Question about Brother IntelliFAX 1800C All-In-One Printer
I change the ink cartridges and then received an Error 41
  • 1,218 Answers
While there are many ways to prevent Brother printer error code "41?, the most common method is to uninstall Print2PDF file from server. You then need to manually remove the traces that still exist and then reinstall Brother printer. You will then have to upgrade your printer software to its newest version. Another way to prevent Brother printer error code "41? is to make sure that printer spooler is working fine. For better working of the spooler set it in automatic mode instead of the default manual mode.
Posted on Nov 08, 2010
Cannot make the printer work after I changed the ink cartridges?
You can validate the HP60 ink cartridge's electrical health by running the 'Tap 41' diagnostics test (this procedure is specific to the F2480 model). Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test: http://inkjet411.com/?page_id=440
1. While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
2. Release the Power button.
3. The 'Tap 41' diagnostic test print should print.
--- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video on how to read the printout. http://inkjet411.com/?page_id=434
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Sep 01, 2013 | HP Deskjet F2480 USB 2.0 All-in-One Color...
How can I align my HP Photosmart C4680 printer after replacing ink cartridge.
If the new (or refilled/reman/compatible) HP 60 (or 60XL) ink cartridge refuses to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance.
The types of 'more severe' cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", etc.), including blinking power/exclamation lights, typically indicate the internal micro-electronics of the HP #60-61 cartridge are electrically damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you always run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on C4600-C4700 models which use HP 60 cartridges. Refer to Inkjet411 youtube videos below:
HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors & Warnings: http://www.youtube.com/watch?v=BskAfa6NJSg
HP Photosmart C4600 & C4700 Printers - Diagnostics Tap 41 Test: http://www.youtube.com/watch?v=ghxjLCn07Jo
HP Photosmart C4600 C4700 D110a Printers - HP 60 Cartridge Error Bypass: http://www.youtube.com/watch?v=rNVJmKPlLsg
HP Deskjet F2400 F4400 and F4500 Printers - Diagnostics Tap 41 Test:
http://www.youtube.com/watch?v=m-OM09NvNqg
HP Deskjet 4200 Printers - Diagnostics Tap 41 Test:
http://www.youtube.com/watch?v=16uXSBwTan8
HP Deskjet D2500 & D2600 Printer -Tap 10 Diagnostic Test:
http://www.youtube.com/watch?v=RTFOBtdthAc
Mar 28, 2012 | Office Equipment & Supplies
How do i bypass the ink cartridge error on the hp Deskjet F4480? It is saying ink cartridge not compatible but it is a genuine cartridge. And E is displayed on the screen and the light is flashing. How can...
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicate the internal micro-electronics of the HP #60-61 cartridge are electrically damaged - now, these errors can be bypassed on select printer models (temporarily). The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you always run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on C4600-C4700 models which use HP 60 cartridges. Refer to Inkjet411 youtube videos below:
May 20, 2010 | HP F4480 All-In-One Printer
My HP Officejet J6480 all-in-one gives me Cartridge error: Cartridge on right must be replaced. I have changed the cartridge but still get the message.
These types of 'severe' cartridge errors/alert messages (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings: http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart C4200-C4500 and C5200-C5500a Printers - Diagnostic Tap 41 Test: (verifies electrical health of ink cartridges): http://www.youtube.com/watch?v=8fE-IM4AVMc
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
Oct 03, 2009 | HP Office Equipment & Supplies
I am receiving the ?Print cartridge problem-[Tri-Color] refer to device doc. to troubleshoot.? Error message on my Hp j4580. There is no help in doc and nothing I?ve tried (cleaning etc.)works. Should I...
I had the same problem. I called hp and spent an hour running through the troubleshooting things that I'd already done. They ended up sending me a new ink cartridge, and surprisingly, it worked. For some reason, the printer refused to recognize a nearly full ink cartridge. Go figure. It seems to be working for now, but it's a huge waste of ink and money. If you have the patience for it, call hp and see if they will replace your cartridges.
Sep 23, 2009 | HP OfficeJet J4580 All-In-One Laser...
Error 41
error 41 is a printhead fault. The only repair is a new printhead. The price went up this year so a new one will cost you at least $89.00 plus labor.
Jul 29, 2009 | Brother MFC 3420C All-In-One InkJet...
Price of catridge of cannon ip1300
these are the cartridges used in 1300
CL-41 FINE Colour Cartridge
PG-40 FINE Black Cartridge
click here for cl 41 prices
http://www.google.com/products?q=cl-41
Click here for pg-40 prices
http://www.google.com/products?q=pg-40
Let me know if you need anything else.
Thanks,
Ekse
Mar 05, 2009 | Canon PIXMA iP1300 Printer
Compatibility of Ink cartidge.
The MP600 does not use the 40 or 41 cartridges, it uses individual color (and black) ink tanks. But other models (MP190, MP460, MP470, etc) do use these cartridges. The error message you are receiving indicates that the printer does not recognize the cartridge you installed as a valid black ink cartridge. This can mean that either the cartridge is faulty, or that the printer has a problem.
I would suggest trying another new cartridge, and if you still get the same error, to contact Canon for support options if the unit is still in warranty.
Oct 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Error 41
error 41 means that the printhead is defectiv. It has to be replaced. Sorry, no chance to fix it anymore.
Oct 07, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother IntelliFAX 1800C All-In-One Printer Logo
137 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
