Question about Honeywell Heating & Cooling
I have a honeywell tstat RTH2310B that we hooked up recently to use with an internal gas furnace and an external a/c unit. It was working fine with the a/c now it is time to use it with the heater and there is something wrong. When switched over to heat we have to turn the temperature setting below the current temperature reading to get the heater to turn on, which means the heather will constantly run until we turn the unit off. I have checked the wires coming out of the furnace and they all match the color of the wires that are plugged into the thermostat, there is a jumper between the Rh/Rc with the red wire hooked into there;the other wires connected are W,Y and G. There is also a blue wire that isn't connected to anything and tucked back in the hole behind the thermostat. I have tried some of the posted solutions I could find here and have had no luck so now I am looking for help.
Posted on Nov 28, 2010
    Genius:
  • 1,015 Answers
You might try disconnect Rc and Rh by removing jumper wire. reconnect red wire to Rh and see what happens.Good luck. Thanks
Posted on Nov 08, 2010
My unit is a Honeywell and not a Muirfield.97-4118/5-89 and it will not work on auto but works on manual.
If it's a new thermostat that you have recently installed, check your installer configuration. Make sure the tstat is set up for gas or electric heat, depending on what you have. Some t-stats also have a small switch on the back to switch from gas to elec. A gas furnace has components to control the fan, electric unit uses the tstat to control the fan. Hope this helps!
Mar 21, 2017 | Honeywell Heating & Cooling
THERMOSTAT WILL NOT COME ON.
You may have missed the fuse. It will/should be part of the control board and has a 3 or 5 on it. You can jump R to G at the tstat by touching them two together. If you don't feel comfortable doing this then don't do it. G will bring on the fan only. And if it starts then you probably have a bad tstat. If not, then you have a short that damaged your 24volt transformer, or lost power to the whole unit. Check your breakers!
Mar 10, 2017 | Heating & Cooling
I just bought a Honeywell 5.2 Day RTH2300B Programmable thermostat to replace my old mercury thermostat for my gas fireplace. When I took of old thermostat it only has two wires. A white wire and a black...
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Dec 06, 2010 | Honeywell Focus 6300B 5-2 Days...
From the Isolator panel, how do I connect the condenser, and the blower?
MOST UNITS NOT HEAT PUMPS  WIRE UP WITH 2 WIRES TO CONDENSER RED WIRE AND WHITE . WHITE GOES TO COMMON C ON FURNACE AND RED TO Y TERMINAL OF FURNACE Y ALSO GOES TO Y ON TSTAT. BOTH YELLOW WIRES MUST MEET AT Y OF FURNACE.  WHITE FROM STAT TO W   GREEN FROM TSTAT TO G AT FURNACE IF YOU HAVE C ON TSTAT HOOK UP BROWN WIRE OR BLUE FROM COMMON TERMINAL WHERE YOU HOOKED UP CONDENSER WHITE WIRE AT FURNACE TO TSTAT , MOST THERMOSTATS DONT NEED C RUN FROM FURNACE. THE TWO WIRES GOING TO CONDENSER IS -  AND + TO ACTAVATE CONTACTOR IN OUTSIDE UNIT
Apr 19, 2010 | Ruud Central System Air Conditioner
My honeywell t-stat reaches current temp setting and furnace kicks off...but within 1 minute the t-stat drops 1 degree and the freakin furnace kicks on! This can't be right as it has never happened with...
Your differential is set to close you can go into tstat and change differential setting. Your install manual for your thermostat will tell you how you can set 1.2.3 degrees differential
Dec 13, 2009 | Honeywell Electronic Programmable...
Thermostat will not turn on for air conditioning
Turn fan to on position to see if fan runs. Is this new tstat. Digital or manual tstat. If digital check back of tstat to see if tstat is set to gas heat. Rus
Jun 21, 2009 | Honeywell Programmable Thermostat Heater
Need to hook up a honeywell rth2310b with only 2 wires!
In some situations the wall plate has no markings, there are just two terminals hooked up to the control wire for the heater. I just installed this thermostat on my gas fireplace. I connected the black wire to the Rc terminal and the white wire to the W terminal. With the thermostat set to heat it works perfectly. Thanks to johnptaylor for the help!
Jan 26, 2009 | Honeywell Focus 6300B 5-2 Days...
Hooking up new thermostat to new furnace
Letter designations for honeywell tsats R=24 volt power, W=heat, Y=cooling, G=fan, C=common wire for the 24volt power to tstat. Generally R is the red tstat wire and so on. Blue tstat wire can be hooked up to common at the tstat. On the heater the blue tstat wire would be hooked up to the C terminal. But this also depends on the manufacturer of heating unit.
Jan 22, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
207 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
