Question about GE WBSE2090A Top Load Washer
The agitator keeps detaching no matter how much water or clothing is in the washer. What can be done to keep the agitator in place?
    Problem Solver:
  • 13 Answers
On top of the agitator should be a cap you can pry off and you will see a nut which has probably come loose, and you just have to tighten.
Posted on Nov 08, 2010
What will cause this washer to tare up cloths
If you are getting ripped or torn clothes then most likely they are getting bunched up underneath the center piece that turns. These usually go back and forth and not all the way around in order to keep from bunching and tangling. It may be getting caught up on a lose bolt or something inside and under the center piece. If you can't figure it out just get a new one and part that one out or sell it at a garage sale. The electrical board and dials alone are worth a hundred bucks to the right buyer.
Mar 23, 2015 | Whirlpool WTW6400SW Cabrio Washer
Fabric softner cap keeps coming off during cycle
Push the fabric softener cup down and turn it to lock it into place
Dec 28, 2013 | GE WBSR3140DW Top Load Washer
Machine not spinning dry
Top-loading washing machine has an outer tub that fills with water and sits stationary as well as an inner tub with holes in it. The inner tub has an agitator that attaches to the drive shaft. A drive belt turns the drive shaft, causing the agitator to move back and forth. Broken seals at the bottom of the agitator, or a broken belt, may cause the agitator to perform inefficiently and leave your clothes dirty
In order to properly wash clothes and prepare them for drying, a washer must agitate or spin the load. This helps wring excess water out of the clothing. If your washer has suddenly stopped spinning properly, you will notice that your clothes will be sopping wet when the washer is done. Typically, there is a simple reason for this problem that you can fix without calling in a professiona
1 Check the lid switch. You will notice on the lip of the lid there is a small stem that hangs down. This fits into a hole on the top of the washer housing and tells the washer the lid is closed and it is safe to spin the load. If the switch is faulty or has been blocked, the washer will not agitate or spin.
2 Clean out the switch receptacle. Use a multipurpose cleaner and a sponge (not a paper towel, it can shred and get caught in the switch receptacle.) Thoroughly clean the area around the switch and the receptacle.
3 Test the washer. Close the lid, allow the washer to fill with an inch of water, and move the selector to the spin cycle. Pull out on the selector. If it does not spin, stop the cycle (push the selector in) and turn the washing machine off. This means there could be three problems with the washer: the switch might be broken, something might be caught in the agitator, or the motor for the agitator may be burned out.
4 Check underneath the agitator. Small items such as underwear, panty hose or bra straps can become caught underneath the agitator and keep it from moving. Run your hand underneath this area and see if you feel anything. If you do, unwrap the item and test the washer again. If it still does not work, move to Step 5.
5 Contact a repair person. If the washer still will not agitate or spin, it will need to either have the switch replaced or the motor replaced. Contact a certified appliance repair person to have the machine inspected. If it is still under warranty, the repair person's visit should be covered.
However if its only the agitator arm, then
Instructions to Remove/replace the Agitator
1 Unplug the washer.
2 Slide a putty knife under each side of the washing machine top to release the springs holding the top in place. Lift up the top on its hinges.
3 Pull the tub clips from the inner tub using a pair of pliers.
4 Pull up on the agitator top to expose the nut holding it in place. Remove the nut using a socket wrench. Lift up on the agitator to remove it from the machine.
5 Turn the agitator upside down and remove the seals from the bottom. Replace them with a new set of seals. If the agitator is cracked, replace it.
6 Reassemble the washer.
Removing the Belt
7 Unplug the washer from the wall outlet.
8 Pull out on the bottom panel on the front of the machine. Look underneath to locate the drive belt.
9 Pull on the drive belt at the washer tub to remove it. Push down on the idler pulley near the motor to remove the belt from the machine. Route the new belt around the pulleys in the same way as before.
10 Reassemble the machine, plug it in and test.
Apr 20, 2012 | Whirlpool Washing Machines
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
May 17, 2011 | Electrolux EW1000i Front Load Washer
What makes a series III washer stink like stagnant water?
J. Garber:
ALL washing machines will build up deposits of gunk in places that you cannot see or readily access. In top loaders, the typical place is underneath the agitator and on the inside of the wash tub (part that holds water). This "gunk" typically consists of body oils, detergent deposits, calcium deposits, hair, dust, dirt, etc. This stuff gets and stays wet. Wet and warm plus "gunk" equals smells. Top loaders can easily solve this problem by removing and cleaning the center column and agitator, then super chlorinating a batch of wash water (no clothes). Fill the washer, putting in three or so cups of bleach, let sit for an hour or so. This should clean the tub. Leaving the top cover open will also help as well as washing smaller batches of clothes more frequently. I have also found that infrequent use of a washer will frequently cause the the residual wash water in the pump(s) to go stagnant. Running a quick small rinse before washing clothes will solve this problem. Front loading washing machines typically have a cleaning cycle and specific instructions as to how, as well as how often, to clean the machine. Have you read the operating manual? I find that leaving the door open and running a fan that blows air inside the machine for an hour or so after washing also helps dry out the machine and keeps mold and bacterial action down by drying out the machine quickly. Keep the door open if at all possible. Removing and drying the detergent dispensers as well as the detergent dispenser opening also helps. Changing detergent may also help. Most front loaders recommend HE detergent. Use the absolute minimum amount of detergent necessary to get your clothes clean which is often a couple of ounces or less. There are also products that claim to clean your machine and eliminate odors, but I have no experience with them. Keep it dry. Keep the door open. Use a fan to blow air around and dry the machine out. Run the cleaning cycle as often as neccesary.
Sep 04, 2009 | Kenmore Washing Machines
My top load 4.5 cubic whirl pool cabrio washer does not seem to clean my clothes. it almost acts like there is not enough water
your agitating belt might be slipping or worn, try holding the switch down with a pencil, and keeping the lid open and see if the agitator is moving or sluggish..good luck.
Jul 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Water left in clothes
The shaft was designed to rotate into 2 directions: one for agitation, one for spinning. The spinning direction is controlled by a mechanism from the clutch engagement. When your plastic pulley wears out, it effects the mechanism to spin. The driving force for spinning is slipped, therefore the spin is weak As a matter of fact, the water remaining in clothes n in turn discharges to the bottom tube
Jul 02, 2009 | Maytag Washing Machines
Kenmore Series 70 top load barely agitates....
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Three places to look.
1. Assuming that this washer has a two piece agitator, I'd check the "agitator dogs" on the top section.
2. It's possible that the splines on the agitator have worn over time.
See the following description of how to remove the agitator.
Look inside the agitator at the splines.
3. It's also possible that the splines on the agitator shaft have worn.
With the agitator off, check the condition of the splines. If they are worn, the options are to replace the agitator shaft (disassembling the transmission) or replacing the transmission itself.
May 06, 2009 | Kenmore 15864/15862 Top Load Washer
Agitate
does the unit Spin?? or just pump out the water ??? i am trying to see if you need a $10 part or a $150 part plz post
Jan 21, 2008 | Whirlpool LSB6300PW Top Load Washer
GE WBSE2090A Top Load Washer Logo
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
