Question about Maytag Dishwashers
Juice glasses have a white film on them. We filled up the rinse agent and changed dishwasher detergent and still have the problem. In fact it is getting worse. c.m.lee@sympatico.ca
    President:
  • 1,891 Answers
This problem is called ( hard water filming ) use glass majic as your dertgent to clean up the problem. then change to a powder det . and use jet dry for the rinse agent and do do not use heat in the dry cycle . if dw has a tempt boost for the wash yu need to use it . the water needs to be 140 deg in wash for dergent to work . .. hope these help mm .. feed back pls ..
Posted on Nov 08, 2010
There is a white film on the inside of the door plus glasses and utensils.This problem just started a few weeks ago.(the dishwasher is just about two years old). We use cascade and jet dry rinse agent,
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Feb 09, 2011 | KitchenAid KUDS03FTBL Dishwasher
The dishwasher leaves a film residue over all my glasses and other dishes. I changed detergents and rinse agents and it still happens
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 12, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
New soap and rinse dispenser was replaced on August 12,2010,now glasses are coming out with hazy film on them. Rinsing agent does not seem to be coming out of dispenser
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
Dec 12, 2010 | KitchenAid 24 in. KUDP02CRBS Stainless...
I bought this dishwasher 2 weeks ago. The dishes are not always clean, the glasses on the top rack have a residue that gets dried on (white/gritty) and the glasses have a white film on them. I have...
Nov 06, 2010 | Viking VDB450 Dishwasher
I keep getting grit on my dishes, I have changed dishwashing agents, rinse agents, and done evrything I can think of to stop this. what else can I do?
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Hope this helps... Please post back if more information is required.
Daniel
Oct 25, 2010 | Frigidaire Dishwashers
White film especially on ziploc containers and utensils. Glasses come out spotted and clear glass dishes are streaked with a white film
Hi
Daniel
Aug 07, 2010 | Dishwashers
My whirlpool dishwasher is leaving a white hard film on glasses. what do I need to do to stop it
Try a rinse agent. You will have a reservoir in the door of your machine. Fill and see it that helps.
In some areas you have "hard water" which contains a lot of minerals. These can leave deposits on dishes that tend to bake on to surfaces as the dishes dry. In this case you add salt to your unit (again there is a reservoir to hold the salt).
In some cases a given detergent will react with glass, plastic, or ceramic depending again on mineral content and hard water. Changing your detergent can help.
Hope this helps, please rate if it helps get you with direction.
Mar 22, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Why is there a residue being left on my glasses? I tried a rinse agent but it didn't help.
heatman101
Mar 15, 2010 | Kenmore 24 in. 15932 Built-in Dishwasher
White film on dishes, glasses and silverware.
white film is actually from the calcium and magnesium found in hard water. your dishwasher is fine. its the water leaving the residue and spots. go to www.dishwasherfilter.com . they have a new product out exactly for this reason. very affordable and works amazing. you will love it.
Oct 06, 2009 | Dishwashers
The inside of my stainless steel dishwasher looks as if it has a white film on it. My glasses are also looking like they are etched. I haven't changed the dishwasher soap...any ideas what is causing...
are you using a rinse agent such as jet dry( you should be) and if your using tabs with rinse aid built in dont add extra rinse aid to dispensor, . water temp might be an issueperhaps some detergent has gotten into the rinse aid compartment mistakenly
Nov 04, 2008 | Dishwashers
Dishwashers Logo
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
