Question about Graco Flat Panel Video Sound Monitor
The camera appears to be working fine, but 8-9 months after buying the monitor, in order to get a picture, we would have to turn it off, and then back on (the picture would only stay for a few seconds before going blank). Now, we get no picture at all. Both components are plugged into outlets. We have checked to make sure both outlets are working normally.
    President:
  • 2,468 Answers
You most likely have a thermal issue,as you say it works for a few seconds,then goes blank/black screen,start by checking all internal capacitors on the monitor printed circuit board, then and before you try this what is the warranty on this unit?Parts/Labor.how long from the manufacturer beings its only 8-9 months old,if no warranty,can you tap lightly on the board and get any video response as in flashing on the lcd screen?, then if so theres a thermal issue even though rare on an lcd screen monitor or a defective printed circuit inside this monitor or even possibly an interconnecting cable that feeds this unit from the other pheriferals attached to the monitor
Posted on Nov 09, 2010
Intermittent picture on turn on - constant volume
Hi Ronni McClare,
For better assistance you can contact our Baby Monitors specialist.
http://www.motorolacordless.us/
Best Regards,
Katy
Motorola Support
Feb 24, 2014 | Motorola Mobility Mbp35bl Digital Video...
Some pictures on my dmc-8 lumix are black on the camera view
Try pressing the display button several times. Perhaps you pressed, so the display stays dark. See what happens after shooting when you pressed it once or twice.
Also check how the monitor settings are in the setup menu.
See page 41 and 46 of the (english) manual. The manual you can find online.
Jan 21, 2014 | Cameras
When turn on, two black do appears on the monitor
Moisture got into your camera. Dry it may work or replace lcd screen if available from ebay parts camera.
Jul 15, 2012 | Olympus Stylus 7030 Digital Camera
Error 99 in Canon EOS 350 D
Try the following diagnosis steps, in this exact order. This will isolate the cause of the issue: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Dec 01, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Blurry LCD monitor in Canon PowerShot A85
Sometimes humidity is the problem . Please keep the camera under room temprature and on position for maximum time . For the Battery low problem first try using alkaline or lithium ion batteries and see if they work fine...
Oct 12, 2008 | Canon PowerShot A85 Digital Camera
A Open monitors
replace the power cords
Jun 09, 2008 | AOpen Computers & Internet
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Camera won't turn on at all
Make sure the batteries you try are new and not cheap crap, or improperly charged or old recharghables. You can by a card reader that plugs into your USB for $15 - $50 dollars and download the photos then. Or bring your memory card into just about any photo store to have them put it onto a cd for you which you can then copy onto your computer. $5-$10
Sep 13, 2007 | Vivitar ViviCam 4100 Digital Camera
Monitor won't work
Try adjusting the video connection on the back of the monitor and kinda wiggle it from side to side to see if there's a loose connection. One other thing to check (In case it's a newer LCD) is that the video isn't switched to DVI (It should be automatic, but it can't hurt to take note of this)
Mar 27, 2007 | Jetway M1901DS (Silver) 19" LCD Monitor
Horizontal pixel line
I have seen this B4 here is a link that may help. http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Mar 31, 2007 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Graco Flat Panel Video  Sound Monitor Logo
188 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
