Question about Boating
I have a 61022 Ray Line/Jabsco search light that has quit turning or tilting. Does anyone know where to get replacement gears/motors?
Jabsco model 37010-0090 electric head. sometimes no motor run or flush when button pressed. By turning slotted shaft on end of motor , button then activates motor and flushes.
Sounds like the motor commutator and brushes need some attention. Not a difficult job if you have been there before but it can be tricky for a novice.
Oct 14, 2013 | ITT Jabsco Manual Marine Toilet Compact...
Need wiring diagram for jabsco 135 searchlight
I have an older unit, but this might help...
Thick Black wire is Earth or Ground
Thick Orange wire is Spotlight feed +
Thick Grey Wire is Flood feed +
Green and brown wires are motor up/down
Yellow and Blue are motor Left and right.
Sep 23, 2012 | ITT Jabsco Jabsco 135 Sl Remote Control...
Where can I buy the reflector for a ray-line #41120-1110
Did you ever find a source? I am looking for a bulb for this same unit, and also a gear mechanism for tilt.
Apr 23, 2012 | ITT Jabsco Jabsco 135 Sl Remote Control...
We have 2 Jabsco Flexmount continuous duty 4" blowers in our engine room on our yacht. These still work after 8 years but getting quite noisey. Your suggestions on what we can do to improve the...
The first step would be to identify whether it is the blowers themselves that have become noisy - could be due to a build up of dirt, particularly on the fan blades affecting their balance, or could be that the motor bearings are getting a bit worn.
An alternative source of the noise might be that the mountings or any connecting hoses have become harder over time and are therefore transmitting more vibrations to the structure of the boat.
Mar 23, 2011 | Jabsco 3 Flexmount Blower 105 CFM 12v 360...
Light turns on and moves up and down but will not go from side to side only clicks, I removed the light and the gears looked good. could it be the control itself?
Chances are that it may be a ceased motor assy.
I had same problem & solved it by replacing motor assy.
Suggest unwire it & remove from unit and apply 12v to terminals (either way round)
If the gear wheel does not turn slowly then that is where your ploblem lies.
Replacement motor not excessively expensive.
Aug 03, 2010 | ITT Jabsco Jabsco 135 Sl Remote Control...
Xerox Phaser 8400 first page blurry
8,009.4x:CAP_FAULT_MP_NO_ CLUTCH_STALL:
  • The media path motor has stalled while moving without the clutch engaged.
33,001.4x - TM_DEV_FAULT_MPT_WIDTH_VALUE_TOO_LOW
  • Tray 1 status:
1. Check the wiring and connectors from the front door to the I/O board.
2. Run the Test Tray 1 Width Sensors.
3. If the test fails replace the front door.
4. Replace the I/O board.
08.055.44:
  • The media path drive module has stalled while engaging the head tilt.
37,008.44:
  • The Preheat preheater is not drawing the expected power from the supply.
Run the Preheat Heater test, check the wiring. If test fails and no apparently problem is evident, replace the preheater.
05,002.42:
  • Problems with the Y-axis. It could be the belt,motor or the drum.
7,008.4x: PM_FAULT_HEADTILT_NOT_ ENGAGED
  • The printhead tilt is not engaged, so it didn't tilt back properly or the printhead is stuck in the tilted position by the tilt lock arms. The process motor gear train getting out of sync can also cause this error.
1. Try rebooting the printer.
2. Check for an obstruction or damage in the process gearbox.
3. Ensure the gears are correctly aligned and homed. If faulty replace the process gearbox
assembly.
4. Run the Tilt Axis Drive test to test the headtilt.
5. Run the Head Maintenance Wiper Clutch test. If the test fails, replace the wiper drive clutch.
6. Run the Wiper Axis Drive test.
7. Replace the exit assembly.
7,010.4x: PM_FAULT_HEADTILT_HOME_ERROR
  • The printhead is stuck in the tilt position by the tilt arms. The process motor gearbox being out of sync can also cause this error.
1. Reboot the printer.
2. Verify the lock arms rotate correctly.
3. Check for spilled ink around the printhead.
4. Check the process motor gears for damage. Ensure the process gears are correctly aligned and homed.
5. Verify the process gear box, process shaft, and drive module shaft are at home position.
6. Verify the headtilt gear will engage, see the home positioning procedure on page. You can manually engage the headtilt gear.
7. Run the Tilt Axis Drive test.
8. Run the Process Motor test.
9. Run the Head Maintenance Clutch test, if the test fails replace the clutch.
10.Run Wiper Drive test. If this fails inspect the wiper drive system.
Aug 26, 2009 | Xerox Phaser 8400 Laser Printer
I have a jabsco 8'' searchlight, it slews however the light went out, is this replaceable or is a whole new unit needed.
Seems like it MUST be replaceable. Look it up on the net. http://www.google.com/search?source=ig&hl=en&rlz=1G1GGLQ_ENUS331&=&q=jabsco+searchlight+parts&aq=1&oq=jabsco+searchlight
Jun 16, 2009 | Boating
Error Code: 07,010.43:263647 The printer gives me the code and automatically powers down. Anyone know what this means, and how I can fix it?
From the service manual:
replace the clutch.
drive system.
Since posting all these test would be impractical, let me know if you need the service manual and I can send it your way. Thanks and please take a moment to rate as fixya.
Mar 10, 2009 | Xerox Phaser 8400 Laser Printer
I SEARCHED. PS3 not loading discs after lens replacement
http://www.llamma.com/PS3/repair/PS3_disassembly_tutorial.htm
That what you need?
Feb 05, 2009 | Sony Playstation 3 (PS3) Console
Boating Logo
82 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
