Question about Linksys WRT160N Wireless Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
  • Linksys Master
  • 7,733 Answers
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
linksys no longer appears on - kb3676-005_en.pngWindows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Posted on Nov 09, 2010
Im hooking everything up right as im going through the 4 step intallation disk and it says Your new router does not appear to be connected properly.
make sure the cable going from your laptop/computer is connected - you NEED to be connected! or if you are going wireless and you know that your laptop wireless adapter is working and you can see the default wireless network - which is "linksys" (without the quotes) you should be able to connect to it and configure it without the CD..
Dec 30, 2009 | Linksys Wireless-G WRT54G Router
When laptop switched on dell logo appears then windows logo fails to appear and a blue screen with fatal system error appears and have to switch off
restore your computer using the restore partition or restore cds, you can try to do a repair install of windows but sometimes that can hurt rather than help. if you want to f ind out the reason why hit f8 at boot and scroll down to 'do not restart computer after system failure' and hit enter, when it fails again it will give you a stop code looking similar to 0x00000000 that will give us a little better idea of what the issue is.
Nov 21, 2009 | Dell OptiPlex GX150 SF PC Desktop
I have progressively more verticle lines appearing on the display. Is there a way to coorect this without replacing the entire display?
This may be caused by a bad video chip or a virus. back up everything and run a restore this may correct this.
Oct 09, 2009 | Computers & Internet
I need to change network name/ssid. the ip
Linksys reset
reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
Sep 06, 2009 | Linksys Wireless-G Broadband Router
Will no longer go wireless
UNINSTALL,,AND INSTALL AGAIN,,,IF THAT DONT WORK,,TRY ,,SYSTEM RESTORE,,OR DOWNLOAD NEW DRIVERS
May 15, 2009 | Acer Aspire One PC Notebook
Need a replacement for Linksys RT54GP2
Unfortunately, Linksys can't replace or upgrade your router. What you can do is just buy a new Linksys router. The model number WRTP54GP2 has all the VOIP functions that you need, plus it has wireless function, you can go online wirelessly using your laptop.
Dec 19, 2008 | Linksys Wireless-G WRT54G Router
SMC7901BRA Modem + Router Cannot connect
The Linksys router can be communicated with by going to Start>Run>type 'http://192.168.1.1' and when the logon screen appears use 'linksys' for username and 'admin' for the password. There you can reset defaults, view status, configure all router functions, et al, including restore defaults. Pressing the little reset button has reset levels that vary with the amount of time it is pressed -basically discharging a capacitive charge. Remember that cable modems use DHCP whereas DSL uses PPPoE. ~Steve
Oct 18, 2008 | SMC WIRELESS-G SMCWPICG 802.11G EZCONNECT...
Need software download for Linksys Wireless-G broadband router WRT54G as I no longer have my CD that originally came with it and I have a Toshiba Satellite A-135 laptop I want to install it on
You can install it manually and no need for the setup CD for it , Try calling linksys tech support and they will walk you through with the process even without the setup CD , this is the linksys tech support number 800-3267114..
Hope that helps.......
Aug 10, 2008 | Computers & Internet
Want to add a network adapter to my laptop
I sometimes have problems with cookies on the linksys site so
http://www.linksys.com
Go to support
(choose North America and US as appropriate)
Choose Linksys Windows Vista Support on left blue bar.
Choose Download Drivers toward center of page
the 5th line under adapters is USB200M V2 (version 2 of the adapter) - if this is your adapter's version (there is a version 1 of this adapter too) there appears to be a 32 bit Vista driver.
Jan 01, 2008 | Linksys USB200M USB 2.0 Network Adapter
No signal to my laptop
try to restore the laptop that doesnt work by going to start accessories system tools system restore then restore it a few weeks back try that
Dec 12, 2007 | Linksys Dual-Band Wireless A+G Broadband...
Linksys WRT160N Wireless Router  Logo
217 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
