Question about RCA HD52W59 HDTV Projection Television
How bmany fuses are there in my rca hd52w59yx39
    Sergeant:
    Champion:
  • 293 Answers
Two fuse only.In AC supply and in the DC supply.
Posted on Nov 08, 2010
Hd52w59yx39, no convergance auto or manual, shows in menu, but allighnment crosses refuse to move, slight hour glass screen top and bottom, may have taken a lightning strike?. Is there an actual manual...
This tv may be one of them with 3 small brown square shaped fuses next to the high voltage transformer on the deflection board. The middle one is the one that will be bad. Usually some solder connections will have to be repaired that caused the fuse to go bad.
Oct 23, 2009 | RCA HD52W59 HDTV Projection Television
Bowed at top and bottom
No amount of cleaning is going to fix this problem, Go to menu look for setup see if you have convergences listed on menu if so try auto converge. If convergence is not on menu then you have a open fuse next flyback transfomer FL231 middle fuse.
Nov 10, 2008 | RCA D52W19 52" Rear Projection Television
HD52W59YX39 - TV Menu screen popps up at random - not a remote problem.
very good troubeshooting.... it will be the keyboard. i have seen this in the shop alot. just fixed one about hour ago. the board rca 271867 try union electronics thats where i get most of my parts. this is a simple board replacement why pay 150 for something like this
Oct 11, 2008 | RCA HD52W59 HDTV Projection Television
RCA D52W20 52 Fuse problem
Well you could always use a bigger fuse but I would not advise to do it, it could and most likely will blow tv not fuse. Fuses ussually blow from a short or power surge. If it is new or under warranty I would return it for replacement or repair.
Jul 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
HDTV MODEL HD52WS9YX39 SERAL NUMBER 6116CNO13
please recheck your model# it should read HD52W59YX39 if this is the correct model the part # is 271850 cost $166.99
changing this part will cause major alignment
the part can be replaced - the RF part # is 215543 for $4.39 or the tuner can be changed part # 268904 cost $30.39
on another note if you are using a cable box or sat box there is no need to repair the rf hooke the tv up with rca plugs
https://www.vancebaldwin.com
thanks
scott
Jun 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where can you purchase parts for a hd52w59yx39????
go to this link and leave an email with your model number and what part youre needing they will be able to help you out.
http://servicemanuals.vstore.ca/
May 11, 2008 | RCA HD52W59 HDTV Projection Television
Replaced convergence fuse tv worked then shut down
Sounds like the convergence power supply is defective. If you need more info let me know
Apr 29, 2008 | RCA HD52W59 HDTV Projection Television
Convergence
Two boards govern this circuit . 1) convergence power supply board # 271860 2) convergence amplifer # 271861 . In most cases amp board is your problem . You might want to check the amp board for loose connections on it .Most of the times its the cable sockets on the borad have loose pins . This the board that has the metal heat sinks in a row of about nine of them on the board . Good luck
Mar 11, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
32 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
