Question about Maytag Dryers
My dryer is not getting hot. The air duct is not clogged.
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 11, 2010
Dryer is taking longer to dry. what used to take 60 minutes now takes 90-120. I took off the back panel and the lint shoot. both were clean. The air blows out the duct with good velocity. Hot air comes...
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Feb 04, 2011 | Dryers
Dryer gets hot but does not dry. It seems to keep the moisture in as of there isn't any air flow. I cleaned out the vents and air duct but still wont dry
This definitely sounds like a clogged vent. 1) disconnect the vent from the back of the dryer. Turn the dryer on and make sure your getting good air flow from the vent outlet. 2) if the air flow is good then your definitely have a vent that is clogged between the dryer and the outside of the house. This is the most common cause for the dryer to not dry the clothes.
Jan 13, 2011 | Dryers
Ge Profile Electric dryer model DPSE810EG5WT The
Hi.
If the fan does not work at all,then the fan motor must be replaced. The fan is tested jumping its contacts to energize it directly.
More commonly the problem is clogged air ducts. Check lint filter and check ducts for blockage. Ensure that the air duct is well in place.
Jun 27, 2010 | Dryers
I checked the connection of the dryer and nothing is clogged....the clothes take 3 hours to dry a small load...the dryer feels hot...in addition it appears there isn't that much lint on the lint screen...
check your dryer duct hose and vent.....it might be clogged,.....in some cases the duct fills with water and causes dry time to take longer.....on other cases the vent might be clogged and the heat sensor detects that it is hot enough and shuts down the heater element.................
make sure all vents are unclogged.............
dryer duct hose is in the back of the dryer and is connected usually with a duct clamp or tie strap.........disconnect and if i were you replace with a new one.... do not rinse out and put back....it will cause a build up of lint around the inside of duct hose.....the water acts like a glue trying to collect all the lint it could...and eventually it will clog the hose..............just replace with a new one......check the vent were the hot air discharges out of usually outside or rooftop........most vents are covered with a screen or a plastic/sheetmetal flap.....make sure the flap can move.also make sure that it is uclogged and has good airflow...........................
good luck if anything just message
a feed back would be good if this helps...
Jun 19, 2010 | Kenmore 62802 Electric Dryer
The dryer does get hot but takes a very long time to dry a normal load of clothes. What I noticed is that the top right hand corner of the dryer gets scalding hot during the cycle. It worked fine before I...
It sound like you have a venting problem. The air from the dryer is probably restricted by either a clogged exhaust hose or duct work in house or a stuck vent flap where air blows to the outside. If your vent goes straight up to the roof, something may be blocking the exit or the whole line may be clogged. Also check for a kinked flex hose that attaches to the dryer. If blockage is in wall of house, there are vent cleaning companies that can clean out the line.
Feb 04, 2010 | Kenmore 84052 Dryer
No hot air for dryer
this is most likeky thermostat you can find here http://www.partstap.com/
Feb 25, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer not drying loads properly.
You need to clean the vent ducting from the point where it leaves the dryer to where it exits your home. The reason the dryer performed better was because it was not meeting any resistance from the ducting to push air through the exhaust on the back of the dryer. You obviously have a clog, kink, excessive bend, or a run that is too long. If you haven't had your vent ducting inspected or cleaned in a while, now would be a good time. In addition, the fact that your dryer became excessively hot WITH the ducting attached adds credence to my suspicion that your ducting is clogged or obstructed in some way. Without proper air flow the dryer will actually overheat to the point of failure. Usually the Thermal Cut-Out (also known as a Thermister) will blow. This component is designed to blow like a fuse in the event of an overheat condition and must be replaced. Running your dryer in an overheat condition not only will damage the appliance, but it can become a fire hazard. I would recommend a thorough ventilation inspection and cleaning. Make sure you are using the metallic semi-rigid ducting and NOT the plastic ducting. The semi-rigid resists crushing, kinking, is heat resistant and resists intrusion by rodents. If you have questions about anything I've explained to you, please contact me and let me know. I hope this helps.
Feb 10, 2009 | Frigidaire GLER642A Electric Dryer
Dryer problem
Your problem may be associated with heavy accumulations of lint inside the dryer and/or ducting. If you have had a water leak recently, and the dryer ducting got wet, the lint could be sticking somewhere and forming a clog. A simple way you can determine if you have a clog somewhere is to disconnect the dryer vent hose from the dryer and start the dryer. The air leaving the dryer should be forceful and about 140 degrees (in other words...good and warm). If the air is weak and cool, you have a clog somehwere INTERNAL to the dryer. If the air is forceful and warm, check your ducting from the dryer to where it exits the house. A dryer needs proper air flow in order to dry properly. The fact that your dryer is getting very hot tells me that the heating element is heating up, but may in fact, be OVERHEATING. The dryer will not continue to run in this condition. Eventually the heating element or thermal fuse will blow. Take the time to perform these simple steps and post back with your results and/or comments. If it is not a simple clog, I can give you further advice on how to determine a cause of your problem.
NOTE: If you plan on cleaning the dryer interior, ensure you unplug the dryer from the power source. Live voltages of 220VAC are still present even with the dryer turned off.
Jan 14, 2008 | Amana NDE2335AY Electric Dryer
Kenmore Elite HE4-lots of heat, clothes not drying
Poor drying problems with dryers generally are attributed to clogged ducting. You have probably heard this before, but the first (and least expensive) fix for any dryer with long dry times is to check the air movement. As well know, dryers require good air flow to ensure proper drying. Now, when you said the air movement is strong, were you checking it at the air vent exhaust outside, or were you checking on the back of the dryer? An easy way to tell if there's a clog in the ducting, or a clog in the dryer is to run one load with the dryer vent disconnected from the back of the machine. Only run one load like this. Not a good idea to blow hot moist air into an enclosed area of your home over a period of time because it can cause mildew problems. If the dryer blows freely and your clothes dry faster, you know you need to check the ducting from where it connects to the wall to where it ends at the exhaust vent. Often it is not enough to just clean the lint trap and the outside vent. You need to check what's in between them as well. Mice and birds are notorious for building nests in dryer vents and clogging them up. Now...if the dryer is blowing poorly at the exhaust port on the back of the dryer, you will need to remove the door kick panel under the door and remove the vent duct housing to get to the blower fan. Make sure you unplug the dryer before attempting this. There are live voltages present even with the dryer turned off. Lint can get trapped in vent housing and restrict the movement of the fan, which, in turn, will cause poor air movement and longer dry times. Last of all, take a temperature reading at the exhaust port on the back of the dryer. A good temperature reading is roughly 140 degrees F. If the temperature is too low, you may have an operating thermostat or high limit thermostat malfunctioning. Check your vent ducting, first and let me know if you need further assistance. I hope this helps you.
Aug 04, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
32 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
