmensions of the 32" you have are fairly common for 32" tubes. You could look on craigslist and probably find one for pretty cheap. ive already been able to locate a dozen throughout the country of the exact same model. on www.craigslist.org for around 75-150 dollars. which would be about the cost of a repair.
  • Nathan Ayers
    glad to see you found your answer. -Nate
    thanks for using fixya
Picture Moved Up
Check the cable and connections between the TV and your cable line. Make sure the contacts are clean, no bent pins, etc. Try replacing the cable if possible.
Jun 01, 2008 | Samsung HCL4715W 47" Rear Projection...
Rca p56830bl picture fade out
sounds like a vertical and horizontal deflection issue..maybe your control board is unhappy.
you inclined to do this work yourself?
Apr 28, 2008 | RCA P56830BL 56" Rear Projection...
I own an 32 inch RCA TV Model No. F32444 one day
The TV has burned out.......Don't switch it back on again unless you want to get electrocuted, or burn your house down
Jan 19, 2010 | RCA F32444 32" TV
RCA 32'' TV making a humming noise
sounds like a shorted horizontal output transistor probably caused by the high voltage transformer or hot. it is most likely fixable but it will be costly.
Aug 19, 2009 | Televison & Video
RCA TV Model F32444 Will not power on
The noise you are hearing is probably the degauss (it demagnetises the screen every startup). The most likely problem is the power supply. Do a replacement of all the caps on the powersupply board and it will likely fix your problem. Because it still has power to the degauss coils it hasn't blown the fuse. Power supply not starting like that is usually caused by a small electrolytic capacitor near the heatsink on the mains side of the powersupply. They can be replaced for about 10 cents.
Hope this helps
Feb 14, 2009 | RCA F32444 32" TV
Fix TV
I have a sony i have picture but its has a red sceen.
May 25, 2008 | RCA F32444 32" TV
Sylvania 27 in tv picture
It sounds like your vertical has shrunk, causing the picture to look squashed. Most likely a bad component in the vertical output stage.
Dec 19, 2007 | Sylvania 6413TC 13" TV
Can't View Cable RCA f32444
You will have to go in the menu and switch it to cable mode, then do an autoprogram and you will have all the channels.
Sep 04, 2007 | RCA F32444 32" TV
RCA 26" SRS WOW has a grey shadow display when watching TV
yeah, I just got one of those and when the picture is full screen I see that also. I just have the picture set to 14:9 and the pic is crystal clear. any good resources for a wall mount?
May 29, 2007 | RCA LCDX2620W 26 in. HDTV-Ready Television
RCA F32444 32" TV Logo
111 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
