Asus M3a7b-t motherboard. How do I hook disc drive to this motherboard. CD-RW drives. It has no black connection for these drives.
  • 8 Answers
SOURCE: DVD RW / CD RW Drive
sounds as if your drive is failing, try buying a new drive.
Posted on Sep 03, 2007
  • 833 Answers
SOURCE: How do I install a DVD drive as well as my CD-RW?
mst...First, get your manual out. the drive must be set to be a secondary device unless it is not. You say you have only one IDE...did you remove the CDR? If you have a second IDE or other board connector, then this drive is primary on that. Now, did you install the drivers for the unit? You can use your CDR to do that or get them from the website of the manufacturer. Are there any bent pins on either the motherboard or the back of your drive? Somewhere in there is an answer.
If you have only one drive connector set, you can get a board which will allow you to setup additional drives. Ask your dealer.
Posted on Dec 17, 2007
  • 198 Answers
SOURCE: Samsung TS-H492 CD-RW Combo
There may be an easier solution. If you remember a time when it worked, do a system restore to that date. If that doesn't work, then try the following. Oddly enough, you don't need drivers for the CD/DVD drives--they aren't even recognized unless you have a non-microsoft burning program. Find out what burning software you have-- I recommend downloading Belarc Advisor, a free program which not only tells you everything in your computer, with model numbers for hardware and all of your software (with their unique codes), but will also inform you if you are missing any needed Windows updates. Once you know what you have,you have to seek a download or upgrade at the computer manufacturer's website, as it may be a special program not related to the burning software from the software manufacturer. That may do the trick--sounds to me as if your burning software is corrupted.
Posted on Mar 15, 2008
  • 125 Answers
SOURCE: ASUS P5S800-VM Motherboard configuration
Serial ATA drives are pretty much plug and play. You just need to install them and set them up as a primary drive in your bios settings. The IDE devices can be connected on the same ribbon cable but need to have jumpers set on the back to determine which device is primary or slave. If the IDE devices are on different ribbon cables then most likely the hard drive jumper setting should be set to master or master (single drive). The CD-ROM drive jumper on master. BIOS should detect all drives You also need to assign the boot order in BIOS. CD-ROM should be the first boot device to load and install the new OS onto the primary hard drive.
Posted on Mar 20, 2009
  • 212 Answers
SOURCE: My internal DVD/CD-RW drive is not working. It
1. Start > Run.
2. regedit
3. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class in the Registry Editor dialog box and select the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a folder.
4. Select File > Export
5. save the file to the Desktop in case you need to restore it
6. In the right panel of the Registry Editor, select the LowerFilters line, and then choose Edit > Delete. Click Yes in the Confirm Key Delete dialog box.
7. Do the same for the UpperFilters line
8. Close the Registry Editor.
9. Restart Windows.
Posted on Oct 31, 2009
Drivers CD-RW/DVD DRIVE SH-M522
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
if you physically unplug your cd/dvd restart your computer the plug it back in the found new hardware wizard should activate
if you dont have motherboard disk you will need to download the drivers
http://download.cnet.com/dvdram-en-20071009085435-zip/3000-2110_4-172943.html
http://download.cnet.com/dvdram-en-20070907111350-zip/3000-2110_4-170034.html
http://download.cnet.com/dvdram-win2k-5025-en/3000-2110_4-172950.html
http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html
Adaptec's UDF Reader enables MultiRead CD-ROM drives to read UDF-formatted CD-R and CD-RW discs (such as those written with DirectCD) under Windows 95/98/98SE/NT 4.0/2000.
hope this helps
Jul 07, 2012 | Toshiba Sh-m522 Ide Cd-rw / Dvd Rom Drive...
Pioneer Internal Blu-ray Disc/DVD/CD Writer BDR-206 (Black) i wanna a driver 4 it ??? my os win 7 pro 32bit
you might have to physically unplug the leads for this blue-ray disc/dvd/cd writer then plug them back in this should activate the found new hardware wizard
if your computer came with a motherboard disc the drivers could be on it
hope this helps
Jan 29, 2011 | Pioneer BDR-206BKS BLU-RAY SATA 12X...
I have an asus crw-5232A3 model cdrw drive. Im running winxp. The orange light on the cd drive stays on when a disc is inserted. No discs will read or write but windows says the device is working properly...
They do wear out and break, sounds like an older model. A new DVD/CD burner can be bought for about £15.
You could try a different ide cable from the motherboard, and that the cables are connected properly.
Give that a try before you look for a new one
Aug 27, 2010 | ASUS (CRW-5232AS QUIETRACK) CD-RW Burner
Wont boot
go to BIOS and enable the secondary drive auto detect.
if you manaully set the drive to primary, secondar. the system should be able to detect it as you have set it. if you select cable select or auto. the sytem will put the drive connected to the end of the IDE cable as primary.
Apr 02, 2009 | Intel Motherboard
ASUS P5S800-VM Motherboard set up
Hi m_k_bishop,
You must connect the CD-RW drive to the Secondary IDE connector on your board.
It can not be connected to the Primary IDE port.
(All SATA drives are seen as master drives in the bios).
With that in mind there shouldn't be any data cable connected to the Primary IDE slot.
When you first load the Bios menu screen you should see your CD-RW listed & you should see your SATA drive listed. Go to the title, " BOOT " in your bios.
(If your system has a floppy disk drive connected your Boot menu should read as follows);
First boot device [Floppy Disk]
Second boot device [Your CD-RW drive]
Third boot device [Your SATA drive as shown from the main menu]
No need for a fourth device.
Save the bios & exit. The system will auto restart.
(At boot up re-enter your bios).
Next change the [RAID Mode] to SATA or Enabled anything but RAID.
Once completed save & exit the bios. If everything is connected correctly & you made the changes above your system should see your SATA drive & windows should install.
(Load the windows CD into your CD-RW drive).
The Asus manual lacks the proper information needed for you to make the correct setting changes in the bios.
Good luck m_k_bishop!
Post back if still have trouble... You shouldn't!
Mike
Mar 21, 2009 | ASUS P5S800-VM Motherboard
Mar 20, 2009 | ASUS P5S800-VM Motherboard
I have a SATA M Hard drive and I would lke to add two ATA HDrives
As long as there is an empty IDE port you can. You will probably have to go into the bios settings after you hook the other drives up & set the boot menu to boot from the SATA drive 1st.
Dec 31, 2008 | ASUS K8V-SE Deluxe Motherboard
Guranteeofasustekmotherboard
http://support.asus.com/service/service.aspx?no=231&SLanguage=en-us
Motherboard 3 Year Since 2000/1/1 onwards Notebook 2 Year Since 2002/2/1 onwards Portable PC (Degatto PC) 1 Year VGA Card 3 Year Since 2001/1/1 onwards (3 year warranty)
Prior to 2001/1/1 (1 year warranty) CD /DVD /CD-RW /DVD-RW Drive 1 Year Server 3 Year 3 year warranty coverage on ASUS' full system. Applicable only to components with genuine ASUS label sticker installed on ASUS Server. Warranty period is determined by the serial number on ASUS Server. Wireless Products 2 Year PDA 2 Year Since 2003/2/18 onwards
Dec 27, 2008 | Computers & Internet
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
Computers & Internet Logo
226 people viewed this question
David Payne
David Payne
