Question about Miele S251i Plus Bagged Canister Vacuum
The powerbrush (SEB 213) on my Miele S251i isn't getting any power. The light doesn't come on at all?not red nor green. Any suggestions? Is there a reset button or fuse?
3 Suggested Answers
odiebugs
  • 949 Answers
SOURCE: Miele SEB-213 powerbrush stopped working
Pull the head cover off to check the belt, if the belt is ok then it might be the power connection between the handle and the power head shaft. If the red light is on the power head, then its not the connection
because its getting power. Now some heads have a reset button on them,you could check this also.
With the cover off the power head, remove the belt, now turn it on, and be careful, but try to make the motor shaft spin,with one finger, because if it does start to spin you do not want to hurt your finger.
If the motor starts to spin,put the belt back on, if it does not spin again, the motor is too weak.
If it does not spin at all, the motor is bad.Hope this helps you,and you get it working.
Posted on Mar 24, 2009
wiggout11
Is the red light on when the motor of the power head cuts off??
Pages 6, 11, 12 address issues related to red light/indicator:
http://www.mieleusa.com/manuals_pdf/accessories/Vacuum%20cleaners/SEB234_236_uscqmx.pdf
Also, I believe you can purchase new power brushes/heads.
Posted on Apr 15, 2015
Need exploded drawing to reassemble Miele SEB 228 Power head unit. Do you have a link or PDF? Thank you
Miele SEB 228 Electro Plus Operating Instructions Manual there are two miele with same model number one is a tractor the other a vacuum i attached link to vacuum hope this helps
May 16, 2018 | Miele Vacuums
Miele seb 213 quit spinning on rug
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first let's focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Miele replacement parts for your Miele Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=miele
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Apr 14, 2013 | Miele SEB 213-2 Vacuum
Miele Vacuum(Saturn300). Vacuum powerhead(SEB234/236) does not work, no light comes on and no power. is it the hose(SES119) or the powerhead? tried plugging and unplugging.
You need to check your voltage coming out of your hose and wand, be sure that the handle switch is in the on position. Voltage should be +/-120V. If you have voltage there then you have a power head issue. The replacement would be the SEB 228, you could also use the SEB 236. The SEB 236 is a deluxe version of the SEB 228.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Feb 24, 2013 | Miele Vacuums
My circuit board has a short on the soldering for the DC rectifier that supplies the carpet cleaning motor. Where can I order a new circuit board. Miele S251i
Just a suggestion, but you could try to re-solder the connection on the board. some of the circuit boards did not have enough solder on the board coming from the factory.
That being said, if the component is damaged due to the burning, I suggest you contact your local Miele dealer and have them order you a circuit board for the unit.
IF the unit is less than 5 years old as well, that part should be covered under warranty. Do NOT solder it, just have them replace the part.
Good luck
Nov 19, 2010 | Miele S251i Plus Bagged Canister Vacuum
Miele vacuum powerhead
My power head failed due to the handle switch. It comes apart with the Phillips screw under the vacuum kill slider. Check for continuity across the switch contact solder points.
Mar 01, 2010 | Miele S251i Plus Bagged Canister Vacuum
The Miele S251i just stopped working. Is there an
How long has unit been down? There is a inline fuse by motor housing internally in unit, but sometimes these units take awhile for them to reset
Dec 03, 2009 | Miele S251i Plus Bagged Canister Vacuum
Mar 24, 2009 | Miele SEB 213-2 Vacuum
Meile SEB 213 powerbrush cuts out
Your problem is either in the wand, assuming you have the telescopic dark grey electric wand. The only other thing it could be is the hose, once again, assuming you have the electric hose with either the rocker switch that shuts down the power brush, or the deluxe hose, with the electronic suction control, as well as the brush shut off. Miele wands and hoses are notorious for causing power brushes to cut off. If your Miele is under two years old, I would suggest taking it to a autherized Miele service center, and see what, if any, warranty you have left, and have it checked out. Let me know how you make out.
Jan 14, 2009 | Miele SEB 213-2 Vacuum
Miele S251i Plus Bagged Canister Vacuum Logo
132 people viewed this question
Top Miele Vacuums Experts
Colin Stickland
Colin Stickland
Jim Parker
Jim Parker
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
