Question about AEG Lavamat W1050 Front Load Washer
AEG Lavamat w1050 stopped before end of cycle - end light flashes 5 times - no other lights on.
3 Suggested Answers
  • 1294 Answers
SOURCE: AEG Lavamat E1050 End light blinks 5 times.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
(Companies just want you to dump the machine & buy another, its keeps them in business)
Posted on Jun 01, 2008
  • 6277 Answers
SOURCE: My AEG Lavamat W 1250
Probably a problem draining.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 17, 2011
AEG Lavamat W1450 Electronic - after about 10 mins of programme machine is making beeping sound and stopping
this is an errorcode !
try to download a servicemanual,
then you can figure out the exact failure -
like : does not heat up etc. ....
May 05, 2012 | AEG Lavamat W1450 Front Load Washer
MY aEG OKO-LAVAMAT 610 WASHES BUT DOES NOT EVACUATE.
Check the drain filter, see if the hose is not clogged (blow it), verify proper operation of the pump and the pressure switch if necessary
May 30, 2011 | AEG Lavamat W1050 Front Load Washer
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
END LED blinks 3 times
Worked out the problem - the heating element was burnt out. Very easy to replace.
Nov 13, 2008 | AEG Lavamat W1050 Front Load Washer
End led blinks 3 times
Had this exact problem (fills, empties and then light blinks three times) and found that the heating element was burnt out. Very easy to replace.
Nov 06, 2008 | AEG Lavamat W1050 Front Load Washer
Water not pumping out and therefore no spinning occurs
Hi, just solved the same problem with our aeg lavamat w 1020. Try checking the filter tray (or port) at the bottom left-hand corner of your machine. This was our problem and as soon as the blockage was removed the machine could be pumped out. It appears to be running OK now.
Aug 14, 2008 | AEG Lavamat W1050 Front Load Washer
Still not working
Press & hold 'end of cycle' for 5 or more seconds. Disconnect from mains for some time, or over night. Then re-start afresh the program.
Jun 02, 2008 | AEG Lavamat W1050 Front Load Washer
Jun 01, 2008 | AEG Lavamat W1050 Front Load Washer
Does not spin when inserting 5.5kg clothes ,only when decreases weight
I'm not a technician, but I own a AEG Lavamat. As far as the owner manual says, this washing machine doesn't allow more than 5 kg.
Jan 12, 2007 | AEG Lavamat W1050 Front Load Washer
AEG Lavamat W1050 Front Load Washer Logo
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
