Question about Makita Garden
I don't know how to fix the blade for makita 4301.pls tell me .Thanks rajan
  • Makita Master
  • 7,733 Answers
How do you adjust the replacement blades in a Makita planer if you don't have to original gauge?
The blades, at thier highest point in rotation, need to be exactly the same height as the larger back plate. Any straight edge laid on the back plate and extending over the blades will let you know if they are set properly. The straight edge should not contact the blades when they are turned (by hand) and there should be as close to no gap between the straight edge and blades as you can get.
Mar 05, 2012 | Makita 3-1/4" Planer Kit N1900B
I cannot get the blade on my Makita 2708 table swa to retract completely. I always leaves !/16" protruding above the table surface. Can you tell me how to fix this?
It likely has too large a blade. It may be a 9.5 inch saw with a 10 inch blade on it. This can go unnoticed until you want to use the router mount or somesuch. Otherwise, it could be debris on the screw base.
anyway, that's where I would start.
Farmerbear at Fixya
Oct 27, 2010 | Makita Saws
How do I install the spring after changing the blade on the Makita 10 miter saw
what spring? do you mean the one in the guard? if so you don;t have to remove it to change the blade, give me the exact model number or you can go to makitatools.com and download a breakdown that shows the reassembly of the guard, it is not that hard, and also you can download an owners manual that shows the proper blade replacement procedure.
Jan 16, 2010 | Makita 10" Miter Saw LS1030N
Makita 4304T. jigsaw blade Do not know how to fasten it?
On the top of the Makita 4304T is a knob, (Top/Front)
This is the blade Installing Lever.
Viewing the jigsaw in the direction you would use it, the Installing Lever is turned towards the Right. Keeping it turned, you then install the jigsaw blade. Once you have the blade up in the Blade Holder, gently release the Installing Lever.
This is a PDF file of the Owners Manual for the Makita 4304T Jigsaw,
(From Makita - Products - Support)
http://www.makita.com/en-us/Assets/images/Products/4304T/owners_manuals/4304T.pdf
[Should the above direct link not work for you, this is Makita - Products -Support, and the download page,
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=248
Left-click on Owners Manual next to the PDF file Icon]
Nov 04, 2009 | Makita Jigsaw Blade
Blade popping off front wheel
Is the axle tight? Has the tool been dropped to warp the frame? But a quick fix if everything else is OK is to loosen up the axle and put a THIN metal shim on the backside of the axle and then tightening it back down.
Jul 29, 2009 | Makita 2107F Portable Band Saw
I AM LOOKING FOR CHARGER FOR TYPE 6347D BATTERY IS 1822 18v 2.0 Ah ..... I WANNA BUY IT FROM EBAY BUT DON´T KNOW WCHICH TYPE CHARGER IS SUITABLE FOR THAT.... WILL I GET A GOOD ADVICE FROM ANYONE? PLS
The charger you need is Makita charger DC1801. If you do a search for "DC1801" on ebay you will find heaps of those chargers on there!
The DC1801 charger will charge the 6347D 18v 2Ah Makita NiCad pod-style battery.
Jun 18, 2009 | Makita BHR200SAE Cordless Rotary Hammer
Makita Saw blade brake doesn't work.
If the model number is right it could be a couple things, I would try and blow the motor housing and area surrounding it with compressed air. Second I would FIRST unplug the saw and remove the brushes and check the condition, if they appear burnt I would replace them, if there is dirt or worn brushes it could cause a problem but before I got deeper into this tool I would recommend checking the date of purchase and seeing if it is still covered under warranty. This a fairly new model for them. If not let me know and I will look at a schematic for this and try and help more in depth.
May 03, 2009 | Makita 10" Miter Saw LS1030N
FITTING DETAILS FOR MAKITA PLANER BLADES
It depends on the planer blade set that you are using. If you are using the the 2 sided blades there is a guage that goes with it to set the blade depth before installing. I would strongly recommend that you go to Makitatools.com and type in your model number and download a copy of the owners manual for specific instructions. Let me know if you have any problems finding them
Mar 08, 2009 | Makita Planer Replacement Blade, 3 1/4"
I need wiring details for makita jig saw 4301bv
I have a little bad news for you. Makita doesn't furnish their wiring schematics online and I checked a couple other sites and nothing but you can call 1-800-4625482 that is their free technical support line and they can get you one.
Feb 20, 2009 | Makita Saws
Garden Logo
37 people viewed this question
Top Makita Garden Experts
Jim Parker
Jim Parker
JOHN LAPIER
Keith Thompson
Level 1 Expert
Are you a Makita Garden Expert? Answer questions, earn points and help others
