Question about Dell Latitude D505 Notebook
MY COMPUTER WONT BOOT UP IT KEEPS READING WINDOWS COULD NOT START BECAUSE THE FOLLOWING FILES ARE MISSING OR CORRUPT; SYSTEM32/DRIVERS/ISAPNP.SYS I DONT HAVE THE CD SO WHAT CAN I DO TO FIXS THIS HELP...
You have to copy the isapnp.sys file from the original cd or else from any other laptop to start up your windows correctly.
Posted on Nov 13, 2010
System32 drivers ntfs sys
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command):
  6. --->cd \windows\system32\drivers
    --->ren ntfs.sys ntfs.old
    Note This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  7. At the command prompt, type the following command, and then press ENTER:copy cd:\i386\ntfs.sys drive:\windows\system32\drivers
    Where cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  8. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  9. Restart the computer.
May 17, 2014 | eMachines Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Windows could not start because the following file is missing or corrupt: System32\DRIVERS\isapnp.sys
This usually occur when unexpectedly deleted or corrupted the files cause by a virus or a third party software. All you have to do is repair your OS using your installation CD(XP) and do not reformat your HDD. Reboot your PC using your XP follow the instruction needed then when it come to the Repair, Do Not Repair, or Don't do anything choose Repair and follow again the instruction.
Apr 24, 2011 | Computers & Internet
Windows did not start ,drivers missing
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer
Mar 03, 2011 | Computers & Internet
Ntfs is missing
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
Jan 10, 2011 | Microsoft Windows Vista Home Premium with...
WHEN TURNED ON IT SAYS "WINDOWS COULD NOT START BECAUSE THE FOLLOWING FILE IS MISSING OR CORRUPT: SYSTEM32\DRIVERS\ISAPNP.SYS
Hi in this case you need run your windows cd and choose option for install then it gonna detect that you've got windows instaled already and give option to repair it if you need more help let me know
Aug 26, 2010 | Dell Inspiron 1501 Notebook
System32/DRIVERS/pci.sys
ITS EASY JUST COPY THE FILE pci.sys from any other computer from System32/DRIVERS/pci.sys .SOUNDS FUN?BUT I KNOW IT WORKS
Mar 27, 2009 | Computers & Internet
Computer will not boot up.
Boot up your Windows XP on your drive.
Since you have been on that process I assume that you already know those things prior to this solution. I'll just continue the subject after it load all the drivers.
Solution:
1) After you get the "MENU" screen that has a selection of
  • Install XP press "Enter"
  • Press "R" to repair
  • Press "F3" to quit
Select to "Install XP"
2)After you will get a End User License Agreement (EULA), then Press "F8" to accept
3) Then another menu that was stated above. Then this is the time you select the REPAIR option
If you find this Solution helpful please Rank me.
Thank you.
regards,
-engrkoiled-
Mar 27, 2009 | Dell OptiPlex GX260 PC Desktop
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
System32.ntfs is missing and corrupt
Boot into recovery console, and at the c:\windows prompt type: cd system32 cd drivers ren ntfs.sys ntfs.old If the ntfs.sys file is there and corrupt this will rename it. If it is not there, then it was missing. At the prompt type: copy e:\i386\ntfs.sys c:\windows\system32\drivers\ntfs.sys good luck
Mar 19, 2006 | Apple Power Supply 344 Watt PowerMac G4...
Dell Latitude D505 Notebook Logo
132 people viewed this question
Alun Cox
