Servicable Vintage GE Microprocessor 700T. After being shipped to a new address would not proceed from the wash cycle to pump out. I drained the tub completely and cleaned the spade connections on the pump as best I could. Also noted that the heavily insulation taped capacitor was loosely suspended at the bottom of the tub and touching floor. I raised the capacitor off the floor. Still won't pump. Thank you in anticipation for your advice. Regards Malcolm malcolmstrayment@gmail.com
JULIANFIX
  • 975 Answers
SOURCE: Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Posted on Apr 22, 2008
MNTECH
  • 1543 Answers
SOURCE: Loose tub on GE WJSR2080V
Reach (or look) over the tub, just under the metal top, at the four corners of the machine to see if the rubber tab dampening straps are OK. (not broken) If broken, use putty knife to push in 2 spring clips at very top of front panel (a couple inches in from the L and R side) and pull to take front panel off. Remove two 1/4 hex head screws holding top to side panels. Remove top. (looks like your model has a lid switch which can be unplugged by the back splash.)
Also check that the inner tub does not rock independently of the outer tub. If it does, pull agitator and tighten large left hand threaded nut.
Posted on Sep 13, 2008
  • 17 Answers
SOURCE: Kenmore HE3 Front Load Washer - Leaking Water into wash tub
THE WATER VALVE IN THE WASHER HAS TO BE REPLACED THE COST OF THE WATER VALVE IS ABOUT $25.00
Posted on Dec 16, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore HE2T F20 plus Water leakage when tub starts to fill
Have you read by advice on how to diagnose this problem? Click on the following link:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
If you HAVE water entering the wash tub, first verify that you do not have a siphoning condition. This is where the drain line does not have the proper air gap to drain properly and creates a vacuum on the drain line. This will cause drain problems and may prevent the washer from filling all the way. Or, you may have trouble maintaining the water level. When you stated you had water leaking, is this a visible leak? Or, do you have water slowly draining from the tub? Double check your drain line to be sure.
Next, check the drain pump to ensure it is not clogged or obstructed which minimizes drain flow. Also, make sure the pump is running. Remove the access cover and clean out the pump reservoir. In addition, check the drain line from the bottom of the wash tub to the inlet side of the drain pump. I have personally found small articles of clothing stuck in this line, preventing drain flow.
Read through the link thoroughly. If you require additional assistance, please let me know before rating the solution. I hope this helps you.
Posted on Feb 02, 2009
  • 113 Answers
SOURCE: GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Posted on Apr 24, 2009
My kenmore top load washing machine washes but wont drain or spin
The spinning cycle may be detecting that your tub is unbalanced and will not proceed. Check that it starts and fails when the tub is spinning slowly. Otherwise you may have a faulty drain relay or debris is plugging the drain out hose.
Feb 01, 2015 | Kenmore Washing Machines
GE spacemaker Washer Dryer Combo don't drain properly?
Check the drain hose for obstructions. Is it being pinched where it goes over the top of the drain pipe behind the washer?
The pump may be going bad...
Jul 29, 2014 | GE WSM2700W Unitized Spacemaker Washer and...
The water will not drain. The tub starts
The pump is clogged. The only way to fix this is to clamp off the hose to the tub and remove the hose from the pump and remove what ever clogged the pump. Expect to get a little wet.
Mar 04, 2010 | GE WBSR3140DW Top Load Washer
What does "nd" mean on my neptune washer
Hello tana_carney4,
Your in the FAV6800AW forum so I’ll assume your machine type is a FAV6800AW or FAV9800AW. I’m an owner of the FAV6800AW with some hands on experience with the machine.
The ND error code equals No Drain. The microprocessor on the Control Board keeps track of the time needed to receive a Low/Mid Level fill indication from the pressure switch at the start of a tub drain cycle. If that time elapses and the pressure switch is signaling that the tub has watering remaining then you trigger the ND error code. Is the tub empty or is there standing water in the tub with the ND error code?
If the wash tub is empty and you fail out of the wash cycle with the ND error code then I feel you have pressure switch failure, the pressure switch is signaling the Control Board incorrectly. We need to go into Service Mode “Board Input Test “ and check if the pressure switch is signaling a -1 with an empty tub (no water). If rhe pressure is signaling a -1 with an empty tub then the pressure switch is false signaling “Stuck Pressure Switch” you will error out in the wash cycle with the ND error code and the Pressure Switch will have to be replaced.
If the wash tub has standing water in the tub with a ND error code to the console we need to check for a failed drain motor, a drain pump impeller jam/clog. We would go into Service Mode turn the drain pump and listen. Do we hear the drain pump turn on? If so will it pump out 5 gallons of water in about 25 seconds or less as my working FAV6800AW will do? Further troubleshooting will require a DVM to verify that 120VAC is applied to the drain pump, If we have 120VAC at the drain pump motor connections and we don’t hear it turn on we would need to remove the drain pump and check for failed motor or jammed impeller. If the drain pump turns on but we have slow drain out of the drain pump we could would need to remove the drain line from the Sump Cap to the inlet of the drain pump and check for restrictions and possible impeller damage to the drain pump.
The question is do you just want know what the ND error code is?
Do you want to DIY the repair? If not then it would be time to call in a repair service.
Here is the FAV6800A/ FAV9800A Service Manual link.
If your machine type is not a FAV6800AW or FAV9800AW then please disregard my post.
Rich aka dh1200s
Nov 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I have the GE whdsr209doww- leaks all through cycle at the back draintube. I am going to get a new drain tube , but could it be the pump not holding the water in the tub?
FYI, the pump does not have a valve which prevents the water from leaving the tub during wash cycles.
If you were to remove the drain line from the machine the water in the tub would siphon.
I think you are moving in the right direction by replacing the drain tube. Also inspect the other connections from the tub to the water pump and water pump to drain tube..
Good luck...
Oct 12, 2009 | General Electric WHDSR209DWW Top Load...
Washer isn't draining after the wash cycle is completed.
theres an obstruction from the tub thru the pump or pump to drain
Oct 04, 2009 | GE WSXH208A Front Load Washer
Washer will not drain
ck pump for obstruction ..remove front by pressing clips along top edge with putty knife front will lift off pump lower right side
Jul 19, 2008 | GE WDSR2080D Top Load Washer
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
