Question about Maytag MSD2756G Side by Side Refrigerator
What is the correct temperature setting for Maytag side by side refridgerator/freezer?
    President:
  • 1,891 Answers
Set the freezer side all the way up and back one / look for a tempt of 0 to 5 deg and the fresh food side 38 deg this is about 1/2 way up on dial like a 4 or 5 . .. you need to work with these as they use # not tempts . hope this helps mm feed back pls
Posted on Nov 08, 2010
Water keeps flowing onto the floor of the bottom freezer and freezes...I keep chipping it out, but it keeps coming back...I have made sure the temperature settings were correct, and still no change. This...
You have a defrost drain that is plugged. You need to figure out where and clean it out.You might be able to get to it from inside the freezer on some models and others you need to get to it from the back of the refrigerator. Hope this gets you on the right track.
May 16, 2011 | Maytag Refrigerators
How should I set the temperature. The refridgerator and freezer is not able to maintain a consistent temperature. What is the correct freezer and top refridgerator setting and how do I know it has accepted...
Basically the thermostat controlls the freezer temperature which turns the compressor on and off.
The refrigerator section receives cold air from the freezer to cool it down.
So when the freezer is off there may not be enough cold air left for the refrigerator.
Fridges can never give you a perfect temperature every time there will always be a drift one way or another.
Once you reset the temperature the numbers or an led should blink at you to confirm the changes you made
Mar 25, 2011 | Liebherr KGK 2833 Comfort Bottom Freezer...
Hi I have a side by side fridge freezer and my refridgerator temperature is 10c i have the temperature set at 7 the highest. It was at 6 but it wasn't getting cold enough. Can you please help. thanks...
Sherree, do this simple check open your freezer door and feel the back panel in your freezer section. If you feel frost on it then a repair is required of the possible of 3 items that could have failed defrost heater, defrost bi-metal thermostat, or defrost controller and is going to require disassembly of the freezer panel and electrical checks as well as the defrost controller. but if it can wait until monday then a serviceman can diagnoise the problem and repair it.
Feb 27, 2011 | Maytag Refrigerators
I have a Maytag plus side by side refridgerator-freezer. The freezer works properly, but the refridgerator temperature is to high.
While you look into the back of the freezer compartment to look for ice or snow collecting on the back panel of the freezer. Let me know what model you have and I will be able to help you with part numbers what you need to do next. Let me know the model number listed most likely in these places, Thanks Sea Breeze
Jul 20, 2009 | Refrigerators
My Jenn-air refridgerator model JCD2389GEW is not cooling
turn freezer to higher temp and turn fresh to lower temp this maximizes airflow into the refrigerator. check the door that regulates airflow into fresh side..see if its stuck closed for some reason. good luck! :)
Jun 11, 2009 | Refrigerators
Maytag refridgerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 06, 2009 | Maytag MSD2651 HE Side by Side...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Maytag side by side refrigerator
fridge has timer to adjust for defrosting, but the not working working you to manual defrost the unit to avoid ice formation inside the fridge.
Dec 30, 2007 | Turbo Air 49 cu. ft. / 1388 liter...
Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Sep 03, 2006 | Maytag MZD2768G Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
159 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
