Question about HP LaserJet 4600dn Color Printer
Error 51.2 y hp color laserjet 4600 - HP LaserJet 4600dn Color Printer
    Scholar:
  • 73 Answers
Hi There, Please follow the below steps to fix this issue :
Action : 1. Press the green (Select) button to continue. 2. Turn the printer off, and turn it on again.
3. Perform a cold reset : a.Turn on the printer. b.Watch the control panel. c.When the memory starts counting, press and hold the (Select) button. d.Continue holding the (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady. e.Release the (Select) button when the Ready, Data, and Attention light are on steady. f.The control panel will display SELECT LANGUAGE . g.Press (Down Arrow) button once. The control panel will display COLD RESET . h. Press (Select). The printer will perform a cold reset and then continue its power-on sequence. 4. If this message persists, contact an HP-authorized service or support provider.
Posted on Nov 08, 2010
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
Hp color laser jet 4600 57.40 error
57 indicates a printer fan error has occurred
the .4 points to the formatter fan (F1) is bad.
Connector J1004. Voltage should be 24 VDC between pins 1 & 3.
If it is, then replace the fan, if it isn't, replace the DC Controller PCB.
May 01, 2014 | HP LaserJet 4600 Printer
51.XY
X Description:
1=beam detect error
2=laser error ***
Y Description:
0=black ***
1=cyan
2=magenta
3=yellow
Replace the black laser assembly !
Mar 13, 2014 | HP LaserJet 4600 Printer
Message error 51.23 on hp color laserjet cm2320nf
The 51 refers to a laser scanner error. The 23 refers to the yellow laser scanner.
Turn power off. wait 30 seconds. Power up and monitor. If the error reoccurs, your printer
is going to need a DC Controller.
Mar 02, 2011 | HP Laserjet CM2320nf All-In-One Color...
HP Color LaserJet 2605dn_2605dtn error code 51.22
The 51.xx error occurs when there is an error in connection with the laser, if you open the printer to clean the lens, surely you have forgotten to replace the cable connection purple laser. open it again and reconnect all cables OR: 51.X PRINTER ERROR A loss of beam-detect occurred. X description: 1 = Beam-detect error 2 = Laser error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. 5. Replace the DC controller.
Mar 06, 2010 | HP LaserJet 2605DTN Color Printer
Need to have 4600 laser printer in just black ,because of broken
Sorry, my friend, there is no way to force it go B/W and override the error message.
Sep 09, 2009 | HP LaserJet 4600dn Color Printer
Hp 4600 error message 51.2c The message appears as soon as i insert the cyan cartridge. It was working properly but after printing 2000 pages (mostly blue color) there was noise and after that the message...
errors in the 51 range are laser scanner errors, it's saying either the laser is out or the scanner motor is not turning, or not turning fast enough. A good shop repair.
Aug 12, 2009 | HP LaserJet 4600 Printer
''HP Laserjet 4600, Error code 81 0180 E10 1 Error'' the printer does not work. please help !
That indicates that the printer has a network card problem. You can try rebooting/resetting which can clear it but usually means a trip to the hp repair shop.
Jul 09, 2009 | HP LaserJet 4600dn Color Printer
Error Code 51.2 C on an HP 4600
A 51.2 error message means that there is an error 51(Printer Error).2 (Laser Error) C (Cyan). This basically means that there is something wrong with the laser and the cyan color laser.
Reference via HP Website, Click Here
To Fix the problem:
  1. Press the green c00224695.jpg (Select) button to continue.
  3. Perform a cold reset.
    1. Turn on the printer.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the c00224695.jpg (Select) button.
    4. Continue holding the c00224695.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the c00224695.jpg (Select) button when the Ready, Data, and Attention light are on steady.
    6. The control panel will display SELECT LANGUAGE .
    7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
    8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
Mar 21, 2009 | HP LaserJet 4600 Printer
HP LaserJet 4600dn Color Printer Logo
1,900 people viewed this question
Seeker5211
Seeker5211
