Question about Sony CLIE PEG-TG50 Handheld
Recording Error Hi, I've been using the Voice Recorder in my TG50 with a Memory Stick, but suddenly this application is raising an error while recording or playing the audio data. The error message while playing is "Error Data: This data format is not supported" The error message while recording is "Recording Error" The preferences are setup as follows: Enable Operation Beep Mic Sens: High Recording Mode: LP List/Rec. Media: MS Maximum size for recording Internal: No Limit MS: No Limit I've changed the memory stick, but I get the same error. However, I can record and play internally. Can anyone help me out? Thanks, amaburto
vega
  • 551 Answers
SOURCE: F55 - Memory Stick Limit? MPEG Frames per Second?
I don't know what the exact frame rate is, but it's fairly low. I reckon about 8-10 FPS, which is more than good enough to put on a web page or to email to someone. If you need anything higher quality wise, then you're better off looking at a mini-DV camcorder ;-)
Posted on Sep 08, 2005
KWONG
  • 18 Answers
SOURCE: Sony Clie n760 memory stick not detected when inserted
Do you share this memory stick with other devices? If you pulled out the memorystick before the device(s) were finished closing the connection, the card may be corrupted. Another thing may be because your memory stick may be too large for your handheld to support. if you don't wanty to refund your $ just shrink the memory stick into a gig or less. You have to have a pc with a memory card reader that supports memory stick. just open up my computer> right click the memory stick> Fortmat and select a smaller size to format to.
Posted on Jul 04, 2007
  • 1027 Answers
SOURCE: Memory Stick File Error
Could be that the camera does not support a 2G stick. Check the operators manual.
Posted on Aug 31, 2008
charcois
  • 763 Answers
SOURCE: memory stick recording
that means your camcorder is set to record on the disc not on the memory card. try to look on the settings on your camcorder there's an option fo you to choose like disc or memory card to be use as recording. hope that helps!
CHARCOIS
Posted on Sep 19, 2008
  • 7993 Answers
SOURCE: I purchased a Sony cybershot DSC- S930 and
The camera does not recognize the card because
1. Card not compatible
2. Camera cannot handle such a large capacity.
3.Card not inserted correctly.
Maybe a recent firmware update can address the 2nd limitation.
Hope it helps.
Posted on Sep 11, 2009
How long it can record voice with a memory stick of 2gb and its built in memory
you should get around 6hrs 13 mins on a 2 gig card recording audio only
May 31, 2015 | Sony ICD-MX20 Digital Voice Recorder
How resolve recorder olympus vn-3500pc memory error
could be corrupted memory. leave battery out of recorder for a couple days to allow the recorder to reset... get new batteries.
May 20, 2011 | Olympus VN6200 Digital Voice Recorder
It freezes on the opening page - the one that says R-09HR WAV/MP3 Recorder VER 1.05 it doesn't move onto the normal home screen and it won't let me upload anything from the memory disc. The...
hi,there are two thing that causes this problem the hardware and the software application system.If the application is corrupted the system will not open and gets freeze.Hardware problem will also causes the system to freeze during power on.To get this error resolve I would suggest to bring your recorder to the service center.. good luck and thank you for consulting fixya..
Apr 07, 2011 | Edirol R-09 Digital Voice Recorder
MY SONY CYBER SHOR DSC-W270. IT SHOWS SYSTEM ERROR WHEN TURNED ON.
The System Error message displays when the files on the recording media have been copied or deleted repeatedly on a computer. Backup the files on your computer, then format the recording media in the camera to resolve this issue.
Formatting the Memory will erase all the data stored in the Memory Stick.
If the error message displays after formatting the Memory Stick, then try using a different Memory Stick media. Once the Memory Stick is inserted, perform manual power reset of the Camera.
To reset the Camera, turn off the Camera and remove the battery pack.
Then, allow the Camera to remain without power for 30 seconds.
Later, re-insert the Battery pack in the Camera to resolve the issue.
Thanks for using FixYa.
Jan 10, 2011 | Sony Cyber-shot DSC-W270 Digital Camera
Digta 410 fat error
Try formatting the memory - or try using an external memory card (SD).
May 28, 2010 | Grundig Digta 410I Digital Recorder (32 MB...
I need to know how to use the memory stick feature on a Sony digital recorder.
Here is the URL for the manual for your recorder =>
http://esupport.sony.com/US/perl/model-documents.pl?mdl=ICDMX20&LOC=3
Essentially you just plug in the Memory Stick, wait for the display to stop showing "ACCESS". Make sure you do not insert the stick when you are either recording or playing a message. There is a chart that shows you how many messages you can record using the different speeds.
Jul 14, 2009 | Sony ICD-MX20 Digital Voice Recorder
SAMSUNG SGH-F400 mobile phone: voice recording help!
check the options on the voice recorder in the applications.
Jan 10, 2009 | Samsung SGH-F400 Cellular Phone
Write protection
Refer to your Owner's manual to re-format your recorder. Sometimes, recorder memory can become corrupted just as with any electronic memory media.
Dec 26, 2008 | Olympus WS-100 Digital Voice Recorder
Not recording
At first set the recording lenght on your phone(example 5 min) and then start recording, after the recording length is completed it automatically saves your recording file
Jan 31, 2008 | Panasonic RR-US360 Digital Voice Recorder
Sony CLIE PEG-TG50 Handheld Logo
57 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
