Question about Scuba Diving & Snorkeling
If i lay a pipe 6 inches below the surface of the sea and let it fill up with sea water i lay it out under the sea at a 2 degree angle until it come out of the sea (due to curve of earth) will the sea water pour out of the pipe??
  • 60 Answers
I would say no. The water in the pipe that is above sea level will drop back in the pipe until it reaches sea level. Provided neither end of the pipe whether above or below the sea is blocked the level in the pipe will always find natural sea level so it wont be higher or lower than sea level. So in answer to your question No it wont pour out.
Posted on Nov 08, 2010
Testimonial: "many thanks for your thoughts on that"
We need a manuel for the curve o mark tool
These are the only instructions in the box, the other side of the sheet is a kist of their other products.
INSTRUCTION SHEET
Centering Heads
Curv-O-Mark Centering Heads aid in the setting of centerlines, establishing angles and marks for ****-ins, locating points inside pipes and tanks, laying out keyways and measuring declivity. The standard model (Stock No. 6) is used on pipe 1/2 inch diameter and larger. It has a 4 inch Y-type head and is fitted with an adjustable dial bubble protractor and a manually operated hardened centering pin.
The jumbo centering head (Stock No. 7) is for pipe 1 inch diameter and up. It has an 8 inch Y-type head and an adjustable dial bubble protractor. A spring-loaded hardened centering pin eliminates the need for a hammer.
To quickly and accurately locate the center point on a pipe, shaft or other cylindrical surface, first set the protractor dial at zero (0). Then place the centering head in the vicinity of the highest point of the cylindrical surface.
Move the centering head across the surface until the bubble is centered, then strike the centering pin a light blow. (On the jumbo model, release the spring loaded pin.) The resulting indentation will be top dead center.
If the desired center is at some angle away from top dead center, merely set the protractor dial to the appropriate degree mark to the right or left of zero (0); and then move the centering head around until the bubble is centered. At that point, make the indentation.
The centering pin should be used only in conjunction with the centering head. It should not be used as a center punch. Avoid making unnecessarily hard blows to the pin with a hammer or other objects.
No. 6 Standard Centering Head 0721-0005
No. 7 Jumbo Centering Head 0721-0006
Form 806 R 5-89
Mar 31, 2011 | Garden
How do you replace the water pump?
Hello, ramrodsc2 Removal Procedure 1. Drain the cooling system untilthe coolant is below the level of the water pump. 2. Remove the drive belt guard. 3.Loosenthe waterpump pulley bolts. 4. Remove the drive belt. 5. Remove the water pump pulleybolts and remove the water pump pulley. 6. Remove thewater pump bolts then Remove the water pump. 7. Remove the water pump gasket 8. Clean the water pumpmating surfaces pay particular attention to the cleaning process and make surethe surfaces are clean. Installation Procedure 1. Install the water pump gasket. 2. Install the water pump; tighten the bolts to 10 Nm (89 inchlbs.). 3. Install the water pump pulley.Loosely install the mounting bolts. 4. Install the drive belt; this will help hold the pulley thentightening the pulley bolts. 5. Tighten the bolts to 25 Nm (18 inch lbs.). 6. Install the drive beltguard. 7. Fill the cooling system. 8. Inspect the cooling system for leaks. Regards, netvan
Mar 13, 2011 | 1999 Chevrolet Venture
How to take off the water punp
1. Drain the cooling system until the coolant is below the level of the water pump. 2. Remove the drive belt guard. 3. Loosen the water pump pulley bolts. 4. Remove the drive belt. 5. Remove the water pump pulley bolts. 6. Remove the water pump pulley. 7. Remove the water pump bolts. 8. Remove the water pump. 9. Remove the water pump gasket. 10. Clean the water pump mating surfaces. Installation Procedure 1. Install the water pump gasket. 2. Install the water pump Notice: Refer to Fastener Notice in Service Precautions. 3. Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.). 4. Install the water pump pulley. 5. Install the water pump pulley bolts. 6. Install the drive belt. Tighten the water pump pulley bolts to 25 Nm (18 inch lbs.). 7. Install the drive belt guard. 8. Fill the cooling system
Aug 13, 2010 | 2002 Buick LeSabre
Remove and replace the water pump buick rendezvou 2003 cost and do it yourself instructions . can i do it myself concerned with loosening the serpentine belt and needing special tools?
Visit my Blog here
Jul 21, 2010 | 2002 Buick Rendezvous
Hi, got a Craftsman 20 Hp 42 inch cut , the Deck will not lay flat, it is always on a angle. any ideas ? No matter what the cut height is set at.
Hi tubbed,
Most of these decks are held on at three points. Two are in line 90 degrees from front to back. The other is attached to the height adjust lever.
The first two are adjustable to change the type of angle problems you are having. Make sure you have the engine off when checking. Adjust until the desired angle is reached.
Also, if the model your problem is categorized under does not match your model, the cause of the angle and the solution may be different.
Best regards
Mike
Jul 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do you find an angle measure for the angles XYZ if it looks like it's 63 degrees?
Place you protractor over the angle to be measured. Make certain the centre line is aligned with the apes (point) of the angle and one arm (of the angle) is aligned with the protractor's bottom edge. You can now read off the size of the angle by noting the position of the other arm under the protractor's degree scale.
Mar 17, 2010 | Alvin & Company PROTRACTOR 6 INCH SOLID
How to cut compound miter on a flat surface, where can I find the chart.
It's a combination of an angled mark on the board and the bevel on the saw set to the proper angle. What are you trying to cut?
Jan 28, 2010 | Delta Saws
WHIRLPOOL MODEL ED5NHA NOT MAKING ICE, IN DOOR WATER DISPENSER WORKING FINE, ICE CUBES ARE IN THE MOLDING TRAY, BUT WILL NOT GET EJECTED. FILL TUBE DOES NOT APPEAR TO BE FROZEN?
Most likely the thermostat # 27 in photo below is defective. It tells the ice maker to begin its cycle by sensing the water is frozen. It is a replacale part.
e301f6a.gif Photo of thermostat 627985
aebc09a.jpg You can see or order the thermostat Here 627985
Or you can order the complete Ice Maker Here 2198597
If you need more help feel free to let me know, Thanks Sea Breeze
Oct 25, 2009 | Frigidaire FRS26H5AS Side by Side...
I need to replace the honda logo on the front grill for my 2001 civic. How can i do that ?
Unfortunately the bumper has to come off. The "H" is held on with tiny "push" clips, the only way to push them on is with the bumper off. To remove the bumper there are 4 clips on top of the bumper, when the hood is lifted, they are visable. Use a small screwdriver to pry up the center portion of the clip, there are 6 of the same clip under the bumper. There are 2 screws where the bumper meets the fender (they unscrew straight down, they are not on an angle.) There are also 2 screws under the bumper, below where the headlight meets the sidemarker, in that corner. Once everthing is removed, reach in the wheel well and pull the bumper out, first out to the side, then pull back towards you. Once you have the bumper off, lay it face down on a surface that won't scratch it. Place the "H" in the holes, Lay the clip over the stem and using a 1/4 inch socket, push the clip over the stem while holding the "H". Good luck!
Apr 09, 2009 | 2001 Honda Civic
Scuba Diving & Snorkeling Logo
1,131 people viewed this question
Top Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
