Question about HP Officejet 5610 All-In-One InkJet Printer
My Hp officejet 5610 isn't working
It keeps going to "alligning cartridges" and I cannot fax, print or nothing. what do i do? I tried powering it down and it just goes back to "aligning cartridges" Thanks
  • lynncalverle Jul 21, 2008
    Changed the black cartridge, placed the sheet of paper that printed out on scanner and pressed "ok". After pressing "ok" message reads "alligning cartridges, please wait". Have shut down printer and have repeated above steps, message continues to read "alligning cartridges, please wait".
    Scholar:
  • 107 Answers
Hi ,
when u aliiging cratridge u get one printout , take this print doc & placed on the scanner glass to scan it & press scan bottun for properly aliige cartridges ..this is the right prosiger for allign cartridge
if this information is useful for u please Rate me................
Posted on Jun 16, 2008
I just added new ink in my HP Officejet 5610. The
check expire date
your have clog printhead try cleaning from printer menu
and if it still not alligne s*ck the old ink from the cartridge and refill it with fresh ink
check here how
utube.png You-Tube video "sOriLrbuBao" placeholder (do not delete) utube.png
utube.png You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete) utube.png
Feb 14, 2010 | HP Officejet 5610 All-In-One InkJet...
HP Officejet printer, says cartridges are missing or not detected
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr11
Aug 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp 5610 all in one printer, cartridge error, will not print
hi,
abdsf17
Aug 10, 2009 | HP Officejet 5610 All-In-One InkJet...
J4580 Print Cartridge Problem:[Tri-Color]Refer to Device Documen.
hi i dont have the tricolor cartridge in my hp 5610 and i want to work only with black cartridge and my printer says there is no cartridge on the left , is it posible to solve this problem and work with one cartridge only ? i can print but copy and fax doesnt work . thanx
Jul 27, 2009 | HP Officejet 5610 All-In-One InkJet...
Everything prints blank, but the ink is fairly new and there are no errors showing up on the screen of my HP 5610 all-in-one printer/ copier/ fax
Hi !
As you are using HP officejet 5610 printer, so perform the following steps on the printer to print a self test report to check the functionality of the printer.
Press Setup on the All-in-One then Press 2 then press 6.
If you are unable to perform the above steps, then try to make a copy using the scanner glass ( By placing a text document face down on the scanner glass and then press color copy button.).
If the printer make a copy or prints the self test page, then it confirms that the printer is working fine.
The issue could be with the software side. However, if the printer again prints the blank page, when you try to make a copy or printing a self test, then the issue is with the print cartridges.
Be sure that you are using the Hp genuine ink cartridges not refiled nor re-manufacture. Check the expiry date printed on both the print cartridges.
If all are correct, then perform the below steps to clean the print cartridges.
1. Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridges , from the top to the bottom.
2. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts.
3. The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom.
Then perform the below steps to power cycle the All-in-One unit.
1. Verify that the unit is switched on. Disconnect power cable from All-in-One and also from wall outlet.
2. Wait 30 seconds.
3. Plug in the power cable to All-in-One and also to wall outlet.
Then insert the print cartridges and try to make a copy and check for the result.
Please revert back to me if the issue occurs again.
With regards.
Mike
Jun 29, 2009 | HP Officejet 5610 All-In-One InkJet...
Won't allign cartridges
Reinstall old one let it run through it's cycle then reinstall the new one. This usually works.
Dec 27, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 Fax Failure
You can try resetting the printer.
Step 1. Unplug the power cord at the back of the printer while the printer is still on
Step 2. Press and hold the # and 6 button on the printer while the power cord is disconnected. And keep holdig the two buttons until you plug in the power back again.
Note : do not release the # and 6 when you plug the power cord back in. keep holding the two buttons until the printer would turn on then turn off or the printer would say anything about "reset"
Step 3. Try sending a fax after the successful reset of the printer
Jun 21, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
105 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
