Question about Sharp AR-168S Copier
Unit plugged into live receptacle and nothing works. Is there a fuse that could be blown?
  • Sharp Expert
  • 1,326 Answers
There is a power switch on the left side of the copier, I know you tried to turn it ON. The switch is attached to the power supply. To get to it , it is under the paper exit tray and I believe there are two screw on the side and maybe one in front with the front door open. I can't really say that I've replaced a fuse on the PCB, but there are a few on it. The problem is the switch itself goes bad. The only down side is that it attached to the PCB as one part number. I would try to turn the switch ON & OFF a few times and it may turn ON. Good Luck
Posted on Nov 08, 2010
Two specific fuses keep blowing immediately - even before the instrumentation they govern can be utilized.
take it back to the dealership where you bought it. You have a dead short to earth in those circuits.
May 29, 2016 | Cars & Trucks
When I turn the piano on, nothing happens I checked the plug-in but still nothing happened. I just played the piano a couple of days ago and it was fine. Do they have fuses which need to be...
I woulld not even venture a guess as to what brand/model/ etc you have. How do you expect us to have any idea to help you?
I will say that a very common problem is if the unit, whatever type it is, has a power adapter, it is COMMON for the plug to work loose... If your unit has a regular cord, then there are likely fuse(s) inside, but if they blow, there is another problem that must be repaired before fuses are replaced.
Does the unit have any lights or displays that show power is on? If nothing is lit, then VERIFY that the cord is plugged in at both ends... ANOTHER problem is that SOME wall receptacles are switched... intended for floor lamps and if one has the switch off the receptacles is dead...
Again, you haven't given us enough info to really help you...
Nov 10, 2010 | Music
Model ftx26-1 stopped half way through brew cycle. Now clock doesnt appear to work. I thought perhaps I put in half enough water, so I added some-nothing. The clock shows no hour, minute or second hands. I...
Sounds like there is no power to the unit. Are you 100% sure the receptacle it is plugged into is working? If it is in a kitchen it may very well be plugged into a receptacle that is protected by a GFIC. Look and make sure one has not tripped. If you find out that the receptacle is good and power is reaching the unit, then it may have an internal fuse. It is highly unlikely the heating element and clock went bad at the same time.
Dec 12, 2009 | Mr. Coffee TFTX85 Coffee Maker
Unit not running, not cooling electronic
To operate, a refrigerator needs electricity. If the refrigerator's light doesn't work and it's motor doesn't run:
1) Check the power. Make sure the receptacle works (plug in a working lamp or a circuit tester). If the receptacle doesn't work, check for a tripped circuit breaker or blown fuse.
2) Be sure the cold control is turned on.
3) If you discover that the refrigerator is plugged into a working outlet and the cold control is on but the device shows no signs of life, leave the door closed to retain the cold air and call an appliance repairperson
Jul 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Microwave has no power
1st try to un-plug and then re-plug after a few minutes to reset... if that does not work, then your internal ceramic fuse is probably blown. You can get one at radio shack for $3.... Always start though by checking to make sure the breaker for the receptacle that the unit is plugged into is still set.
Steve
Jan 20, 2009 | Maytag MMV4205 Microwave Oven
My mixer wont start
First of all plug another appliance into the receptacle to make sure you have power there. If you don't have power at that receptacle you have blown a fuse or tripped a circuit breaker. good luck
Jan 16, 2009 | KitchenAid K45SS Classic Stand Mixer
Microwave
Mst likely a blown fuse. You''ll need to unplug the unit, remove the outside cover and follow the line cord and you should find the fuse.
Replace it with the EXACT same value that was labeled on the original fuse. You'll probably be able to find a replacement at any Radio Shack store or hardware store.
Replace the cover and plug the unit back in. Hopefully nothing was damaged and the unit will play again.
Please let me know if I can be of further assistance to you.
- Jim
Mar 03, 2008 | Panasonic NN-T994SF Microwave Oven
Receptacle Doesn't Work
By far the most common problem with a receptacle is that it doesn?t work. Because receptacles are very inexpensive and easy to replace, it makes sense to replace them when they cease to work properly. But before you go to the trouble of buying a new one and installing it, make sure that the old one is truly defective. For a non-working duplex receptacle, first make sure the problem isn't with the appliance or lamp. Some appliances, such as hairdryers, have overload protectors that automatically shut them off if they begin to overheat. Try a second appliance or lamp in the receptacle. If the receptacle still doesn't work, you'll usually find that the circuit breaker has tripped or the fuse has blown, the receptacle has become faulty, or there is a switch that operates that receptacle and it needs to be turned on. The problem is rarely the wiring. 1) Test the receptacle with a second lamp or appliance. 2) Be sure that one half of the duplex receptacle (or the entire receptacle) isn't controlled by a switch in the room. 3) Check the circuit breaker (or fuse) for that receptacle's circuit to be sure it has not tripped (or blown). If it has, reset the breaker or replace the fuse, and try plugging a working lamp or appliance into the receptacle again. 4) If it still doesn't work, turn off the receptacle's circuit breaker, unscrew the cover plate from the receptacle, and use a voltage tester to be sure none of the wires in the electrical box are still "hot." Then check to be sure that the wires are securely fastened to the receptacle's terminals. 5) Look for signs of charring. Replace the receptacle if it looks damaged. 6) Put the cover plate back on, turn the circuit back on, and try the receptacle again. If it still doesn't work, turn the circuit back off, remove the receptacle cover, and replace the receptacle with one that has the same amp and voltage ratings. 7) If this doesn't solve the problem, call an electrician.
Jan 18, 2006 | APC MasterSwitch Power Receptacle - Power...
TCM400 will not perk
Assuming you have power to the receptacle the unit has probably blown the thermal fuse. They are in line with the power to interupt the circuit if the unit gets too hot but over time they will blow out from all the heating cycles. The fuse looks like a small metal cylinder and come in various ratings. You need to replace it with the same rated fuse. They are available at most Electronic parts supply stores.
Dec 17, 2005 | Black & Decker TCM400 Coffee Maker
Sharp AR-168S Copier Logo
21 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
