I have a purple streak at the top of my flat screen tv. Is there something I can do to fix it?
    Problem Solver:
  • 3 Answers
Sound like the color is going.Hope you have a warranty
Posted on Nov 08, 2010
What should i do,model number below has vertical lines on half of the screen, any suggestions?
If they are blurry lines, likely you have a problem with heat damaging the diffuser plate behind the LCD. Unfortunately, there is no fix to this other than to replace the screen, which is as much as the same TV used. It's usually caused from the vents in the back of the tv getting clogged with dust/debris/smoke and the power inverter overheats. It causes the screen to develop a line on one side of the screen, then it starts to look like the screen was washed with something and you get black streaks running from the top which usually is accompanied by a darkened blurry "cloud".
May 08, 2014 | Seiki 32" LED TV - SE321FB
How to fix Toshiba Regza LCD TV when half the screen with vertical streaks?
hi this fault sounds like a bad tab/ribbon fault, at top of the tv are ribbons connector to the screen, when one is faulty the heat makes them flex causing this fault, you can bond the ribbon down with a bit of rubber to stop it flexing, but this not a permanent repair as it is a screen fault. hope it helps
regards
shaun
Apr 24, 2014 | Toshiba 42HP66 42 in. LCD Television
My son wiped a baby wipe across my LCD tv and now there is a purple streak across the tv I have tried wiping it with a wet soft cloth but it didnt do anything any suggestions?
Did the baby wipe contain alcohol? because LCD screens are sensitive to harsh chemicals. they have layers so this possibly damaged them.
so i think you can save it if you go to a tv repair man or get a new.
Sep 22, 2012 | Televison & Video
My son took a baby wipe to the LCD tv screen and now there is a purple streak I tried a damp soft cloth but that didn't work any suggestions how to clean the baby wipe off?
Try a 50/50 solution of water/rubbing alcohol and a micofiber cloth. DO NOT SPRAY THE SOLUTION ON THE SCREEN ITSELF but on the cloth then wipe down the screen. I hope the screen isn't damaged !!!
Some one sprayed something on my flat screen tv and now it has streaks
It could possibly be stained and cleaning will not help. Please run out to the electronics store and purchase an LCD cleaner or LCD cleaner wipes. Hope you can still fix this. Thanks for asking and show all hands of support!
Jun 26, 2011 | Sylvania LD320SSX LCD TV
I have only had this tv for 2 years. Sony Bravia 32". Black streak going through top of screen & light streaks going vertically down the screen. Also happening on the same day this happened. ...
sound like inverter is going bad.
if you got streaks might have gotten hit by something.
also power supply might be going bad. if you have not clean it of dust, overheating could be the culprit.
good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Oct 29, 2010 | Sony Televison & Video
I have a thin purple streak on one side of my tv screen
panel is bad not economical to repair. usually repair is 90% of what you paid for tv new.
Jul 06, 2009 | Hitachi 55HDX99 55 in. Plasma HDTV
Purple and Green Streaks
If lcd set the issue may be with the T con board which is responsible for video and any aberrations that you see on screen.
Mar 24, 2017 | JVC AV-48WP30 48" Rear Projection...
Sony grand wega 50in
Go to SonyStyle.com/support. The purple streak sounds like a bad optic block. Sony has warrantied this problem on certain models and will either fix or offer you a deal on a new tv. Check out their site for the models warrantied through Dec 2008. Yours may be one.
Oct 14, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
